BlueField-2 BIOS configuration for VMware ESXi 8 (SR-IOV)
I’m setting up an NVIDIA BlueField-2 on a host running VMware ESXi 8, and I need to confirm the correct BIOS/UEFI configuration on the DPU for full compatibility with SR-IOV.
The goal is to assign 1 VF from port P0 and 1 VF from port P1 to each VM.
Key questions:
  1. Which operation mode should be used for ESXi 8 — Embedded, Host, Separated, or Switchdev?
  2. In the DPU BIOS, which options must be enabled or disabled for SR-IOV? (e.g., SR-IOV Enable, IOMMU, PXE Boot, Secure Boot, Hardware Offload).
  3. What is the recommended firmware/BFB version for proper VF detection under ESXi 8?
  4. Should the PFs be set to Host-visible or Embedded-visible so ESXi can detect the VFs?
My setup:
  • VMware ESXi 8.0 U1
  • BlueField-2 dual port (P0/P1)
  • Goal: 1 VF from P0 + 1 VF from P1 per VM
Jose
If someone needs guidance on the compatible settings for using this card with ESXi 8.0.3, I can share the configuration details.
root@localhost:/lib/modules/5.15.0-1074-bluefield/updates/dkms# sudo mlxconfig -d /dev/mst/mt41686_pciconf0 q
Device #1:
Device type: BlueField2
Description: BlueField-2 P-Series DPU 25GbE Dual-Port SFP56; PCIe Gen4 x8; Crypto and Secure Boot Enabled; 16GB on-board DDR; 1GbE OOB management; HHHL
Device: /dev/mst/mt41686_pciconf0
Configurations: Next Boot
    ACCURATE_TX_SCHEDULER                       False(0)
    ADVANCED_PCI_SETTINGS                       False(0)
    AES_XTS_TWEAK_INC_64                        False(0)
    ALLOW_RD_COUNTERS                           True(1)
    ATS_ENABLED                                 False(0)
    AUTO_POWER_SAVE_LINK_DOWN_P1                False(0)
    AUTO_POWER_SAVE_LINK_DOWN_P2                False(0)
    BOOT_DBG_LOG                                False(0)
    BOOT_INTERRUPT_DIS                          False(0)
    BOOT_LACP_DIS                               False(0)
    BOOT_PKEY                                   0
    BOOT_UNDI_NETWORK_WAIT                      0
    BOOT_VLAN_EN                                False(0)
    BOOT_VLAN                                   1
    CLAMP_TGT_RATE_AFTER_TIME_INC_P1            True(1)
    CLAMP_TGT_RATE_AFTER_TIME_INC_P2            True(1)
    CLAMP_TGT_RATE_P1                           False(0)
    CLAMP_TGT_RATE_P2                           False(0)
    CNP_802P_PRIO_P1                            6
    CNP_802P_PRIO_P2                            6
    CNP_DSCP_P1                                 48
    CNP_DSCP_P2                                 48
    CQE_COMPRESSION                             BALANCED(0)
    CRYPTO_POLICY                               UNRESTRICTED(1)
    DCBX_CEE_P1                                 False(0)
    DCBX_CEE_P2                                 False(0)
    DCBX_IEEE_P1                                False(0)
    DCBX_IEEE_P2                                False(0)
    DCBX_WILLING_P1                             False(0)
    DCBX_WILLING_P2                             False(0)
    DCE_TCP_G_P1                                1019
    DCE_TCP_G_P2                                1019
    DCE_TCP_RTT_P1                              1
    DCE_TCP_RTT_P2                              1
    DCR_LIFO_SIZE                               16384
    DO_NOT_CLEAR_PORT_STATS_P1                  False(0)
    DO_NOT_CLEAR_PORT_STATS_P2                  False(0)
    DPU_RESET_NOTIFICATION_ENABLED              DISABLED(0)
    DUP_MAC_ACTION_P1                           LAST_CFG(0)
    DUP_MAC_ACTION_P2                           LAST_CFG(0)
    DYNAMIC_VF_MSIX_TABLE                       False(0)
    ECPF_ESWITCH_MANAGER                        ECPF(1)
    ECPF_PAGE_SUPPLIER                          ECPF(1)
    ESWITCH_HAIRPIN_DESCRIPTORS                 Array\[0..7\]
    ESWITCH_HAIRPIN_TOT_BUFFER_SIZE             Array\[0..7\]
    ETH_ETS_GRANULARITY_P1                      DEVICE_DEFAULT(0)
    ETH_ETS_GRANULARITY_P2                      DEVICE_DEFAULT(0)
    ETS_SCHED_MODE_P1                           device_default(0)
    ETS_SCHED_MODE_P2                           device_default(0)
    EXP_ROM_NVME_UEFI_x86_ENABLE                True(1)
    EXP_ROM_PXE_ENABLE                          True(1)
    EXP_ROM_UEFI_ARM_ENABLE                     True(1)
    EXP_ROM_UEFI_x86_ENABLE                     True(1)
    EXP_ROM_VIRTIO_BLK_UEFI_ARM_ENABLE          False(0)
    EXP_ROM_VIRTIO_BLK_UEFI_x86_ENABLE          False(0)
    EXP_ROM_VIRTIO_NET_PXE_ENABLE               False(0)
    EXP_ROM_VIRTIO_NET_UEFI_ARM_ENABLE          False(0)
    EXP_ROM_VIRTIO_NET_UEFI_x86_ENABLE          False(0)
    FLEX_IPV4_OVER_VXLAN_PORT                   0
    FLEX_PARSER_PROFILE_ENABLE                  0
    HAIRPIN_DATA_BUFFER_LOCK                    False(0)
    HIDE_PORT2_PF                               False(0)
    HOST_CHAINING_CACHE_DISABLE                 False(0)
    HOST_CHAINING_DESCRIPTORS                   Array\[0..7\]
    HOST_CHAINING_MODE                          DISABLED(0)
    HOST_CHAINING_TOTAL_BUFFER_SIZE             Array\[0..7\]
    HOST_PRIV_FLASH_ACCESS                      DEVICE_DEFAULT(0)
    HOST_PRIV_FW_UPDATE                         DEVICE_DEFAULT(0)
    HOST_PRIV_NIC_RESET                         DEVICE_DEFAULT(0)
    HOST_PRIV_NV_GLOBAL                         DEVICE_DEFAULT(0)
    HOST_PRIV_NV_HOST                           DEVICE_DEFAULT(0)
    HOST_PRIV_NV_INTERNAL_CPU                   DEVICE_DEFAULT(0)
    HOST_PRIV_NV_PORT                           DEVICE_DEFAULT(0)
    HOST_PRIV_PCC_UPDATE                        DEVICE_DEFAULT(0)
    IB_ETS_GRANULARITY_P1                       DEVICE_DEFAULT(0)
    IB_ETS_GRANULARITY_P2                       DEVICE_DEFAULT(0)
    IB_ROUTING_MODE_P1                          LID(1)
    IB_ROUTING_MODE_P2                          LID(1)
    ICM_CACHE_MODE                              DEVICE_DEFAULT(0)
    INITIAL_ALPHA_VALUE_P1                      1023
    INITIAL_ALPHA_VALUE_P2                      1023
    INTERNAL_CPU_ESWITCH_MANAGER                ECPF(0)
    INTERNAL_CPU_IB_VPORT0                      ECPF(0)
    INTERNAL_CPU_MODEL                          EMBEDDED_CPU(1)
    INTERNAL_CPU_OFFLOAD_ENGINE                 ENABLED(0)
    INTERNAL_CPU_PAGE_SUPPLIER                  ECPF(0)
    INTERNAL_CPU_RSHIM                          ENABLED(0)
    INT_LOG_MAX_PAYLOAD_SIZE                    AUTOMATIC(0)
    IP_OVER_VXLAN_EN                            False(0)
    IP_VER                                      IPv6(1)
    KEEP_ETH_LINK_UP_P1                         True(1)
    KEEP_ETH_LINK_UP_P2                         True(1)
    KEEP_IB_LINK_UP_P1                          False(0)
    KEEP_IB_LINK_UP_P2                          False(0)
    KEEP_LINK_UP_ON_BOOT_P1                     True(1)
    KEEP_LINK_UP_ON_BOOT_P2                     True(1)
    KEEP_LINK_UP_ON_STANDBY_P1                  False(0)
    KEEP_LINK_UP_ON_STANDBY_P2                  False(0)
    LAG_RESOURCE_ALLOCATION                     PRE_ALLOCATION(1)
    LARGE_MTU_TWEAK_64                          False(0)
    LEGACY_BOOT_PROTOCOL                        NONE(0)
    LLDP_NB_DCBX_P1                             True(1)
    LLDP_NB_DCBX_P2                             True(1)
    LLDP_NB_RX_MODE_P1                          OFF(0)
    LLDP_NB_RX_MODE_P2                          OFF(0)
    LLDP_NB_TX_MODE_P1                          OFF(0)
    LLDP_NB_TX_MODE_P2                          OFF(0)
    LOG_DCR_HASH_TABLE_SIZE                     11
    LOG_MAX_OUTSTANDING_READ_ATOMIC             0
    LOG_MAX_OUTSTANDING_WQE                     7
    LOG_MAX_QUEUE                               17
    LOG_TX_PSN_WINDOW                           7
    LRO_LOG_TIMEOUT0                            6
    LRO_LOG_TIMEOUT1                            7
    LRO_LOG_TIMEOUT2                            8
    LRO_LOG_TIMEOUT3                            13
    MANAGEMENT_PF_MODE                          MNG_PF_ENABLE(1)
    MAX_PACKET_LIFETIME                         0
    MCTP_I3C_DISABLE                            False(0)
    MEMIC_BAR_SIZE                              0
    MEMIC_SIZE_LIMIT                            \_256KB(1)
    MIN_TIME_BETWEEN_CNPS_P1                    4
    MIN_TIME_BETWEEN_CNPS_P2                    4
    MKEY_BY_NAME                                False(0)
    MKEY_BY_NAME_RANGE                          DEVICE_DEFAULT(0)
    MPFS_MC_LOOPBACK_DISABLE_P1                 False(0)
    MPFS_MC_LOOPBACK_DISABLE_P2                 False(0)
    MPFS_UC_LOOPBACK_DISABLE_P1                 False(0)
    MPFS_UC_LOOPBACK_DISABLE_P2                 False(0)
    MULTIPATH_DSCP                              DEVICE_DEFAULT(0)
    MULTI_PCI_RESOURCE_SHARING                  DEVICE_DEFAULT(0)
    MULTI_PORT_VHCA_EN                          False(0)
    NON_PREFETCHABLE_PF_BAR                     False(0)
    NUM_OF_PFC_P1                               8
    NUM_OF_PFC_P2                               8
    NUM_OF_PF                                   3
    NUM_OF_TC_P1                                \_8_TCs(0)
    NUM_OF_TC_P2                                \_8_TCs(0)
    NUM_OF_VFS                                  0
    NUM_OF_VL_P1                                \_4_VLs(3)
    NUM_OF_VL_P2                                \_4_VLs(3)
    NUM_PF_MSIX                                 127
    NUM_PF_MSIX_VALID                           True(1)
    NUM_VF_MSIX                                 11
    NVME_EMULATION_CLASS_CODE                   67586
    NVME_EMULATION_DEVICE_ID                    24577
    NVME_EMULATION_ENABLE                       False(0)
    NVME_EMULATION_MAX_QUEUE_DEPTH              0
    NVME_EMULATION_NUM_MSIX                     0
    NVME_EMULATION_NUM_PF                       1
    NVME_EMULATION_NUM_VF                       0
    NVME_EMULATION_REVISION_ID                  0
    NVME_EMULATION_SUBSYSTEM_ID                 0
    NVME_EMULATION_SUBSYSTEM_VENDOR_ID          0
    NVME_EMULATION_VENDOR_ID                    5555
    P2P_ORDERING_MODE                           DEVICE_DEFAULT(0)
    PARTIAL_RESET_EN                            False(0)
    PCC_INT_EN                                  False(0)
    PCC_INT_NP_RTT_DATA_MODE                    RTT_V0(64)
    PCC_INT_NP_RTT_DSCP_EN                      False(0)
    PCC_INT_NP_RTT_DSCP                         26
    PCC_INT_SYSTEM_RTT                          0
    PCIE_CREDIT_TOKEN_TIMEOUT                   0
    PCIE_IN_BAND_VDM_DISABLE                    False(0)
    PCIE_SMBUS_DISABLE                          False(0)
    PCI_ATOMIC_MODE                             PCI_ATOMIC_DISABLED_EXT_ATOMIC_ENABLED(0)
    PCI_DOWNSTREAM_PORT_OWNER                   Array\[0..15\]
    PCI_SWITCH_EMULATION_ENABLE                 False(0)
    PCI_SWITCH_EMULATION_NUM_PORT               0
    PCI_WR_ORDERING                             per_mkey(0)
    PER_PF_NUM_SF                               True(1)
    PF_BAR2_ENABLE                              False(0)
    PF_BAR2_SIZE                                0
    PF_DEVICE_ID_ENABLE                         False(0)
    PF_DEVICE_ID                                41686
    PF_LOG_BAR_SIZE                             5
    PF_NUM_OF_VF                                0
    PF_NUM_OF_VF_VALID                          True(1)
    PF_NUM_PF_MSIX                              63
    PF_NUM_PF_MSIX_VALID                        False(0)
    PF_SD_GROUP                                 0
    PF_SF_BAR_SIZE                              10
    PF_TOTAL_SF                                 0
    PHY_AUTO_NEG_P1                             DEVICE_DEFAULT(0)
    PHY_AUTO_NEG_P2                             DEVICE_DEFAULT(0)
    PHY_COUNT_LINK_UP_DELAY                     DELAY_NONE(0)
    PHY_FEC_OVERRIDE_P1                         DEVICE_DEFAULT(0)
    PHY_FEC_OVERRIDE_P2                         DEVICE_DEFAULT(0)
    PHY_RATE_MASK_OVERRIDE_P1                   False(0)
    PHY_RATE_MASK_OVERRIDE_P2                   False(0)
    PLDM_FW_UPDATE_DISABLE                      False(0)
    PORT_OWNER                                  True(1)
    PRIO_TAG_REQUIRED_EN                        False(0)
    PROG_PARSE_GRAPH                            False(0)
    QOS_TRUST_STATE_P1                          TRUST_PCP(1)
    QOS_TRUST_STATE_P2                          TRUST_PCP(1)
    RATE_REDUCE_MONITOR_PERIOD_P1               4
    RATE_REDUCE_MONITOR_PERIOD_P2               4
    RATE_TO_SET_ON_FIRST_CNP_P1                 0
    RATE_TO_SET_ON_FIRST_CNP_P2                 0
    RBT_DISABLE                                 False(0)
    RDE_DISABLE                                 False(0)
    RDMA_SELECTIVE_REPEAT_EN                    False(0)
    REAL_TIME_CLOCK_ENABLE                      False(0)
    RENEG_ON_CHANGE                             True(1)
    RESET_WITH_HOST_ON_ERRORS                   False(0)
    ROCE_ADAPTIVE_ROUTING_EN                    False(0)
    ROCE_CC_CNP_MODERATION_P1                   DEVICE_DEFAULT(0)
    ROCE_CC_CNP_MODERATION_P2                   DEVICE_DEFAULT(0)
    ROCE_CC_DCQCN_COMPATIBILITY_MODE            DEVICE_DEFAULT(0)
    ROCE_CC_LEGACY_DCQCN                        False(0)
    ROCE_CC_PRIO_MASK_P1                        255
    ROCE_CC_PRIO_MASK_P2                        255
    ROCE_CONTROL                                ROCE_ENABLE(2)
    ROCE_NEXT_PROTOCOL                          254
    ROCE_RTT_RESP_DSCP_MODE_P1                  DEVICE_DEFAULT(0)
    ROCE_RTT_RESP_DSCP_MODE_P2                  DEVICE_DEFAULT(0)
    ROCE_RTT_RESP_DSCP_P1                       0
    ROCE_RTT_RESP_DSCP_P2                       0
    RPG_AI_RATE_P1                              5
    RPG_AI_RATE_P2                              5
    RPG_BYTE_RESET_P1                           32767
    RPG_BYTE_RESET_P2                           32767
    RPG_GD_P1                                   11
    RPG_GD_P2                                   11
    RPG_HAI_RATE_P1                             50
    RPG_HAI_RATE_P2                             50
    RPG_MAX_RATE_P1                             0
    RPG_MAX_RATE_P2                             0
    RPG_MIN_DEC_FAC_P1                          50
    RPG_MIN_DEC_FAC_P2                          50
    RPG_MIN_RATE_P1                             1
    RPG_MIN_RATE_P2                             1
    RPG_THRESHOLD_P1                            1
    RPG_THRESHOLD_P2                            1
    RPG_TIME_RESET_P1                           300
    RPG_TIME_RESET_P2                           300
    RT_PPS_ENABLED_ON_POWERUP                   False(0)
    SAFE_MODE_ENABLE                            False(0)
    SILENT_MODE                                 False(0)
    SM_DISABLE                                  False(0)
    SRIOV_EN                                    False(0)
    SRIOV_IB_ROUTING_MODE_P1                    LID(1)
    SRIOV_IB_ROUTING_MODE_P2                    LID(1)
    STEERING_CACHE_REFRESH                      0
    STRICT_VF_MSIX_NUM                          False(0)
    SWITCH_COMPT_FEATURE_MASK                   0x0(0)
    TLS_OPTIMIZE                                False(0)
    TRACER_ENABLE                               True(1)
    TUNNEL_ECN_COPY_DISABLE                     False(0)
    TUNNEL_IP_PROTO_ENTROPY_DISABLE             False(0)
    TX_PCI_DATA_FETCH_LATENCY                   40
    TX_SCHEDULER_BURST                          0
    TX_SCHEDULER_FWS_REACTIVITY                 DIRECT(1)
    TX_SCHEDULER_LOCALITY_FACTOR                0
    TX_SCHEDULER_LOCALITY_MODE                  DEVICE_DEFAULT(0)
    UCTX_EN                                     True(1)
    UEFI_HII_EN                                 True(1)
    UEFI_LOGS                                   DISABLED(0)
    UNKNOWN_UPLINK_MAC_FLOOD_P1                 False(0)
    UNKNOWN_UPLINK_MAC_FLOOD_P2                 False(0)
    UPT_EMULATION_ENABLE                        True(1)
    USER_PROGRAMMABLE_CC                        False(0)
    VF_LOG_BAR_SIZE                             1
    VF_MIGRATION_MODE                           DEVICE_DEFAULT(0)
    VF_NODNIC_ENABLE                            False(0)
    VF_VPD_ENABLE                               False(0)
    VIRTIO_BLK_EMULATION_ENABLE                 False(0)
    VIRTIO_BLK_EMULATION_NUM_MSIX               2
    VIRTIO_BLK_EMULATION_NUM_PF                 0
    VIRTIO_BLK_EMULATION_NUM_VF                 0
    VIRTIO_BLK_EMULATION_PF_PCI_LAYOUT          VIRTIO_1_X(0)
    VIRTIO_BLK_EMULATION_SUBSYSTEM_ID           4162
    VIRTIO_BLK_EMULATION_VF_PCI_LAYOUT          VIRTIO_1_X(0)
    VIRTIO_BLK_EMU_SUBS_VENDOR_ID               6900
    VIRTIO_EMULATION_HOTPLUG_TRANS              False(0)
    VIRTIO_NET_EMULATION_ENABLE                 False(0)
    VIRTIO_NET_EMULATION_NUM_MSIX               2
    VIRTIO_NET_EMULATION_NUM_PF                 0
    VIRTIO_NET_EMULATION_NUM_VF                 0
    VIRTIO_NET_EMULATION_PF_PCI_LAYOUT          VIRTIO_1_X(0)
    VIRTIO_NET_EMULATION_SUBSYSTEM_ID           4161
    VIRTIO_NET_EMULATION_VF_PCI_LAYOUT          VIRTIO_1_X(0)
    VIRTIO_NET_EMU_SUBSYSTEM_VENDOR_ID          6900
    VL15_BUFFER_SIZE_P1                         0
    VL15_BUFFER_SIZE_P2                         0
    VL_BUFFER_ALLOCATION_P1                     FULL_DYNAMIC(1)
    VL_BUFFER_ALLOCATION_P2                     FULL_DYNAMIC(1)
    VL_ISOLATION_MODE_P1                        DEVICE_DEFAULT(0)
    VL_ISOLATION_MODE_P2                        DEVICE_DEFAULT(0)
    ZERO_TOUCH_TUNING_ENABLE                    False(0)
These settings enable both ports in ESXi for use with a vSwitch and hardware offload when using OVS.
