NVIDIA Corporation GA104 [GeForce RTX 3070 Lite Hash Rate] (rev a1)
Rocky Linux 8.6 (RHEL 8.6 binary compatiable)
Using HPC drivers from:
Alienware R13 with latest 1.7.0 BIOS.
Detailed description:
Previous kernel 4.18.0-372.19.1 worked, however, now on 4.18.0-372.26.1 the nvidia driver doesn’t work with the precompiled nvidia kmod.
Upon reboot with GUI the computer just arrives at a black screen. I’m unable to Ctrl+Alt+F2, etc… to get a terminal when this occurs. When I boot the computer to a multi-user terminal I obtained the nvidia bug report attached. Additionally, when executing the nvidia-smi some error message appear on the screen. I’ve captured these errors in the attached nvidia-dmesg attachment and you can see the nvidia-smi.error showing the command responding with typical view after those error messages are displayed on the screen.
Adding nomodeset at boot doesn’t help with the GUI loading.
Uninstalling the nvidia driver is the only thing that allows the GUI to display and function as normal. Computer has the latest BIOS and I’ve used the HPC driver on many computers without this issue. Any help is appreciated, thanks.
To make sure this log file includes as much relevant information as possible, please start the X server with `startx -- -logverbose 6` and run `nvidia-bug-report.sh` after the problem has occurred. If X can not be started or the machine appears to have crashed, please check if you can log into it remotely (e.g. via ssh) and run `nvidia-bug-report.sh` in the remote shell, if possible.
Inside a multi-user.target boot up I ran startx – -logverbose 6 and nvidia-bug-report.sh
Thanks for the response, 515.65.01 worked as previously noted.
However, we were using a displayport connection with 520.51.05 and the new release 520.56.06 notes that, “Fixed a regression in 515.76 that caused blank screens and hangs when starting an X server on RTX 30 series GPUs in some configurations where the boot display is connected via HDMI.”
when boot the machine, cloldboot or reset, the screen text when boot systemd turns freeze, but the system still booting in background. after a minute (for make sure the machine is booted), binded typping my login/password, and then launch “startwayland” (my wayland session launcher script), the display recover and my desktop appears
the same thing when halt/poweroff. after logount the session, the display become black, do things, and then shutdown
this happen with kernel 6.0.2-arch1-1. and 520.61.05 drivers. the bootlog/journalctrl is out of nvidia driver errors
No obvious display issue when using 520.61.06 from runfile installation. However, I did see some errors in dmesg despite the X GUI environment displaying.
