Best way to check which tegra board
So, given a running Tegra system, what’s the ideal way of determining whether a system is a Nano, TX2, Xavier, etc? I was thinking of relying on the apt sources since that now lists the SOC, however that seems rather fragile and I was wondering if there was a better way (something in /proc maybe).
hello mdegans,
there’re several ways to check it.
  1. you may refer to Quick Start Guide to determine whether the developer kit is in Force Recovery mode.
    for example, it’s 7c18 for Jetson-TX2.
$ lsusb
Bus 001 Device 068: ID 0955:<b>7c18</b> NVidia Corp.
  1. you could check the nv_tegra_release for release version and also board version from the system.
    for example,
$ cat /etc/nv_tegra_release
# R32 (release), REVISION: 3.1, GCID: , <b>BOARD: t186ref</b>, EABI: aarch64, DATE: Thu Dec 19 03:38:02 UTC 2019
  1. besides, you could also check the kernel message, please search for “DTS File Name” for Jetson Modules and SoCs.
    for example, this is TX2.
$ dmesg | grep "DTS File Name"
[    0.184289] DTS File Name: .../t18x/quill/kernel-dts/tegra186-quill-<b>p3310</b>-1000-c03-00-base.dts
Thanks, Jerry! That’s exactly what I needed.
My experience is that it depends on the release. The /etc/nv_tegra_release file was omitted for a couple of releases when a dpkg feature for lookup was introduced. I believe that /etc/nv_tegra_release was added back in recently.
For the code to be “robust” you may have to do some hunting. Raffaello Bonghi has a shell script for the heavy lifting:
https://github.com/rbonghi/jetson_stats/blob/master/scripts/jetson_variables
It can be difficult to differentiate the TX1 from the Nano from the chip ID/nv_tegra_release methods, the advantage of the DTS method is that you can determine the actual board in use. For example, this might be useful for differentiating between a Jetson Nano Rev A and a Rev B board. I’m not sure how you differentiate between a dev kit module and a production module.
Thanks, Kangalow. That give me some more options. Unfortunately “dmesg | grep DTS” doesn’t seem to work on my Nano (i guess it’s not printed anymore), and /etc/nv_tegra_release only tells me the soc.
I had a look in proc, and it looks like on Nano i get:
$ cat /proc/device-tree/nvidia,boardids
3448
(and that would also be in /sys since /proc/device-tree is a symlink there)
So I’m just putting that here as another tidbit for whoever else is looking.
There is other useful stuff in /proc/device-tree like the dts filename:
$ cat /proc/device-tree/nvidia,dtsfilename
/dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
also
$ cat /proc/device-tree/model
NVIDIA Jetson Nano Developer Kit
and
$ cat /proc/device-tree/compatible
nvidia,p3449-0000-b00+p3448-0000-b00nvidia,jetson-nanonvidia,tegra210
there is more, including the serial
I’m gonna make a quick python library for this and will post a link here when done.
So for those who want it, there is this python code to read various things:
# Copyright 2020 Michael de Gans
# Permission is hereby granted, free of charge, to any person obtaining a copy of
# this software and associated documentation files (the "Software"), to deal in
# the Software without restriction, including without limitation the rights to
# use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
# of the Software, and to permit persons to whom the Software is furnished to do
# so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
import os
import re
__all__ = [
    'name',
    'model',
    'compatible_models',
    'dts_filename',
    'soc',
    'nickname',
def cat(filename) -> str:
    with open(filename) as f:
        return f.read().rstrip('\x00')
def name():
    return cat('/proc/device-tree/model')
def model():
    return cat('/proc/device-tree/nvidia,proc-boardid')
def compatible_models():
    raw = cat('/proc/device-tree/compatible')
    return re.split(r'nvidia|\x00|,|\+', raw)[2:4]
def dts_filename(short=False):
    if short:
        return os.path.basename(dts_filename())
    return os.path.abspath(cat('/proc/device-tree/nvidia,dtsfilename'))
def soc(short=False):
    if short:
        return re.search(r'(?<=platform/)(.*)(?=kernel-dts)', dts_filename())[0].split('/')[0]
    return re.split(r'nvidia|\x00|,|\+', raw)[9]
def nickname():
    return re.search(r'(?<=platform/)(.*)(?=kernel-dts)', dts_filename())[0].split('/')[1]
def quick_test():
    print(f'name={name()}')
    print(f'model={model()}')
    print(f'compatible_models={compatible_models()}')
    print(f'dts_filename={dts_filename()}')
    print(f'dts_filename_short={dts_filename(short=True)}')
    print(f'soc={soc()}')
    print(f'short_soc={soc(short=True)}')
    print(f'nickname={nickname()}')
if __name__ == "__main__":
    quick_test()
when run:
name=NVIDIA Jetson Nano Developer Kit
model=3448
compatible_models=['p3449-0000-b00', 'p3448-0000-b00']
dts_filename=/dvs/git/dirty/git-master_linux/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
dts_filename_short=tegra210-p3448-0000-p3449-0000-b00.dts
soc=tegra210
short_soc=t210
nickname=porg
I will put it on GitHub later after I add tests. I plan on finding at least one other way to get each string so if they don’t match, the test fails. Any help would be welcome.
Hi mdegans,
I was looking this thread and there are a lot of point interesting also for my jetson-stats.
Thank you Kangalow to quote me! :-)
I use to recognize the jetson model this number: /sys/module/tegra_fuse/parameters/tegra_chip_id but don’t recognize some model
I notice that not all commands have the same output:
Nano - JP 4.3:
  • cat /sys/module/tegra_fuse/parameters/tegra_chip_id = 33
  • cat /etc/nv_tegra_release = BOARD: t210ref
  • cat /proc/device-tree/model = NVIDIA Jetson Nano Developer Kit
  • cat /proc/device-tree/nvidia,boardids = 3448
  • cat /proc/device-tree/compatible = nvidia,p3449-0000-b00+p3448-0000-b00nvidia,jetson-nanonvidia,tegra210
  • cat /proc/device-tree/nvidia,dtsfilename = /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
  • Xavier - JP 4.2.2:
  • cat /sys/module/tegra_fuse/parameters/tegra_chip_id = 25
  • cat /etc/nv_tegra_release = BOARD: t186ref
  • cat /proc/device-tree/model = Jetson-AGX
  • cat /proc/device-tree/nvidia,boardids = No such file or directory
  • cat /proc/device-tree/compatible = nvidia,jetson-xaviernvidia,tegra194
  • cat /proc/device-tree/nvidia,dtsfilename = /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
  • TX2 - JP 3.2:
  • cat /sys/module/tegra_fuse/parameters/tegra_chip_id = 24
  • cat /proc/device-tree/model = quill
  • cat /proc/device-tree/compatible = nvidia,quillnvidia,tegra186
  • cat /proc/device-tree/nvidia,dtsfilename = /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
  • I can’t check a TX1 right now, I will do soon.
    I think a good reference to recognize the board is use the last name in /proc/device-tree/compatible, but I’m not sure of that.
    Best,
    Raffaello
    Thanks rbonghi,
    That output is very useful. It does seem like the last part of …/compatible is the best place along with first part of the dts basename. It’s interesting that …/nvidia,boardids isn’t on every system.
    I finally bring my TX1, this is the output:
    TX1 - JP 3.2:
  • cat /proc/device-tree/model = jetson_tx1
  • cat /proc/device-tree/compatible = nvidia,jetson-cvnvidia,tegra210
  • cat /proc/device-tree/nvidia,dtsfilename = /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
  • I don’t have a TK1 with me, but it’s out of production.
    Anyway to recognize the Nano and the TX1 require more than one step.
    Best,
    Raffaello
