Jetson AGX Orin is turning on, but it's not supplying power to peripherals or not functioning properly
We have a Jetson AGX Orin 64 GB developer kit and we wanted to use it for the purpose of autonomous driving, but it not supplying power to peripherals and not functioning properly. Can you please resolve this issue as early as possible
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I have moved this post for better visibility.
Cheers,
Tom
Not sure what issue you met on this power things, please provide more details then we can know how to support.
Dear NVIDIA Developer Forums,
I am experiencing an issue with my Jetson AGX Orin, where the device powers on but does not function correctly. Below are the details of the problem:
Issue Description:- The Jetson AGX Orin powers on, and the power LED is solid, but no output is displayed on DP.
  • No peripherals (USB, Ethernet, etc.) are receiving power.
  • The system does not seem to boot properly.
  • I have attempted a serial console connection but did not receive any boot logs.
  • Recovery mode does not appear to work, and the board is not detected via USB when connected to a host PC.
Troubleshooting Steps Taken:
✔ Used a different power adapter (19V-20V, 5A)
✔ Tried multiple DP cables and monitors
✔ Removed all peripherals and tried booting again
✔ Attempted booting into recovery mode
Request for Support:
I would appreciate your guidance on further troubleshooting steps. If the issue is hardware-related, please advise on the RMA process.
Thank you for your assistance.
Best Regards,
Venkata Lakshmi,
The Deep Terrain Ai
Will you please give a quick response to this based on the information i provided above about Jetson AGX Orin issue and the Troubleshooting steps that we had took to overcome the issue
Best Regards,
Venkata Lakshmi,
The Deep Terrain Ai
Have you tried to do a clean flash on your device with JetPack SW?
IF yes, and still not working, then please do the RMA, see Jetson FAQ | NVIDIA Developer
Everything was done by our side and still it is not working
How do you do the recovery mode?
Please describe the steps in detail.
Also use other flashing cable supporting data transfer to cross check whether issue exist.
Since recovery mode is a pure hardware event, if cannot enter recovery mode, please do the RMA.
I followed the below steps for recovery mode
  1. Powered off the jetson AGX Orin
  2. Connected to Host PC using a USB-C cable
    3.Press and hold the recovery button
    4.While holding recovery button, press and released the power button of jetson.
    5.After released the power button,hold the recovery button for 2 secs and then released.
After performing this steps also it is not displaying anything on the screen
Best Regards,
Venkata Lakshmi,
The Deep Terrain Ai
Will you please let me know how to do the RMA process?
Thank you
Best Regards,
Venkata Lakshmi,
The Deep Terrain Ai
After this you should check “lsusb” command on the host pc terminal.
See if you can see "NVidia Corp…’ listing which means unit is in recovery mode.
Thanks for the reply
To check the lsusb command first it is not displaying anything that’s the problem
Best Regards,
Venkata Lakshmi,
The Deep Terrain Ai
Please refer to the Jetson FAQ | NVIDIA Developer.
We have referred and posted. Please provide the return process details
Best Regards,
Venkata Lakshmi,
The DeepTerrain Ai
Please contact with RMA first.
I contacted RMA and they also said to post in forums
We have the urgency of it
Please make anything possible quickly
Best Regards,
Venkata Lakshmi,
The DeepTerrain Ai
Please provide this forum link for them.
Thank you we will provide the link with RMA
Best Regards,
Venkata Lakshmi,
The DeepTerrain Ai
After providing the link they are not even responding
I have posted everything in the forums and troubleshooting steps also performed
We have the urgency on this issue
Provide the details of the returning process
Best Regards,
Venkata Lakshmi,
The DeepTerrain Ai
