Audio bluetooth not working please help ! (speaker and headset)
Hello every body ! I’m new user Jetson Nano.
I just install Intel 8265NGW success and wifi good working. Icon bluetooth enable.
When I connect my headset bluetooth, Jetson Nano otification successful connection.
But the sound still doesn’t come from speakers and headset.
Thank you for read !!
Hi dangtrunghieuspt,
Please refer to this thread if can help: [url]https://devtalk.nvidia.com/default/topic/1052124/jetson-nano/nano-bluetooth/post/5351416/#5351416[/url]
Thank you very much !
But my problem still can not solve by this method.
When I run
sudo apt-get install pulse-audio-module-bluetooth
Terminal notification:
Unable to locate package pulse-audio-module-bluetooth
I had try remove
ExecStart=/usr/lib/bluetooth/bluetoothd -d --noplugin=audio,a2dp,avrcp
And replace by:
ExecStart=/usr/lib/bluetooth/bluetoothd -d --noplugin=audio,avrcp
And then I reboot Jetson Nano, I try connect my headset and speaker bluetooth but it still not working !
Hic hic !!
You must use the correct name:
apt-get install pulseaudio-module-bluetooth
Already documented here - Enabling Bluetooth Audio — Jetson Linux<br/>Developer Guide 34.1 documentation
  1. Navigate to this file:
/lib/systemd/system/bluetooth.service.d/nv-bluetooth-service.conf
  1. Use a text editor to change this line:
To this:
(That is, delete the --noplugin option and all of its values.)
  1. Enter these commands to update the apt-get package list and install the pulse audio package:
$ sudo apt-get update $ sudo apt-get install pulseaudio-module-bluetooth
  1. Enter this command to reboot the NVIDIA Jetson device:
$ sudo reboot
  1. When the reboot is complete, pair and connect any Bluetooth headset.
