In jetpack 5.1.2, I managed to enable HDMI and disable DP by using p3509-a02+p3767-0000.conf, it turns out the erro like attached file occured during bootup. While it is perfectly fine when I used jetpack 5.1.1.
I appreciate the time you spend to investigate that, thanks.
bootup_log_orin_nx_jetpack5-1-2.txt (56.5 KB)
For Orin series, we suggest use DP output. There is deviation between Orin NX and Xavier NX modules as mentioned in
https://developer.nvidia.com/embedded/faq#jetson-compatibility
We would suggest use Orin NX module + Orin Nano carrier board. It may not work properly in Orin NX module + Xavier NX carrier board.
Thanks for your response. Does that mean currently Jetpack 5.1.2 only support DP for Orin NX? If that is the case, is there a plan to make it work for HDMI in the near future?
You are asking a known issue on rel-35.4.1. Please refer to
