I was working on Jetson TX2 NX and using rtl8822ce chip for BT and connecting through USB. It is able to scan, pair, and connect but after connected it automatically disconnects within a few seconds.
I am using ‘bluetoothctl’ for connecting with devices.
Is there any way to solve this problem.
commands and output
root@localhost:/home/askc# bluetoothctl
[NEW] Controller 70:66:55:A6:F4:AA BlueZ 5.48 [default]
[NEW] Device 40:74:E0:07:2E:E7 7882--VISN--KOCHI1
Agent registered
[bluetooth]# power on
Changing power on succeeded
[bluetooth]# agent on
Agent is already registered
[bluetooth]# default-agent
Default agent request successful
[bluetooth]# trust 40:74:E0:07:2E:E7
Changing 40:74:E0:07:2E:E7 trust succeeded
[bluetooth]# connect 40:74:E0:07:2E:E7
Attempting to connect to 40:74:E0:07:2E:E7
[CHG] Device 40:74:E0:07:2E:E7 Connected: yes
[CHG] Device 40:74:E0:07:2E:E7 ServicesResolved: yes
Failed to connect: org.bluez.Error.InProgress
[CHG] Device 40:74:E0:07:2E:E7 ServicesResolved: no
[CHG] Device 40:74:E0:07:2E:E7 Connected: no
[bluetooth]#
btmon log
root@localhost:/home/askc# btmon
Bluetooth monitor ver 5.48
= Note: Linux version 4.9.253-tegra (aarch64) 0.197853
= Note: Bluetooth subsystem version 2.22 0.197856
= New Index: 70:66:55:A6:F4:AA (Primary,USB,hci0) [hci0] 0.197858
= Open Index: 70:66:55:A6:F4:AA [hci0] 0.197859
= Index Info: 70:66:55:A6:F4:AA (Realtek Semiconductor Corporation) [hci0] 0.197860
@ MGMT Open: bluetoothd (privileged) version 1.14 {0x0002} 0.197861
@ MGMT Open: bluetoothd (privileged) version 1.14 {0x0001} 0.197862
@ MGMT Open: btmon (privileged) version 1.14 {0x0003} 0.197888
< HCI Command: Create Connection (0x01|0x0005) plen 13 #1 [hci0] 13.839258
Address: 40:74:E0:07:2E:E7 (OUI 40-74-E0)
Packet type: 0xcc18
DM1 may be used
DH1 may be used
DM3 may be used
DH3 may be used
DM5 may be used
DH5 may be used
Page scan repetition mode: R2 (0x02)
Page scan mode: Mandatory (0x00)
Clock offset: 0x0000
Role switch: Allow slave (0x01)
> HCI Event: Command Status (0x0f) plen 4 #2 [hci0] 13.841328
Create Connection (0x01|0x0005) ncmd 2
Status: Success (0x00)
> HCI Event: Role Change (0x12) plen 8 #3 [hci0] 16.743307
Role: Slave (0x01)
> HCI Event: Connect Complete (0x03) plen 11 #4 [hci0] 16.751320
Handle: 2
Link type: ACL (0x01)
Encryption: Disabled (0x00)
< HCI Command: Read Remote Supported Features (0x01|0x001b) plen 2 #5 [hci0] 16.751799
Handle: 2
> HCI Event: Command Status (0x0f) plen 4 #6 [hci0] 16.756285
Read Remote Supported Features (0x01|0x001b) ncmd 2
< HCI Command: Write Scan Enable (0x03|0x001a) plen 1 #7 [hci0] 16.756346
Scan enable: No Scans (0x00)
> HCI Event: Command Complete (0x0e) plen 4 #8 [hci0] 16.758291
Write Scan Enable (0x03|0x001a) ncmd 2
> HCI Event: Max Slots Change (0x1b) plen 3 #9 [hci0] 16.760277
Handle: 2
Max slots: 5
> HCI Event: Read Remote Supported Features (0x0b) plen 11 #10 [hci0] 16.765278
Handle: 2
Features: 0xbf 0xfe 0x0f 0xfe 0xdb 0xff 0x7b 0x87
3 slot packets
5 slot packets
Encryption
Slot offset
Timing accuracy
Role switch
Sniff mode
Power control requests
Channel quality driven data rate (CQDDR)
SCO link
HV2 packets
HV3 packets
u-law log synchronous data
A-law log synchronous data
CVSD synchronous data
Paging parameter negotiation
Power control
Transparent synchronous data
Enhanced Data Rate ACL 2 Mbps mode
Enhanced Data Rate ACL 3 Mbps mode
Enhanced inquiry scan
Interlaced inquiry scan
Interlaced page scan
RSSI with inquiry results
Extended SCO link (EV3 packets)
EV4 packets
EV5 packets
AFH capable slave
AFH classification slave
LE Supported (Controller)
3-slot Enhanced Data Rate ACL packets
5-slot Enhanced Data Rate ACL packets
Sniff subrating
Pause encryption
AFH capable master
AFH classification master
Enhanced Data Rate eSCO 2 Mbps mode
Enhanced Data Rate eSCO 3 Mbps mode
3-slot Enhanced Data Rate eSCO packets
Extended Inquiry Response
Simultaneous LE and BR/EDR (Controller)
Secure Simple Pairing
Encapsulated PDU
Erroneous Data Reporting
Non-flushable Packet Boundary Flag
Link Supervision Timeout Changed Event
Inquiry TX Power Level
Enhanced Power Control
Extended features
< HCI Command: Read Remote Extended Features (0x01|0x001c) plen 3 #11 [hci0] 16.765346
Handle: 2
Page: 1
> HCI Event: Command Status (0x0f) plen 4 #12 [hci0] 16.766306
Read Remote Extended Features (0x01|0x001c) ncmd 2
> HCI Event: Read Remote Extended Features (0x23) plen 13 #13 [hci0] 16.770327
Handle: 2
Page: 1/2
Features: 0x0b 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Secure Simple Pairing (Host Support)
LE Supported (Host)
Secure Connections (Host Support)
< HCI Command: Remote Name Request (0x01|0x0019) plen 10 #14 [hci0] 16.770625
< ACL Data TX: Handle 2 flags 0x00 dlen 10 #15 [hci0] 16.770675
L2CAP: Information Request (0x0a) ident 1 len 2
Type: Extended features supported (0x0002)
> HCI Event: Command Status (0x0f) plen 4 #16 [hci0] 16.772307
Remote Name Request (0x01|0x0019) ncmd 2
> ACL Data RX: Handle 2 flags 0x02 dlen 10 #17 [hci0] 16.772799
< ACL Data TX: Handle 2 flags 0x00 dlen 16 #18 [hci0] 16.772888
L2CAP: Information Response (0x0b) ident 1 len 8
Result: Success (0x0000)
Features: 0x000002b8
Enhanced Retransmission Mode
Streaming Mode
FCS Option
Fixed Channels
Unicast Connectionless Data Reception
> HCI Event: Number of Completed Packets (0x13) plen 5 #19 [hci0] 16.774296
Num handles: 1
Handle: 2
Count: 1
> ACL Data RX: Handle 2 flags 0x02 dlen 16 #20 [hci0] 16.777663
Streaming Mode
FCS Option
Fixed Channels
< ACL Data TX: Handle 2 flags 0x00 dlen 10 #21 [hci0] 16.777820
L2CAP: Information Request (0x0a) ident 2 len 2
Type: Fixed channels supported (0x0003)
> HCI Event: Number of Completed Packets (0x13) plen 5 #22 [hci0] 16.779287
Num handles: 1
Handle: 2
Count: 1
> ACL Data RX: Handle 2 flags 0x02 dlen 10 #23 [hci0] 16.782725
< ACL Data TX: Handle 2 flags 0x00 dlen 20 #24 [hci0] 16.782853
L2CAP: Information Response (0x0b) ident 2 len 12
Channels: 0x0000000000000006
L2CAP Signaling (BR/EDR)
Connectionless reception
> ACL Data RX: Handle 2 flags 0x02 dlen 20 #25 [hci0] 16.784044
Channels: 0x0000000000000086
Security Manager (BR/EDR)
< ACL Data TX: Handle 2 flags 0x00 dlen 12 #26 [hci0] 16.784630
L2CAP: Connection Request (0x02) ident 3 len 4
PSM: 1 (0x0001)
Source CID: 64
> ACL Data RX: Handle 2 flags 0x02 dlen 16 #27 [hci0] 16.790202
L2CAP: Connection Response (0x03) ident 3 len 8
Destination CID: 64
Source CID: 64
Result: Connection successful (0x0000)
Status: No further information available (0x0000)
< ACL Data TX: Handle 2 flags 0x00 dlen 23 #28 [hci0] 16.790421
L2CAP: Configure Request (0x04) ident 4 len 15
Destination CID: 64
Flags: 0x0000
Option: Retransmission and Flow Control (0x04) [mandatory]
Mode: Basic (0x00)
TX window size: 0
Max transmit: 0
Retransmission timeout: 0
Monitor timeout: 0
Maximum PDU size: 0
> ACL Data RX: Handle 2 flags 0x02 dlen 23 #29 [hci0] 16.791555
L2CAP: Configure Request (0x04) ident 3 len 15
Destination CID: 64
Flags: 0x0000
Mode: Basic (0x00)
TX window size: 0
Max transmit: 0
Monitor timeout: 0
Maximum PDU size: 0
< ACL Data TX: Handle 2 flags 0x00 dlen 18 #30 [hci0] 16.791683
L2CAP: Configure Response (0x05) ident 3 len 10
Source CID: 64
Flags: 0x0000
Option: Maximum Transmission Unit (0x01) [mandatory]
MTU: 672
> ACL Data RX: Handle 2 flags 0x02 dlen 18 #31 [hci0] 16.793998
L2CAP: Configure Response (0x05) ident 4 len 10
Source CID: 64
Flags: 0x0000
MTU: 672
< ACL Data TX: Handle 2 flags 0x00 dlen 24 #32 [hci0] 16.794720
Channel: 64 len 20 [PSM 1 mode 0] {chan 0}
SDP: Service Search Attribute Request (0x06) tid 0 len 15
Search pattern: [len 5]
Sequence (6) with 3 bytes [8 extra bits] len 5
UUID (3) with 2 bytes [0 extra bits] len 3
L2CAP (0x0100)
Max record count: 65535
Attribute list: [len 7]
Sequence (6) with 5 bytes [8 extra bits] len 7
Unsigned Integer (1) with 4 bytes [0 extra bits] len 5
0x0000ffff
Continuation state: 0
> HCI Event: Remote Name Req Complete (0x07) plen 255 #33 [hci0] 16.798290
@ MGMT Event: Device Connected (0x000b) plen 33 {0x0003} [hci0] 16.798403
BR/EDR Address: 40:74:E0:07:2E:E7 (OUI 40-74-E0)
Flags: 0x00000000
Data length: 20
Name (complete): 7882--VISN--KOCHI1
@ MGMT Event: Device Connected (0x000b) plen 33 {0x0002} [hci0] 16.798403
Flags: 0x00000000
Data length: 20
@ MGMT Event: Device Connected (0x000b) plen 33 {0x0001} [hci0] 16.798403
Flags: 0x00000000
Data length: 20
> HCI Event: Number of Completed Packets (0x13) plen 5 #34 [hci0] 16.799386
Num handles: 1
Handle: 2
Count: 1
> HCI Event: Number of Completed Packets (0x13) plen 5 #35 [hci0] 16.800301
Num handles: 1
Handle: 2
Count: 1
> HCI Event: Number of Completed Packets (0x13) plen 5 #36 [hci0] 16.801325
Num handles: 1
Handle: 2
Count: 1
> HCI Event: Number of Completed Packets (0x13) plen 5 #37 [hci0] 16.802300
Num handles: 1
Handle: 2
Count: 1
> ACL Data RX: Handle 2 flags 0x02 dlen 676 #38 [hci0] 16.803030
Channel: 64 len 672 [PSM 1 mode 0] {chan 0}
SDP: Service Search Attribute Response (0x07) tid 0 len 667
Attribute bytes: 656
Continuation state: 8
23 98 ad 61 90 02 00 00 #..a....
> HCI Event: Number of Completed Packets (0x13) plen 5 #39 [hci0] 16.803278
Num handles: 1
Handle: 2
Count: 1
> HCI Event: Number of Completed Packets (0x13) plen 5 #40 [hci0] 16.804285
Num handles: 1
Handle: 2
Count: 1
< ACL Data TX: Handle 2 flags 0x00 dlen 32 #41 [hci0] 16.806517
Channel: 64 len 28 [PSM 1 mode 0] {chan 0}
SDP: Service Search Attribute Request (0x06) tid 1 len 23
L2CAP (0x0100)
0x0000ffff
> HCI Event: Number of Completed Packets (0x13) plen 5 #42 [hci0] 16.809290
Num handles: 1
Handle: 2
Count: 1
> ACL Data RX: Handle 2 flags 0x02 dlen 676 #43 [hci0] 16.814058
SDP: Service Search Attribute Response (0x07) tid 1 len 667
23 98 ad 61 20 05 00 00 #..a ...
< ACL Data TX: Handle 2 flags 0x00 dlen 32 #44 [hci0] 16.814293
SDP: Service Search Attribute Request (0x06) tid 2 len 23
L2CAP (0x0100)
0x0000ffff
> HCI Event: Number of Completed Packets (0x13) plen 5 #45 [hci0] 16.817274
Num handles: 1
Handle: 2
Count: 1
> ACL Data RX: Handle 2 flags 0x02 dlen 162 #46 [hci0] 16.819887
Channel: 64 len 158 [PSM 1 mode 0] {chan 0}
SDP: Service Search Attribute Response (0x07) tid 2 len 153
Attribute bytes: 150
Combined attribute bytes: 1462
Attribute list: [len 163] {position 0}
Attribute: Service Record Handle (0x0000) [len 2]
0x00010001
Attribute: Service Class ID List (0x0001) [len 2]
Generic Access Profile (0x1800)
Attribute: Protocol Descriptor List (0x0004) [len 2]
Sequence (6) with 6 bytes [8 extra bits] len 8
L2CAP (0x0100)
Unsigned Integer (1) with 2 bytes [0 extra bits] len 3
0x001f
Sequence (6) with 9 bytes [8 extra bits] len 11
ATT (0x0007)
0x0001
0x0005
Attribute: Browse Group List (0x0005) [len 2]
Public Browse Root (0x1002)
Attribute: Documentation URL (0x000a) [len 2]
http://www.bluez.org/ [len 21]
Attribute: Client Executable URL (0x000b) [len 2]
Attribute: Icon URL (0x000c) [len 2]
Attribute: Unknown (0x0100) [len 2]
Generic Access Profile [len 22]
Attribute: Unknown (0x0102) [len 2]
BlueZ [len 5]
Attribute list: [len 88] {position 1}
0x00010002
Generic Attribute Profile (0x1801)
L2CAP (0x0100)
0x001f
ATT (0x0007)
0x0006
0x000f
Generic Attribute Profile [len 25]
BlueZ [len 5]
Attribute list: [len 81] {position 2}
0x00010003
Device Information (0x180a)
L2CAP (0x0100)
0x001f
ATT (0x0007)
0x0010
0x0012
Device Information [len 18]
BlueZ [len 5]
Attribute list: [len 103] {position 3}
0x00010004
A/V Remote Control (0x110e)
A/V Remote Control Controller (0x110f)
L2CAP (0x0100)
0x0017
AVCTP (0x0017)
0x0103
Attribute: Bluetooth Profile Descriptor List (0x0009) [len 2]
0x0106
Attribute: Additional Protocol Descriptor List (0x000d) [len 2]
Sequence (6) with 16 bytes [8 extra bits] len 18
L2CAP (0x0100)
0x001b
AVCTP (0x0017)
0x0103
AVRCP CT [len 8]
Attribute: Unknown (0x0311) [len 2]
0x004f
Attribute list: [len 100] {position 4}
0x00010005
A/V Remote Control Target (0x110c)
L2CAP (0x0100)
0x0017
AVCTP (0x0017)
0x0103
0x0105
L2CAP (0x0100)
0x001b
AVCTP (0x0017)
0x0103
AVRCP TG [len 8]
0x005f
Attribute list: [len 83] {position 5}
0x00010006
Headset AG (0x1112)
Generic Audio (0x1203)
L2CAP (0x0100)
RFCOMM (0x0003)
Unsigned Integer (1) with 1 byte [0 extra bits] len 2
0x0c
Headset (0x1108)
0x0102
Headset Voice gateway [len 21]
Attribute list: [len 82] {position 6}
0x00010007
Headset (0x1108)
Headset HS (0x1131)
L2CAP (0x0100)
RFCOMM (0x0003)
0x03
Headset (0x1108)
0x0102
Headset unit [len 12]
Attribute: Unknown (0x0302) [len 2]
false
Attribute list: [len 98] {position 7}
0x00010008
Message Notification Server (0x1133)
L2CAP (0x0100)
RFCOMM (0x0003)
0x11
OBEX (0x0008)
Message Access Profile (0x1134)
0x0102
Message Notification [len 20]
Attribute: Unknown (0x0200) [len 2]
0x1001
Attribute: Unknown (0x0317) [len 2]
0x0000007f
Attribute list: [len 102] {position 8}
0x00010009
Message Access Server (0x1132)
L2CAP (0x0100)
RFCOMM (0x0003)
0x10
OBEX (0x0008)
0x0100
Message Access [len 14]
0x1003
Attribute: Unknown (0x0315) [len 2]
0x00
Attribute: Unknown (0x0316) [len 2]
0x0f
0x0000007f
Attribute list: [len 100] {position 9}
0x0001000a
Phonebook Access Server (0x112f)
L2CAP (0x0100)
RFCOMM (0x0003)
0x0f
OBEX (0x0008)
Phonebook Access (0x1130)
0x0101
Phone Book Access [len 17]
0x1005
Attribute: Unknown (0x0314) [len 2]
0x01
0x00000003
Attribute list: [len 86] {position 10}
0x0001000b
IrMC Sync (0x1104)
L2CAP (0x0100)
RFCOMM (0x0003)
0x0e
OBEX (0x0008)
IrMC Sync (0x1104)
0x0100
Synchronization [len 15]
Attribute: Unknown (0x0301) [len 2]
0x01
Attribute list: [len 83] {position 11}
0x0001000c
OBEX File Transfer (0x1106)
L2CAP (0x0100)
RFCOMM (0x0003)
0x0a
OBEX (0x0008)
0x0102
File Transfer [len 13]
0x1007
Attribute list: [len 100] {position 12}
0x0001000d
OBEX Object Push (0x1105)
L2CAP (0x0100)
RFCOMM (0x0003)
0x09
OBEX (0x0008)
0x0102
Object Push [len 11]
0x1009
Attribute: Unknown (0x0303) [len 2]
0x01
0x02
0x03
0x04
0x05
0x06
0xff
Attribute list: [len 79] {position 13}
0x0001000e
Audio Sink (0x110b)
L2CAP (0x0100)
0x0019
AVDTP (0x0019)
0x0103
Advanced Audio Distribution (0x110d)
0x0103
Audio Sink [len 10]
0x000f
Attribute list: [len 81] {position 14}
0x0001000f
Audio Source (0x110a)
L2CAP (0x0100)
0x0019
AVDTP (0x0019)
0x0103
0x0103
Audio Source [len 12]
0x000f
< ACL Data TX: Handle 2 flags 0x00 dlen 24 #47 [hci0] 16.833605
SDP: Service Search Attribute Request (0x06) tid 3 len 15
PnP Information (0x1200)
0x0000ffff
> HCI Event: Number of Completed Packets (0x13) plen 5 #48 [hci0] 16.844286
Num handles: 1
Handle: 2
Count: 1
> ACL Data RX: Handle 2 flags 0x02 dlen 88 #49 [hci0] 16.847348
Channel: 64 len 84 [PSM 1 mode 0] {chan 0}
SDP: Service Search Attribute Response (0x07) tid 3 len 79
Attribute bytes: 76
Attribute list: [len 72] {position 0}
0x00010000
0x0103
0x0103
Attribute: Unknown (0x0201) [len 2]
0x1d6b
Attribute: Unknown (0x0202) [len 2]
0x0246
Attribute: Unknown (0x0203) [len 2]
0x053a
Attribute: Unknown (0x0204) [len 2]
true
Attribute: Unknown (0x0205) [len 2]
0x0002
< ACL Data TX: Handle 2 flags 0x00 dlen 12 #50 [hci0] 19.197253
L2CAP: Disconnection Request (0x06) ident 5 len 4
Destination CID: 64
Source CID: 64
> HCI Event: Number of Completed Packets (0x13) plen 5 #51 [hci0] 19.217302
Num handles: 1
Handle: 2
Count: 1
> ACL Data RX: Handle 2 flags 0x02 dlen 12 #52 [hci0] 19.300202
L2CAP: Disconnection Response (0x07) ident 5 len 4
Destination CID: 64
Source CID: 64
< HCI Command: Disconnect (0x01|0x0006) plen 3 #53 [hci0] 21.302398
Handle: 2
Reason: Remote User Terminated Connection (0x13)
> HCI Event: Command Status (0x0f) plen 4 #54 [hci0] 21.303300
Disconnect (0x01|0x0006) ncmd 2
> HCI Event: Disconnect Complete (0x05) plen 4 #55 [hci0] 21.393318
Handle: 2
Reason: Connection Terminated By Local Host (0x16)
@ MGMT Event: Device Disconnected (0x000c) plen 8 {0x0003} [hci0] 21.393402
Reason: Connection terminated by local host (0x02)
@ MGMT Event: Device Disconnected (0x000c) plen 8 {0x0002} [hci0] 21.393402
@ MGMT Event: Device Disconnected (0x000c) plen 8 {0x0001} [hci0] 21.393402
< HCI Command: Write Scan Enable (0x03|0x001a) plen 1 #56 [hci0] 21.422676
Scan enable: Page Scan (0x02)
> HCI Event: Command Complete (0x0e) plen 4 #57 [hci0] 21.424277
