Breakage in TensorRT 5.1.2
I have a Tensorflow model derived from VGG16 which worked fine when converted with TensorRT 5.0.2. (tensorrt:19.02-py3 being served with tensorrtserver:19.02-py3).
TensorRT 5.1.2 is making my life miserable. (tensorrt:19.03-py3 being served with tensorrtserver:19.03-py3)
In 5.0.2 I specified the parser input as follows:
parser.register_input(tname, (3, 224, 224), trt.UffInputOrder.NHWC)
In 5.1.2 I get the following error when creating the plan:
[TensorRT] ERROR: import/conv1/convolution: kernel weights has count 32670 but 2439360 was expected
[TensorRT] ERROR: UffParser: Parser error: import/conv1/BiasAdd: The input to the Scale Layer is required to have a minimum of 3 dimensions.
[TensorRT] ERROR: Network must have at least one output
I can get it to compile if I do either:
  • parser.register_input(tname, (224, 224, 3), trt.UffInputOrder.NHWC)
  • parser.register_input(tname, (3, 224, 224), trt.UffInputOrder.NCHW)
But then my soft maxes come out as garbage numbers, regardless of whether I provide input images in HWC or CHW.
Other Tensorflow architectures that I use are working fine with 5.1.2.
Any advice on debugging this problem? Until I fix this, I can’t use the 1.0.0 TRT Inference Server because it is not backwards compatible with 5.0 TRT plan files.
to help us debug, can you please share a small repro that contains the model and plan creation code that exhibit the errors you are seeing?
Sure. I can get a repro case with the model and my conversion code together on Monday.
What is the easiest way to share the savedmodel.pb with you?
you can DM me and share a google drive or dropbox link? or if you’d like to attached to the post, please reference https://devtalk.nvidia.com/default/topic/1043356/tensorrt/attaching-files-to-forum-topics-posts/
I just sent a repro case through DM.
thanks for the repro. will triage and keep you updated.
Per engineering,
With 5.0.2, there was a UFF bug where input order was completely ignored, and the inputs/outputs were always treated as CHW. So even though parsing would often work, inference results were not always correct for HWC cases.
In 5.1.2+, the input order is no longer ignored, so CHW fails, because the model is actually HWC.
So the correct usage as of 5.1 is to specify the same input order and shape as the original TensorFlow model, and pass input data in that format as well.
Changing your inpurt order to
INPUT_SHAPE = (224, 224, 3)
and was able to parse successfully with 5.1.2+
Howdy,
Using (224,224,3) does compile a plan with TRT 5.1.2, but the softmax outputs are completely bogus.
Specifically, if I shove in all-ones as input to the model I sent over…
Tensorflow served with TRTIS 19.03:
—> input: ones(224,224,3)
—> output: [0.1936914473772049, 0.07535892724990845, 0.09353204816579819, 0.05095922574400902, 0.5572561621665955, 0.0292021706700325]
TRT 5.0.2 built with (3,224,224), trt.UffInputOrder.NHWC served with TRTIS 19.02:
—> input: ones(3,224,224)
—> output: [0.1936902105808258, 0.07535859197378159, 0.0935320109128952, 0.0509592704474926, 0.5572577118873596, 0.02920212782919407]
TRT 5.1.2 built with (224,224,3) trt.UffInputOrder.NHWC served with TRTIS 19.03:
—> output: [1.0, 1.0, 1.0, 1.0, 1.0, 1.0]
So:
  • TRT 5.0.2 gives answers consistent with TF
  • TRT 5.1.2 can generate a plan, but the output is broken
At this point I’ve tried every combination of shape, UffInputOrder, and actual input data shape against TRT 5.1.2. All lead to sadness. :(
Sadly this is still broken on today’s 19.04 release of TRT and TRTIS.
I am also getting same issue, please suggest me solution for tensor rt 5.1.2 usage
We did find a workaround, but it has been quite a while so the details are fuzzy.
I believe root cause was that TensorRT used a different axis than Tensorflow when doing the final softmax calculation, so the output was nonsense. (Probably a bug in TensorRT HWC vs. CHW propagation).
The work around was rejiggering the graph to have conv2d+activation be separate layers when the activation is softmax.
Newer versions of TensorRT have come out since. The TensorRT bug may be fixed in those.
That’s all the help I can give on the topic.
