Connectivity Issues between Two NIC Ports on the Same Machine
Description:
I am experiencing connectivity issues between two network interface cards (NICs) on the same server, and I’m unable to establish a ping between them. I’m seeking assistance to resolve this issue.
Environment:
  • Operating System: Ubuntu 20.04.5 LTS
  • NIC 1: enp130s0np0 (192.168.3.1/24)
  • NIC 2: enp3s0f0np0 (192.168.3.2/24)
  • NIC 2 Type: Nvidia Bluefield (with embedded CPU configuration)
  • Both NICs are directly connected via an Ethernet cable.
$ ip route
default via 10.190.172.1 dev eno1 proto static
default via 10.190.172.1 dev eno1 proto dhcp src 10.190.172.107 metric 100
10.190.172.0/22 dev eno1 proto kernel scope link src 10.190.174.31
10.190.172.1 dev eno1 proto dhcp scope link src 10.190.172.107 metric 100
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
192.168.3.0/24 dev enp130s0np0 proto kernel scope link src 192.168.3.1
192.168.3.0/24 dev enp3s0f1np1 proto kernel scope link src 192.168.3.3
192.168.3.0/24 dev enp3s0f0np0 proto kernel scope link src 192.168.3.2
192.168.100.0/24 dev tmfifo_net0 proto kernel scope link src 192.168.100.1
192.168.122.0/24 dev virbr0 proto kernel scope link src 192.168.122.1 linkdown
Issue Details:
Despite the direct connection, attempts to ping from one NIC to the other result in “Destination Host Unreachable” errors from both ends.
  • Ping from enp3s0f0np0 to enp130s0np0:
PING 192.168.3.1 (192.168.3.1) from 192.168.3.2 enp3s0f0np0: 56(84) bytes of data.
From 192.168.3.2 icmp_seq=1 Destination Host Unreachable
  • Ping from enp130s0np0 to enp3s0f0np0:
PING 192.168.3.2 (192.168.3.2) from 192.168.3.1 enp130s0np0: 56(84) bytes of data.
From 192.168.3.1 icmp_seq=1 Destination Host Unreachable
Configuration of NIC 2 (Nvidia Bluefield):
  • Mode: Embedded PCU
  • Relevant configurations that might affect connectivity are provided below:
HOST_CHAINING_MODE: DISABLED
INTERNAL_CPU_MODEL: EMBEDDED_CPU
SRIOV_EN: True
NUM_OF_VFS: 10
Request:
I am looking for guidance on why these connectivity issues might be occurring and how to resolve them. I suspect there might be a configuration or hardware-related issue, especially concerning the special properties of the Nvidia Bluefield card in embedded PCU mode.
Thank you in advance for any suggestions or guidance you can provide!
Thanks for your question.
Most likely the issue is not with the Bluefield adapter itself.
Based on the network configuration you shared, there are a few interfaces on the same server, which are configured with addresses in the same subnet 192.168.3.0/24
This configuration may cause various network issues (ARP, routing issues), as the kernel may reply to ARP via wrong interface, and as a result no connectivity.
In this case you may configure a routing table per interface, or just not using same subnet on a few ports on the same server.
Please find the below explanations:
#All the settings are very well documented in below link
#https://access.redhat.com/documentation/en-us/red_hat_enterprise_linux/7/html/kernel_administration_guide/working_with_sysctl_and_kernel_tunables
#default is usually 0
#value 1 is used if there is static source based routing
in order to force ARPs for each interface be answered based on
#whether or not the kernel would route a packet from the ARP’d IP out that interface
sysctl -w net.ipv4.conf.all.arp_filter=1
sysctl -w net.ipv4.conf.default.arp_filter=1
#value 1 or 2 can work, the difference if the subnet is checked as well
sysctl -w net.ipv4.conf.all.arp_ignore=1
sysctl -w net.ipv4.conf.default.arp_ignore=1
#either 1 or 2, 1 works better as value 2 ignores IP addr in src packet
sysctl -w net.ipv4.conf.all.arp_announce=1
sysctl -w net.ipv4.conf.default.arp_announce=1
#rp_filter can be set to 0 or 2, just not 1
sysctl -w net.ipv4.conf.all.rp_filter=2
sysctl -w net.ipv4.conf.default.rp_filter=2
Best Regards,
Anatoly
Thank you very much, Anatoly! I appreciate your detailed advice and will implement these settings to see if they help resolve the issue.
