Best way to configure 6 PWM motor control outputs from Orin Nano Development Kit
Hi all,
I’m designing a robot that uses Orin Nano Development Kit. Ideally, I would like to drive 6 independent PWM motor control outputs from the development kit.
What would the best approach for this? Alternatively, I could use something like the PCA 9685 servo driver.
Thanks for your help!
Bob Anderson
I am moving this topic to the Jetson forums for visibility.
There are at most only 3 PWM pins on Orin Nano. You may need to refer to other online resource to see if you could use gpio to simulate as PWM.
