Hi team,
Some questions on TX-1:
Broadcom wifi module in TX1: As from the link https://www.broadcom.com/products/wireless-connectivity/wireless-lan/bcm4354 this device is used as client devices in smartphones and others.However, as per another link (Jetson/TX1 WiFi Access Point - eLinux.org), Jetson TX1’s WiFi controller can be run in Access Point (AP) hot-spot mode, enabling TX1 to host it’s own WiFi network. Can someone confirm us that TX1 module supports AP mode?
CUDA Toolkit 7.5: For GPU Application we are using CUDA Toolkit 7.5. From docs we understood that R23.2 SDK supports CUDA Toolkit 7.0 because it uses kernel version 3.10.67. Is it needed to upgrade to latest version(like 3.19) to support CUDA 7.5?
If the kernel needs to be upgraded, can we apply Tegra SDK changes on that kernel?
I2S Software Feature: In Tegra_Linux_Driver_Package_Software_Feature_List_23.2 doc, I2S interface is missing in software feature supported. Is there any limitation in SDK to support I2S?
Thanks in advance.
