Boot failed
I have same issue with this topic
wonder to know is it relate to this known issue in 38.4 release note?
To confirm the issue: does the device boot normally when the HDMI cable is unplugged?
Yes, it can boot normally without HDMI plugged
  • What is your bsp version?
  • Do you use the custom carrier board or the developer kit?
jp 7.1
developer kit
I just want to clarified this known issue if it is related.
To explain with our customer
HI,
Thus,
What is your current EMC clock frequency?
Did you change it, so it is not the Fmax value?
I didn’t modify it
It is set by nvidia
and it is 4226Mhx now
HI,
Could you upgrade to the latest bsp like 7.2.1 to do the cross check?
I have check with 7.2.1 release note
It seems to have some workarounds on orin platforms
But our customer use 7.1 with thor
Even if the issue is solved on 7.2.1, they won’t upgrade to 7.2.1 due to their project schedules
So, please just focus on 7.1
If there’s no support on 7.1, then you can close the issue
