could you point out which exactly file[datasheet] to download of the several in order to find which volt range is supported on AGX devkit Orin Jetson barrel jack, please?
Thank you
AV
The DC Jack supply voltage is SYS_VIN_HV. You can find the range of it is 7~20V in module datasheet: Log in | NVIDIA Developer
