Big Minecraft issues with latest stable driver 565.77 on Wayland
You’re brilliant. Thanks a lot. This helps me from those annoying crashes on exit.
They persist even in newer library -
Java VM: OpenJDK 64-Bit Server VM (Red_Hat-21.0.6.0.7-1) (21.0.6+7, mixed mode, sharing, tiered, compressed oops, compressed class ptrs, g1 gc, linux-amd64)
Problematic frame:
C [libnvidia-glcore.so.570.124.04+0xa5911c]
I just add
export __GL_THREADED_OPTIMIZATIONS=0
before starting TLauncher and voila )))
And there are no any other issues with MC on My Fedora 41 (KDE 6.3.3, wayland) F11 works just fine.
Still have some concerns about possible drawbacks from disabling threaded optimization. Hope nvidia will fix the issue so we can live without such crutches. Perhaps this buggy “optimization” should be turned off by default.
For those who suffering from F11-fullscreen bug - I would suggest to try turn off Adaptive sync - it is under Display configuration in KDE. I had freezing issues in MC (in fullscreen mode only) before turned it off too
