Is it possible to monitor battery voltage and charge level with a Jetson Orin NX?
I would like to know if it’s possible to use a Jetson Orin NX to read the incoming voltage level from a battery in order to calculate the battery’s charge level. Alternatively, is there a way to determine the battery’s charge level using the sensors available on the Jetson Orin NX?
No, it is not supported as there is no ADC on Jetson.
