Battery and power monitor
I’m struggling to search a good solution to safely power the AGX Orin of my robot.
I have a 4S LiPo battery powering the AGX with a DC-DC to keep a stable power source.
I’m searching for a simple power monitor with a communication interface (uart, CAN, USB,…) to check the value with the Jetson and safely power it off by software when the battery is exhausted.
Does anyone have a ready solution to recommend?
Thank you
Walter
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Hi @carolyuu
I think there’s a misunderstanding.
I’m not referring to computing power monitor, but to battery power (charge status) monitor.
We don’t have recommendation on this. You can check with the vendors in Jetson Ecosystem | NVIDIA Developer for options.
