I am attaching my flash log. Would like to understand the meaning of Return Value 8 from tegrarcm_v2. I am running with our own carrier board with Orin NX.
flashlog052523.txt (222.8 KB)
I don’t think the meaning of return values matters much here. The same error message may be caused by many different reasons, and experiences from other people may not help you.
I remember you have some post also regarding flashing Orin NX with custom carrier boards the other days. Is the situation the same now?
Can you try if your device can get into UEFI when you only flash the QSPI memory? What does UART give you when the flashing process fail?
I was doing the flash command from the Virtual BoxVM and that has a known issue with USB interfaces. I converted over to a WMWare virtual machine and now my flash command seems to run but at the end it times out.
/home/jetson/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra
* - Step 3: Start the flashing process *
Waiting for target to boot-up…
Timeout
Cleaning up…
I will try the QSPI flash command next.
Results of QSPI flash only command: Still not able to get system flashed.
$ sudo ./flash.sh -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit mmcblk0p1 | tee flashQSPIlog.txt
L4T BSP Information:
R35 , REVISION: 3.1
User release: 0.0
Target Board Information:
Name: jetson-orin-nano-devkit, Board Family: t186ref, SoC: Tegra 234,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/jetson/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)… done.
copying device_config(/home/jetson/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)… done.
copying misc_config(/home/jetson/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)… done.
./tegraflash.py --chip 0x23 --applet “/home/jetson/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins “mb2_applet applet_t234.bin” --cmd “dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.1252 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.1275 ] File rcm_state open failed
[ 0.1285 ] ERROR: failed to read rcm_state
[ 0.1285 ]
[ 0.1331 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.1337 ] Assuming zero filled SBK key
[ 0.1297 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.1464 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.1767 ] Parsing partition layout
[ 0.1794 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.1837 ] Kernel DTB used: None
[ 0.1838 ] WARNING: dce base dtb is not provided
[ 0.1838 ] Parsing partition layout
[ 0.1861 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.1893 ] Creating list of images to be signed
[ 0.1917 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.1941 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.2008 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.2051 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.2125 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.2192 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.2301 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.2345 ] adding BCH for mb2_t234_aligned.bin
[ 0.2369 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.2472 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.2476 ] adding BCH for mb2_t234_aligned.bin
[ 0.2762 ] Filling MB1 storage info
[ 0.2762 ] Parsing dev params for multi chains
[ 0.2938 ] Generating br-bct
[ 0.2962 ] Updating dev and MSS params in BR BCT
[ 0.2964 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.3000 ] Updating bl info
[ 0.3071 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.3094 ] WARNING: boot chain is not completed. set to 0
[ 0.3116 ] Generating signatures
[ 0.3162 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.3168 ] Assuming zero filled SBK key
[ 0.3723 ] Warning: pub_key.key is not found
[ 0.3685 ] Parsing dev params for multi chains
[ 0.3686 ] Generating br-bct
[ 0.3714 ] Updating dev and MSS params in BR BCT
[ 0.3718 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.3774 ] Updating bl info
[ 0.3798 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.3820 ] WARNING: boot chain is not completed. set to 0
[ 0.3857 ] Get Signed section of bct
[ 0.3882 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.3915 ] Signing BCT
[ 0.3960 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.3966 ] Assuming zero filled SBK key
[ 0.4088 ] Sha saved in br_bct_BR.sha
[ 0.4098 ] Warning: pub_key.key is not found
[ 0.4054 ] Updating BCT with signature
[ 0.4077 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.4099 ] Offset :4608 Len :3584
[ 0.4123 ] Generating SHA2 Hash
[ 0.4168 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.4174 ] Assuming zero filled SBK key
[ 0.4348 ] Sha saved in br_bct_BR.sha
[ 0.4315 ] Updating BCT with SHA2 Hash
[ 0.4340 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.4363 ] Offset :4608 Len :3584
[ 0.4377 ] Offset :68 Len :8124
[ 0.4391 ] Generating coldboot mb1-bct
[ 0.4416 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.4444 ] MB1-BCT version: 0.10
[ 0.4450 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.4465 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.4469 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.4474 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.4481 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.4488 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.4493 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.4500 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.4505 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.4552 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.4561 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.4566 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.4571 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.4576 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.4580 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.4584 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.4588 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.4611 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.4611 ] Added Platform Config 9 data with size :- 100
[ 0.4611 ]
[ 0.4613 ] Updating mb1-bct with firmware information
[ 0.4643 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.4713 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.4766 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.4797 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.4944 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.4949 ] Assuming zero filled SBK key
[ 0.5000 ] Warning: pub_key.key is not found
[ 0.4985 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.5029 ] Generating recovery mb1-bct
[ 0.5053 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.5091 ] MB1-BCT version: 0.10
[ 0.5111 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.5111 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.5111 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.5111 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.5111 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.5111 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.5111 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.5111 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.5111 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.5111 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.5111 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.5111 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.5111 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.5111 ]
[ 0.5111 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.5111 ] Added Platform Config 9 data with size :- 100
[ 0.5111 ]
[ 0.5112 ] Updating mb1-bct with firmware information
[ 0.5151 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.5278 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.5328 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.5353 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.5417 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.5423 ] Assuming zero filled SBK key
[ 0.5486 ] Warning: pub_key.key is not found
[ 0.5471 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.5589 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.5590 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.5591 ] Copying signatures
[ 0.5619 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.5809 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.5812 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.5813 ] Boot Rom communication
[ 0.5842 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.5911 ] BR_CID: 0x80012344705DD4578000000010FE8040
[ 0.6973 ] Sending bct_br
[ 0.7971 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Reading board information failed.
Ran the QSPI flash command again and it ran thru succesfully but was this supposed to flash the kernel and OS too? I only saw the Boot config stuff get flashed into QSPI.
please ignore my previous comment about only flashing QSPI memory. Does UART output anything during the flashing process?
You need to get a real Ubuntu PC first, and some users can get it fixed by disabling auto suspend on their host PC with the following command:
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
If it still does not work, try for a different USB cable/port or a different host PC.
I moved over to use a WMWare virtual machine and the usb seems to be working better. When I run the flash command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --network usb0 --showlogs jetson-orin-nx-varmint-ai internal
I end up with the “waiting for boot” to time out.
can you provide the UART log to see where the device gets stuck?
There is no uart output.
Does flashing with a real Ubuntu PC make any change?
I don’t have access to a Linux PC, went to using a WMWare VM and that seems to keep the device connected.
Give this method a try:
$ sudo -s echo -1 > /sys/module/usbcore/parameters/autosuspend
bash: /sys/module/usbcore/parameters/autosuspend: Permission denied
Did you run them as two separate commands? You have to first switch to root.
no did not expand and see the newlines in your response
Ok that did not work.
I put some extra echo calls in the l4t_initrd_flash_internal.sh script and it is dumping
netpath=/sys/class/net/ens32
netserialnumber=
netconfiguration=
netpath=/sys/class/net/lo
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
GOT 1
netserialnumber=
netconfiguration=
netserialnumber=
netconfiguration=
Timeout
Cleaning up…
So if this is the USB timeout issue how could I determine that?
The script is looking to parse a serial number from the USB device?
While I am running the flash command I see the usb device get disconnected and reconnected multiple times. Is this an expected behavior?
21532.375848] usb 1-1: USB disconnect, device number 43
[21537.237790] usb 1-1: new high-speed USB device number 44 using ehci-pci
[21537.513056] usb 1-1: New USB device found, idVendor=0955, idProduct=7323, bcdDevice= 4.01
[21537.513073] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[21537.513077] usb 1-1: Product: APX
[21537.513080] usb 1-1: Manufacturer: NVIDIA Corp.
[21570.698997] nfsd: last server has exited, flushing export cache
[21571.889357] NFSD: Using UMH upcall client tracking operations.
[21571.889370] NFSD: starting 90-second grace period (net f0000000)
[21577.481594] usb 1-1: USB disconnect, device number 44
[21578.018481] usb 1-1: new high-speed USB device number 45 using ehci-pci
[21578.290602] usb 1-1: New USB device found, idVendor=0955, idProduct=7323, bcdDevice= 4.01
[21578.290620] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[21578.290625] usb 1-1: Product: APX
[21578.290629] usb 1-1: Manufacturer: NVIDIA Corp.
[21598.446814] loop17: detected capacity change from 0 to 115343360
[21599.138207] EXT4-fs (loop17): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[21851.224810] loop17: detected capacity change from 0 to 131072
[21879.526323] usb 1-1: USB disconnect, device number 45
[21880.058072] usb 1-1: new high-speed USB device number 46 using ehci-pci
[21880.330202] usb 1-1: New USB device found, idVendor=0955, idProduct=7323, bcdDevice= 4.01
[21880.330224] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[21880.330231] usb 1-1: Product: APX
[21880.330236] usb 1-1: Manufacturer: NVIDIA Corp.
[21900.003864] loop17: detected capacity change from 0 to 115343360
[21900.778936] EXT4-fs (loop17): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[22153.575693] loop17: detected capacity change from 0 to 131072
[22175.106971] loop17: detected capacity change from 0 to 115343360
[22175.155654] EXT4-fs (loop17): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[22343.238469] usb 1-1: USB disconnect, device number 46
[22343.760085] usb 1-1: new high-speed USB device number 47 using ehci-pci
[22344.036563] usb 1-1: New USB device found, idVendor=0955, idProduct=7323, bcdDevice= 4.01
[22344.036584] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[22344.036588] usb 1-1: Product: APX
[22344.036592] usb 1-1: Manufacturer: NVIDIA Corp.
[22365.992036] loop17: detected capacity change from 0 to 131072
[22423.086726] nfsd: last server has exited, flushing export cache
[22424.309396] NFSD: Using UMH upcall client tracking operations.
[22424.309408] NFSD: starting 90-second grace period (net f0000000)
Yes, and that’s why we suggest flashing Jetson devices using real host PCs, as a VM may not be able to handle it if connection and disconnection happen too frequently.
Interesting observation, I can mount /dev/sda1 /mnt on my VM and see that the filesystem is empty after the bootloader is running.
