Bluefiled smartnic mode, x86 host pf(p4p1) ping nic pf representor(pf0hpf) fail, Destination Host Unreachable
I following the post “BlueField-SmartNIC-Modes”, change my bluefield to smartnic mode. After that, i configure ip to x86 host side pf interface(p4p1, 192.168.200.1/24) and nic side pf representor(pf0hpf, 192.168.200.2/24). In x86 host, i ping 192.168.200.2 failure, error msg “Destination Host Unreachable”. I check the system’s route table, it is correct. Did i missed some important step?
x86 host side:
mlxfwmanager -d /dev/mst/mt41682_pciconf0 --query
Querying Mellanox devices firmware …
Device #1:
Device Type: BlueField
Part Number: MBF1M332A-ASNAx_Ax
Description: BlueField™ SmartNIC 25GbE dual-port SFP28; PCIe Gen3.0/4.0 x8; BlueField™ G-Series 16 Cores; Crypto disabled; 16GB on-board DDR; HHHL; ROHS R6
PSID: MT_0000000317
PCI Device Name: /dev/mst/mt41682_pciconf0
Base GUID: 0c42a10300d72c8c
Base MAC: 0c42a1d72c8c
Versions: Current Available
FW 18.27.2008 18.26.1040
NVMe 20.1.0003 20.1.0003
PXE 3.5.0901 3.5.0803
UEFI 14.20.0022 14.19.0014
Status: Up to date
ip addr show dev p4p1
11: p4p1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 0c:42:a1:d7:2c:8c brd ff:ff:ff:ff:ff:ff
inet 192.168.200.1/24 scope global p4p1
valid_lft forever preferred_lft forever
ip route get 192.168.200.2
192.168.200.2 dev p4p1 src 192.168.200.1
cache
ping 192.168.200.2
PING 192.168.200.2 (192.168.200.2) 56(84) bytes of data.
From 192.168.200.1 icmp_seq=1 Destination Host Unreachable
From 192.168.200.1 icmp_seq=2 Destination Host Unreachable
From 192.168.200.1 icmp_seq=3 Destination Host Unreachable
snic side:
ip a show pf0hpf
8: pf0hpf: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether fa:09:48:1d:3a:21 brd ff:ff:ff:ff:ff:ff
inet 192.168.200.2/24 scope global pf0hpf
ip route get 192.168.200.1
192.168.200.1 dev pf0hpf src 192.168.200.2 uid 0
cache
  1. Please avoid use ip xxx.xxx.xxx.1, it is default route gw ip.
  2. On same linux server it is nature that use same subnet ip on 2 port will not work, since linux kernel route table limit, you can check on kernel.org or Redhat website.
You can set different subnet ip on 2 port and correct iproute rules.
