I have a Bluetooth headset that can connect and does properly support audio playback but the microphone does not work(having verified it is in good working order and not muted). I have a USB headset that does properly support audio playback and microphone input. I have tried to use the sound PulseAudio Volume Control to ensure I have the correct input source selected. The Bluetooth microphone only shows as a Monitor but not hardware input device. What is the difference?
I saw in one other older post that Bluetooth microphone may not be supported but have seen other users of Bluetooth audio not mention it. Can a definitive answer be given to the question: Can the Jetson Nano running a current release of the SD Card image use an audio input on a Bluetooth connected headset?
Thank you
