I just tried driver 530 as well, and I can confirm, max brightness is still very low.
…rolling back to version 470. :(
According NVidia driver 530 documentation at this link: Chapter 16. Configuring a Notebook
There is (or was) an option to disable the backlight handler, by passing the
NVreg_EnableBacklightHandler=0
parameter to the nvidia kernel module.
This would most likely solve the dim backlight problem, but unfortunately, it seems this option was removed after driver 470, even though it is still mentioned in the documentation.
Running “modinfo nvidia” shows that it is gone.
Is this a temporary bug, or was this feature removed permanently. If so, why is it still in the docs?
Also, what is the point of paying a premium for a laptop with certified NVidia GSync display, if the display is not compatible with the latest NVidia drivers?
Unfortunately, the latest CUDA Toolkit requires updated drivers, so I can’t install CUDA without borking my display. As a workaround, I bought an AMD Radeon eGPU, so I can port my CUDA code to ROCm.
Hi - it’s been 6 months …
Note the previous discussion on this was closed (unsolved):
Unfortunately there was confusion between the BACKLIGHT and the ability to adjust the brightness. Oh dear. The problem is not adjustable brightness. The BACKLIGHT is turned off when the nvidia driver updates > v470 (!)
I have just tried 535.113.01 still bad. The laptop display goes very dim. hard to read. The 2nd monitor (attached by HDMI) is fine.
GOOD LAPTOP BACKLIGHT: 470.199.02
BAD LAPTOP BACKLIGHT: 535.113.01
Please notice this driver has been broken for YEARS. Does NVidia still do computer graphics?
This 17" razer blade pro has a 4K IGZO Touch Display UHD 3840x2160 with NVidia GSync
Still a very good display…
It’s becoming an issue having to revert to version 470.
output from “kscreen-console bug” is attached.
kscreen.console.txt (16.2 KB)
lshw -C display
*-display
description: VGA compatible controller
product: GP104BM [GeForce GTX 1080 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:150 memory:db000000-dbffffff memory:b0000000-bfffffff memory:c0000000-c1ffffff ioport:e000(size=128) memory:c0000-dffff
*-graphics
product: EFI VGA
physical id: 3
logical name: /dev/fb0
capabilities: fb
configuration: depth=32 resolution=800,600
During the Gentoo install of x11-drivers/nvidia-drivers-525.125.06
The word backlight appears twice:
CONFTEST: acpi_video_backlight_use_native
CONFTEST: get_backlight_device_by_name
@2024a - pls respond/help? – can you slice the diff for what happens to the backlight after v470?
Stuck at nvidia-driver version 470.199.02
01:00.0 VGA compatible controller: NVIDIA Corporation GP104BM [GeForce GTX 1080 Mobile] (rev a1) (prog-if 00 [VGA controller])
I had couple of razer blade notebooks handy with Ada and ampere graphics card where I cannot see backlight brightens issue.
I am trying to find similar notebook model with pascal architecture for local reproduction.
Meanwhile, could you please try below command manually and share backlight brightness behavior?
echo n > /sys/class/backlight/nvidia_0/brightness
where n is an integer from 0 to 100 in the increment of 10.
You can also try decreasing its value as well from 100 to 0 in decrement of 10 to confirm its behavior.
Hi All,
Could you please try below command manually and share backlight brightness behavior?
Thanks for the response!! Yes, the backlight entry is there, but it does nothing when it is changed.
razer ~ $ echo 50 > /sys/class/backlight/nvidia_0/brightness
bash: /sys/class/backlight/nvidia_0/brightness: Permission denied
razer ~ $ su
Password:
razer /home/ben # echo 50 > /sys/class/backlight/nvidia_0/brightness
razer /home/ben # echo 0 > /sys/class/backlight/nvidia_0/brightness
razer /home/ben # echo 100 > /sys/class/backlight/nvidia_0/brightness
razer /home/ben #
razer /home/ben # cat /sys/class/backlight/nvidia_0/brightness
100
razer ~ # echo 89 > /sys/class/backlight/nvidia_0/brightness
razer ~ # cat /sys/class/backlight/nvidia_0/brightness
89
razer ~ # echo 100 > /sys/class/backlight/nvidia_0/brightness
xrandr does work - it makes the display dimmer. However, the problem is the display is already too dim (because the backlight is OFF).
The Subject Line should be: Backlight OFF - not Backlight “very low”.
razer /home/ben # /usr/bin/xrandr
Screen 0: minimum 8 x 8, current 7680 x 2160, maximum 32767 x 32767
HDMI-0 connected 3840x2160+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
3840x2160 60.00*+ 59.94 29.97 25.00 23.98
2560x1440 59.95
2048x1280 60.00
1920x1080 60.00 59.94 50.00 25.00 23.98 60.00 50.04
1600x1200 60.00
1600x900 60.00
1280x1024 75.02 60.02
1280x720 59.94
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-0 connected primary 3840x2160+3840+0 (normal left inverted right x axis y axis) 382mm x 215mm
3840x2160 60.00*+ 30.00
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
razer /home/ben # /usr/bin/xrandr --output DP-0 --brightness 0.5
razer /home/ben # /usr/bin/xrandr --output DP-0 --brightness 0.1
razer /home/ben # /usr/bin/xrandr --output DP-0 --brightness 1.0
razer /home/ben #
The nvidia GPU is fully exposed, as usual, in /sys/devices (and indeed /sys/class)
razer /home/ben # ls -la /sys/class/backlight/nvidia_0/
total 0
drwxr-xr-x 3 root root 0 Nov 21 09:06 .
drwxr-xr-x 3 root root 0 Nov 21 09:06 ..
-r--r--r-- 1 root root 4096 Nov 21 10:06 actual_brightness
-rw-r--r-- 1 root root 4096 Nov 21 10:06 bl_power
-rw-r--r-- 1 root root 4096 Nov 21 10:13 brightness
lrwxrwxrwx 1 root root 0 Nov 21 10:06 device -> ../../../0000:01:00.0
-r--r--r-- 1 root root 4096 Nov 21 10:02 max_brightness
drwxr-xr-x 2 root root 0 Nov 21 10:06 power
-r--r--r-- 1 root root 4096 Nov 21 10:06 scale
lrwxrwxrwx 1 root root 0 Nov 21 09:10 subsystem -> ../../../../../../class/backlight
-r--r--r-- 1 root root 4096 Nov 21 10:06 type
-rw-r--r-- 1 root root 4096 Nov 21 09:10 uevent
razer /home/ben # ls -la /sys/class/backlight/nvidia_0/power/
total 0
drwxr-xr-x 2 root root 0 Nov 21 10:06 .
-rw-r--r-- 1 root root 4096 Nov 21 10:14 autosuspend_delay_ms
-rw-r--r-- 1 root root 4096 Nov 21 10:14 control
-r--r--r-- 1 root root 4096 Nov 21 10:14 runtime_active_time
-r--r--r-- 1 root root 4096 Nov 21 10:14 runtime_status
-r--r--r-- 1 root root 4096 Nov 21 10:14 runtime_suspended_time
razer /home/ben # cat /sys/class/backlight/nvidia_0/power/control
auto
razer /home/ben # more /sys/class/backlight/nvidia_0/power/*
/sys/class/backlight/nvidia_0/power/autosuspend_delay_ms
auto
/sys/class/backlight/nvidia_0/power/runtime_active_time
0
/sys/class/backlight/nvidia_0/power/runtime_status
unsupported
/sys/class/backlight/nvidia_0/power/runtime_suspended_time
0
razer /home/ben # equery l nvidia-drivers
* Searching for nvidia-drivers ...
[IP-] [ ] x11-drivers/nvidia-drivers-470.199.02:0/470
I will have to send the same test for a version > 470 (where the backlight is off)
apologies - this razer is currently running the old v470 because this is where
the backlight is still on (and i can read the screen!)
The razer has had Linux NVidia Driver 545.29.02 installed, and has booted into it.
The laptop display is dark again. This is the problem.
There is also a 2nd monitor attached by HDMI cable. it is fine; same as before.
Here are the same commands, now with the new driver - note the backlight is now OFF
razer /mnt/home/ben $ su
Password:
razer /mnt/home/ben # uname -a
Linux where.nowhere 5.15.88-gentoo-x86_64 #6 SMP Wed Oct 11 08:51:33 AEDT 2023 x86_64 Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz GenuineIntel GNU/Linux
razer /mnt/home/ben # equery l nvidia-drivers
[IP-] [ ] x11-drivers/nvidia-drivers-545.29.02:0/545
razer /mnt/home/ben # date
Wed Nov 22 10:45:03 AEDT 2023
razer /mnt/home/ben # cat /sys/class/backlight/nvidia_0/brightness
100
razer /mnt/home/ben # echo 50 > /sys/class/backlight/nvidia_0/brightness
bash: echo: write error: Invalid argument
razer /mnt/home/ben # ls -la /sys/class/backlight/nvidia_0/brightness
-rw-r--r-- 1 root root 4096 Nov 22 10:45 /sys/class/backlight/nvidia_0/brightness
razer /mnt/home/ben # cat /sys/class/backlight/nvidia_0/actual_brightness
100
razer /mnt/home/ben # echo 50 > /sys/class/backlight/nvidia_0/actual_brightness
bash: /sys/class/backlight/nvidia_0/actual_brightness: Permission denied
total 0
drwxr-xr-x 3 root root 0 Nov 22 09:23 .
drwxr-xr-x 3 root root 0 Nov 22 09:23 ..
-r--r--r-- 1 root root 4096 Nov 22 10:45 actual_brightness
-rw-r--r-- 1 root root 4096 Nov 22 10:45 bl_power
-rw-r--r-- 1 root root 4096 Nov 22 10:45 brightness
lrwxrwxrwx 1 root root 0 Nov 22 09:30 device -> ../../../0000:01:00.0
-r--r--r-- 1 root root 4096 Nov 22 09:30 max_brightness
drwxr-xr-x 2 root root 0 Nov 22 10:45 power
-r--r--r-- 1 root root 4096 Nov 22 10:45 scale
lrwxrwxrwx 1 root root 0 Nov 22 09:31 subsystem -> ../../../../../../class/backlight
-r--r--r-- 1 root root 4096 Nov 22 09:30 type
-rw-r--r-- 1 root root 4096 Nov 22 09:31 uevent
razer /mnt/home/ben # more /sys/class/backlight/nvidia_0/*
100
/sys/class/backlight/nvidia_0/bl_power
0
50
*** /sys/class/backlight/nvidia_0/device: directory ***
/sys/class/backlight/nvidia_0/max_brightness
100
*** /sys/class/backlight/nvidia_0/power: directory ***
/sys/class/backlight/nvidia_0/scale
unknown
*** /sys/class/backlight/nvidia_0/subsystem: directory ***
/sys/class/backlight/nvidia_0/type
raw
/sys/class/backlight/nvidia_0/uevent
Pls note the command fails this time!
The laptop screen is too dark to use. I have to revert it, to v470.
btw, the xrandr commands do work, and makes the screen darker.
The problem is the Backlight is clearly OFF. It needs to be ON.
This 4K screen has IGZO & NVidia G-Sync.
any assistance appreciated.
regards,
ben.
Hello! happy 3D day - 3rd of December 2023.
this topic is still open, since 26-Oct-2022. Unsolved.
Perhaps it could be fixed in the open-source version of the driver?
Is that a reality? Is the open-source version up to the same version of the private binary/firmware?
b.
@fortythree
Sory for taking longer time to repro issue locally.
Could you please do us a favor one more time by sharing nvidia bug report from repro driver.
@fortythree
@fortythree
Hi All,
I would request to please confirm if anyone is still seeing brightness issue with latest release driver.
If yes, please share laptop model along with nvidia bug report.
Hi Amrits,
I can confirm that I am still having the same brightness issue as before. There’s no bug report, just a dim screen.
The laptop is: Razer Blade Pro 17 (2017) RZ09-01663 with 4K IGZO G-Sync Sharp CRX1200 display and GTX 1080 GPU. (https://mysupport.razer.com/app/answers/detail/a_id/3687/~/razer-blade-pro-17”-(2017)-|-rz09-01663-support-%26-faqs)
With the 470 driver, the screen is nice and bright but with newer drivers, like 535, the backlight is extremely dim, too dim for practical use. So, I’ve been sticking with the 470 driver, until now. However, that is no longer an option: I just upgraded to Ubuntu 24.04, but unfortunately it doesn’t work well with the old 470 driver. Text in the Settings window won’t render, and I see all kinds of glitches and rendering artifacts on the desktop. Ubuntu works much better with the 535 driver, except for the dim backlight. Now, the only usable driver left, is the open source Nouveau driver, but that has no Cuda or ray tracing support.
Hi Amrits,
Yes. Same. Sorry, i’m not sure what to do (how to: “sharing nvidia bug report from repro driver”). Do you mean respond here? Very happy to do whatever’s needed to fix this. It seems i have the same razer laptop as user61024
It’s still stuck running v470 nvidia driver.
razer ~ $ date
Mon Apr 29 11:37:45 AEST 2024razer ~ $ uname -a
Linux where.nowhere 6.6.21-gentoo-x86_64 #1 SMP PREEMPT_DYNAMIC Sun Apr 7 12:19:18 AEST 2024 x86_64 Intel(R) Core™ i7-6700HQ CPU @ 2.60GHz GenuineIntel GNU/Linuxrazer ~ $ equery l x11-drivers/nvidia-drivers
- Searching for nvidia-drivers in x11-drivers …
[IP-] [ ] x11-drivers/nvidia-drivers-470.239.06:0/470razer ~ $ hwinfo --gfxcard
16: PCI 100.0: 0300 VGA compatible controller (VGA)
[Created at pci.386]
Unique ID: VCu0.w5kfazC82XD
Parent ID: vSkL.kzadsJz_dQ7
SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: “nVidia GP104BM [GeForce GTX 1080 Mobile]”
Vendor: pci 0x10de “nVidia Corporation”
Device: pci 0x1be0 “GP104BM [GeForce GTX 1080 Mobile]”
SubVendor: pci 0x1a58 “Razer USA Ltd.”
SubDevice: pci 0x6750
Revision: 0xa1
Driver: “nvidia”
Driver Modules: “nvidia”
Memory Range: 0xdb000000-0xdbffffff (rw,non-prefetchable)
Memory Range: 0xb0000000-0xbfffffff (ro,non-prefetchable)
Memory Range: 0xc0000000-0xc1ffffff (ro,non-prefetchable)
I/O Ports: 0xe000-0xe07f (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 150 (292716 events)
Module Alias: “pci:v000010DEd00001BE0sv00001A58sd00006750bc03sc00i00”
Driver Info #0:
Driver Status: nvidia_drm is active
Driver Activation Cmd: “modprobe nvidia_drm”
Driver Info #1:
Driver Status: nvidia is active
Driver Activation Cmd: “modprobe nvidia”
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #14 (PCI bridge)Primary display adapter: #16
razer ~ $ su
razer ~ # lshw -C display
*-display
physical id: 0
version: a1
width: 64 bits
clock: 33MHz
*-graphics
product: EFI VGA
physical id: 2
capabilities: fb
Follow-up. As a test, I trialled NVidia Driver version 550.78 [edit correction]
It still has the same problem: the backlight is off. It’s no good.
I have reverted to NVidia Driver version 470.239.06
where the backlight is on.
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
Sure Amrits,
I ran the nvidia-bug-report.sh script twice, once with driver 470 installed, and once with 535 installed.
btw. I rolled back to Ubuntu 22.04 for now, so I can continue using the 470 driver for a brighter screen.
(My Vulkan code wouldn’t run under Nouveau.)
Files attached:
470-nvidia-bug-report.log (1.3 MB)
535-nvidia-bug-report.log (1.4 MB)
