hi,
actually we are using Jetson nano production module B01 with eMMC, so we are trying to boot from micro SD-card following below steps:
1)Connect the SD card to the Jetson Nano.
2)Check the SD card device partition (e.g. /dev/mmcblk1p1)
by entering command “lsblk”
3)Create a new GPT:
$ sudo parted /dev/mmcblk1p1 mklabel gpt
4)Add the APP partition:
$ sudo parted /dev/mmcblk1p1 mkpart APP 0GB 16GB
5)format the partition as ext4 : we can use command
“mkfs.ext4 /dev/mmcblk1p1”
6)mounting it’s partition
$ sudo mount /dev/mmcblk1p1 /mnt
7) Copy the application area of the emmc to the micro-SD card.
$ sudo cp -ax /path/to/source (emmc path) /path/to/destination (SD card path)
8)Modify the “/boot/extlinux/extlinux.conf” config file as follow
TIMEOUT 30
MENU TITLE L4T boot options
LABEL sdcard
MENU LABEL sdcard kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk1p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
after these step jetson nano’s eMMC is getting format/corrupt so please let us know these steps are right or what ? and why jetson nano getting format/corrupt.
