I develop a driver which works with our camera via MIPI CSI-2 in RAW14 (0x2D) mode on 4 lanes.
I’ve added all needed definitions for RAW14 format and driver works but when I capture single frame:
v4l2-ctl --set-fmt-video=pixelformat=Y14 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=capture.raw
the captured frame has “broken” every 5th (sometimes also 6th) pixel in the line. It effects in one- or two-pixel wide vertical lines on the image.
What could be a reason? Any suggestions?
The output status from v4l2-ctl is:
nvidia@tegra-ubuntu:~$ v4l2-ctl --list-formats
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'Y14 '
Name : 14-bit Greyscale
Index : 1
Pixel Format: 'Y16 '
Name : 16-bit Greyscale
Index : 2
Pixel Format: 'GREY'
Name : 8-bit Greyscale
nvidia@tegra-ubuntu:~$ v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, mipi-boson 6-0001
Bus info : platform:54080000.vi:0
Driver version: 4.4.38
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: ok)
Format Video Capture:
Width/Height : 320/256
Pixel Format : 'Y14 '
Field : None
Bytes per Line : 768
Size Image : 196608
Colorspace : sRGB
Transfer Function : Default
YCbCr Encoding : Default
Quantization : Default
Flags :
Camera Controls
hdr_enable (intmenu): min=0 max=1 default=0 value=0
sensor_mode (int64) : min=0 max=0 step=0 default=0 value=0 flags=read-only
gain (int64) : min=0 max=0 step=0 default=0 value=4194304 flags=read-only
frame_rate (int64) : min=0 max=0 step=0 default=0 value=251658240 flags=read-only
bypass_mode (intmenu): min=0 max=1 default=0 value=0
override_enable (intmenu): min=0 max=1 default=0 value=0
height_align (int) : min=1 max=16 step=1 default=1 value=1
size_align (intmenu): min=0 max=2 default=0 value=0
write_isp_format (bool) : default=0 value=0
sensor_signal_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_modes (int) : min=0 max=30 step=1 default=30 value=1 flags=read-only
