I am using a battery to power my system and was wondering if there was a way to read the voltage from the barrel jack input so that I can integrate a state-of-charge monitor at a software level. It is possible to read this value directly or would I need to read the voltage externally and feed it back through the GPIO somehow?
euan2
1
hello euan2,
you may see-also developer guide, Software-Based Power Consumption Modeling.
the input voltage is available via sysnode, there’re different channels.
for example, /sys/bus/i2c/drivers/ina3221/1-0040/hwmon/hwmon4/in1_input
Related topics
| Jetson AGX Orin can i read the input voltage? | 6 | 79 | April 9, 2026 | |
| Want to read input voltage coming in jetson orin nano | 4 | 503 | April 7, 2025 | |
| Interpretation of Orin power monitors | 2 | 810 | August 23, 2022 | |
| ORIN AGX\Nx Power Consumption | 2 | 940 | May 4, 2023 | |
| Jetson AGX Orin INA3221 power monitor layout | 4 | 1297 | August 31, 2022 | |
| Power consumption of Jetson AGX Orin module or Jetson AGX Orin soc | 3 | 685 | June 13, 2023 | |
| Voltage, power usage current Monitoring On Drive AGX Orin | 12 | 402 | February 20, 2025 | |
| Subdirectory to execute "in_power0_input" inaccessible? | 10 | 371 | June 9, 2024 | |
| New JetPack 5.0 how to measure power consumption of CPU/GPU Soc | 4 | 1466 | September 28, 2022 | |
| Is it possible to monitor battery voltage and charge level with a Jetson Orin NX? | 2 | 137 | October 18, 2024 |
