Breakpoints not enabled during debugging
I want to debug using VScode in KIT, but when I use VS Code Debugger to connect remotely, the breakpoints I thought I set are invalid.
Sorry if the procedure is wrong, but is there some bug that disables breakpoints when connecting remotely? Also, it would be helpful if you could tell me the procedure to enable it.
The video referenced is at
The documents referred to are as follows
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/tutorial_advanced_python_debugging.html
Hi @yujyu.i.ju.kook. Are you trying to debug in Omniverse Code or Isaac Sim? For Omiverse Code, I would follow the video instructions exclusively. For Isaac Sim, I would follow the linked documentation exclusively. The two methods have nuances that make them incompatible.
