I’m trying to make an inference engine from Tensorflow model using an example from
https://devblogs.nvidia.com/int8-inference-autonomous-vehicles-tensorrt/
The differences from the above example are:
It keeps throwing the following error:
[TensorRT] INFO: Detecting Framework
[TensorRT] INFO: Parsing Model from uff
[TensorRT] INFO: UFFParser: parsing input_1
[TensorRT] INFO: UFFParser: parsing block1_conv1/kernel
[TensorRT] INFO: UFFParser: parsing block1_conv1/Conv2D
[TensorRT] ERROR: UFFParser: Parser error: block1_conv1/Conv2D: Invalid weights types when converted
[TensorRT] ERROR: Failed to parse UFF File
The weight type of this operation in tensorflow graph is D_FLOAT.
UFF model is obtained as follows:
model = tf.keras.applications.VGG16(include_top=True, weights='imagenet')
model_input = model.input.name.strip(':0')
model_output = model.output.name.strip(':0')
graph = tf.get_default_graph().as_graph_def()
sess = tf.keras.backend.get_session()
frozen_graph = tf.graph_util.convert_variables_to_constants(sess, graph, [model_output])
frozen_graph = tf.graph_util.remove_training_nodes(frozen_graph)
uff_model = uff.from_tensorflow(frozen_graph, [model_output])
with open('VGG16.uff', 'wb') as dump:
dump.write(uff_model)
The engine is created like this (this fails):
batchstream = calibrator.ImageBatchStream(5, calibration_files, sub_mean_hwc)
int8_calibrator = calibrator.PythonEntropyCalibrator(["input_1"], batchstream)
engine = trt.lite.Engine(framework="uff",
path="VGG16.uff",
# stream=uff_model,
max_batch_size=1,
max_workspace_size=(256 << 20),
input_nodes={"input_1": (HEIGHT,WIDTH,CHANNEL)},
output_nodes=["predictions/Softmax"],
preprocessors={"input_1": sub_mean_hwc},
postprocessors={},
data_type=trt.infer.DataType.INT8,
calibrator=int8_calibrator,
logger_severity=trt.infer.LogSeverity.INFO)
Using framework=‘tf’ and passing a model graph as a stream makes no difference. I have Ubuntu 16.04, GTX 1060, CUDA9.0, CuDNN 7.0.5, tensorflow 1.5.0-rc0.
Please help.
