I am using jetpack 5.1.2 and flashing a Orin NX with this command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg" --network usb0 p3509-a02+p3767-0000 external
Before using jetpack 5.1.2 I was using JetPack 5.1.1, and the same command to flash the board, and it works correctly, but now using 5.1.2 after the automatic logging is printed these messages:
Ubuntu 20.04.6 LTS nvidia-machine ttyTCU0
nvidia-machine login: nvidia (automatic login)
Welcome to Ubuntu 20.04.6 LTS (GNU/Linux 5.10.120-tegra aarch64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
Expanded Security Maintenance for Applications is not enabled.
111 updates can be applied immediately.
81 of these updates are standard security updates.
To see these additional updates run: apt list --upgradable
Enable ESM Apps to receive additional future security updates.
See https://ubuntu.com/esm or run: sudo pro status
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
nvidia@nvidia-machine:~$ [ 17.834993] CPU:0, Error: dce-fabric@0xde00000, irq=28
[ 17.842929] **************************************
[ 17.847854] CPU:0, Error:dce-fabric, Errmon:2
[ 17.852340] Error Code : SLAVE_ERR
[ 17.856199] Overflow : Multiple SLAVE_ERR
[ 17.860685]
[ 17.862218] Error Code : SLAVE_ERR
[ 17.866083] MASTER_ID : DCE
[ 17.869313] Address : 0x2212000
[ 17.872903] Cache : 0x1 -- Bufferable
[ 17.877201] Protection : 0x3 -- Privileged, Non-Secure, Data Access
[ 17.884008] Access_Type : Read
[ 17.887499] Access_ID : 0x0
[ 17.887501] Fabric : dce-fabric
[ 17.894305] Slave_Id : 0x3b
[ 17.897531] Burst_length : 0x0
[ 17.901027] Burst_type : 0x1
[ 17.904345] Beat_size : 0x2
[ 17.907571] VQC : 0x0
[ 17.910354] GRPSEC : 0x3f
[ 17.913406] FALCONSEC : 0x0
I am using Orin Nano devkit with a Orin NX SOC.
Does someone know what could be the cause of the problem?
Thanks in advance.
