Orin nx 8G flash failure
host: ubuntu22.04, JetPack 6.1
按以下操作步骤
1.toolchain
$ mkdir $HOME/l4t-gcc
$ cd $HOME/l4t-gcc
$ tar -xf <toolchain_archive>
$ sudo apt install build-essential bc
2.解压
$tar -xvf Jetson_Linux_R36.4.0_aarch64.tbz2
$ tar -xf public_sources.tbz2 -C Linux_for_Tegra/..
$ cd Linux_for_Tegra/source
$ tar -xf kernel_src.tbz2
$ tar -xf kernel_oot_modules_src.tbz2
$ tar -xf nvidia_kernel_display_driver_source.tbz2
$ cd ../../
$ tar -xf Tegra_Linux_Sample-Root-Filesystem_R36.4.0_aarch64.tbz2 -C Linux_for_Tegra/rootfs/
3.编译
$ ./generic_rt_build.sh “enable”
$ export CROSS_COMPILE=/home/wel/l4t-gcc/aarch64–glibc–stable-2022.08-1/bin/aarch64-buildroot-linux-gnu-
$ make -C kernel
$ export INSTALL_MOD_PATH=/home/wel/nvidia/Linux_for_Tegra/rootfs/
$ sudo -E make install -C kernel
$ cp kernel/kernel-jammy-src/arch/arm64/boot/Image
/Linux_for_Tegra/kernel/Image
$ export IGNORE_PREEMPT_RT_PRESENCE=1
$ export CROSS_COMPILE=/bin/aarch64-buildroot-linux-gnu-
$ export KERNEL_HEADERS=/home/wel/nvidia/Linux_for_Tegra/source/kernel/kernel-jammy-src
$ make modules
$ sudo -E make modules_install
$ cd /Linux_for_Tegra
$ sudo ./tools/l4t_update_initrd.sh
$ make dtbs
$ cp kernel-devicetree/generic-dts/dtbs/* /Linux_for_Tegra/kernel/dtb/
4.烧录
$ sudo ./tools/l4t_flash_prerequisites.sh
$ sudo ./apply_binaries.sh
$ rm rootfs/etc/systemd/system/default.target
$bash ./nvsdkmanager_flash.sh --storage nvme0n1p1
烧录信息:
Entering RCM boot
[ 0.0248 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0248 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0248 ] rcm boot with presigned binaries
[ 0.0253 ] tegrarcm_v2 --instance 1-6 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0257 ] BR_CID: 0x80012344705DD74C4400000015FF0180
[ 0.0343 ] Sending bct_br
[ 0.0444 ] Sending mb1
[ 0.0451 ] Sending psc_bl1
[ 0.0566 ] Sending bct_mb1
[ 0.0627 ] Generating blob for T23x
[ 0.0644 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0647 ] The number of images in blob is 19
[ 0.0652 ] blobsize is 112011313
[ 0.0654 ] Added binary blob_uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt of size 3300816
[ 0.1270 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[ 0.1282 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[ 0.1289 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[ 0.1295 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279808
[ 0.1301 ] Not supported type: mb2_applet
[ 0.1304 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 440944
[ 0.1314 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.1322 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[ 0.1330 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12070576
[ 0.1421 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.1454 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1027008
[ 0.1468 ] Added binary blob_tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt of size 263488
[ 0.1479 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[ 0.1486 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 415232
[ 0.1491 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.1496 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1887312
[ 0.1505 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.1510 ] Added binary blob_boot0.img of size 88039424
[ 0.2052 ] Added binary blob_tegra234-p3768-0000+p3767-0001-nv.dtb of size 249505
[ 0.2985 ] tegrarcm_v2 --instance 1-6 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.2989 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[ 0.3235 ] Sending bct_mem
[ 0.3327 ] Sending blob
[ 5.6277 ] RCM-boot started
  • Step 3: Start the flashing process *
Waiting for target to boot-up…
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up…
root@wel-22-04-5:/home/wel/nvidia/Linux_for_Tegra#
串口打印信息:
[0075.305] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-22833a33)
I> t234-A01-0-Silicon (0x12347)
I> Boot-mode : RCM BOOT
I> Emulation:
I> Entry timestamp: 0x047d7475
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x273800000, size:0x800000]
I> Task: SE error check
I> Task: Crypto init
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: Set blob address
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: I2C register
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x272e00000
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x272a00000
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x27a000000
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x27d800000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x272f00000
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x273180000
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSI VMON
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x276000000
I> Task: Prepare eeprom data
E> I2C: slave not found in slaves.
E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
E> I2C_DEV: Failed to send register address 0x00000000.
E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
E> eeprom: Retry to read I2C slave device.
E> eeprom: Failed to read I2C slave device
C> Task 0x0 failed (err: 0x1f1e050d)
E> Top caller module: I2C_DEV, error module: I2C, reason: 0x0d, aux_info: 0x05
I> Busy Spin
哪里出了问题?
If this is custom board then please follow the document to disable cvb eeprom read.
已修改这里:
  • cvb_eeprom_read_size = <0x100>
  • cvb_eeprom_read_size = <0x0>
提示烧录成功:
[ 200]: l4t_flash_from_kernel: Successfully flash the qspi
[ 200]: l4t_flash_from_kernel: Flashing success
[ 200]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
Flash is successful
Reboot device
Cleaning up…
Log is saved to Linux_for_Tegra/initrdlog/flash_1-6_0_20250328-154528.log
但启动画面停在nvidia logo这里,串口打印日志如下:
3.425082] hub 2-1.2:1.0: USB hub found
[ 3.425808] hub 2-1.2:1.0: 4 ports detected
[ 3.503644] usb 1-3.1: new high-speed USB device number 5 using tegra-xusb
[ 3.688081] usb 2-1.4: new SuperSpeed USB device number 4 using tegra-xusb
[ 3.791635] usb 1-3.2: new full-speed USB device number 6 using tegra-xusb
[ 3.933630] input: C-Media Electronics Inc. USB Audio Device as /devices/platform/bus@0/3610000.usb/usb1/1-3/1-3.2/1-3.2:1.2/0003:0D8C:0012.0001/input/input1
[ 3.992068] hid-generic 0003:0D8C:0012.0001: input,hidraw0: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-3610000.usb-3.2/input2
[ 13.240412] ERROR: mounting PARTUUID=7a1d8ba6-701d-4d28-ae6f-48ebb005463a as /mnt fail…
[ 13.241859] ERROR: PARTUUID=7a1d8ba6-701d-4d28-ae6f-48ebb005463a mount fail…
[ 13.243295] ttyTCU0: Press [ENTER] to start bash in 30 seconds…
[ 16.243995] ttyTCU0: Press [ENTER] to start bash in 27 seconds…
[ 19.244598] ttyTCU0: Press [ENTER] to start bash in 24 seconds…
[ 22.245181] ttyTCU0: Press [ENTER] to start bash in 21 seconds…
[ 25.245763] ttyTCU0: Press [ENTER] to start bash in 18 seconds…
[ 28.246348] ttyTCU0: Press [ENTER] to start bash in 15 seconds…
[ 31.246928] ttyTCU0: Press [ENTER] to start bash in 12 seconds…
[ 31.905158] Starting bash…
还有哪里出问题?
please attach the full log. Attach. Not copy and paste.
flash_1-6_0_20250328-161803.log (48.1 KB)
完整日志
如reboot,串口打印日志:
Serial port.txt (47.0 KB)
Please attach the UART side. I mean when the error happened.
Your system is already stuck in recovery boot.
L4TLauncher: Attempting Recovery Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
This log does not help. Please follow this to let system go back to normal boot and capture log again.
Serial port11.txt (64.1 KB)
flash_1-6_0_20250328-165245.log (48.1 KB)
Did you remember to update the kernel modules in rootfs and initrd after you build out a rt kernel?
[ 0.000000] Linux version 5.15.148-rt-tegra (root@wel-22-04-5) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT_RT Fri Mar 28 14:41:49 CST 2025 ()
The issue here is pcie driver and nvme driver are not loaded.
./apply_binaries.sh执行完后,在执行的sudo ./tools/l4t_update_initrd.sh
apply_binaries.sh won’t install the RT kernel modules for you.
那正确的顺序是sudo ./tools/l4t_update_initrd.sh后,在执行apply_binaries.sh吗?
跟apply_binaries.sh沒有關係. 是你rt kernel build的時候有沒有重新build pcie跟nvme driver然後更新到rootfs跟initrd裡面.
