We intend to use the AGX Orin in an embedded project and I’ve some questions :
What’s the voltage range of the DC Jack ? I saw that the box consume 60W, but I can not find any information about the input voltage. (We intend to power the box with a 12V or 24V truck battery)
Does the AGX turn on when it get power or do we need to push the power on button ? If the power on button is needed, is there a way to force the AGX Orin to turn on once it powered ?
As we intend to use the AGX Orin in truck, we will have to do the available update on the field. Is there a way to update the board on the field, without using the SDK manager on a PC (is there an equivalent to “apt-get upgrade” to upgrade the JetPack ?
For this, we plan to support OTA-based image update on next 5.1.1 release. You can use 5.1 now and when 5.1.1 is released, the system can be upgraded with the method.
