[bug ?] clSetKernelArg segfaults
I just wrote and ran an incorrect code :
err = clSetKernelArg(zero_, 0, sizeof(cl_mem), (void*)&dst);
[error check}
err = clSetKernelArg(zero_, 0, sizeof(int), (void*)&size);
[error check]
As you can see, I set ‘0’ two times as argument index, that’s why it’s incorrect.
But instead of returning an error code, the second call … segfaulted !
I think this is not a normal behavior… no ?
I use OpenCL 1.1 :
CL_PLATFORM_NAME: NVIDIA CUDA
CL_PLATFORM_VERSION: OpenCL 1.1 CUDA 3.2.1
with driver 258.19
I get a seg fault with clCreateContext for the following code:
cl_platform_id platform;
    status = clGetPlatformIDs(1, &platform, NULL);
    cout<<"clGetPlatformIDs :"<<status<<endl;
// 2. Find a GPU device
    cl_device_id device;
    status = clGetDeviceIDs(platform, CL_DEVICE_TYPE_GPU, 1, &device, NULL);
    cout<<"clGetDeviceIDs :"<<status<<endl;
// 3. Create a context and command queue on device cl_context context = clCreateContext(0, 1, &device, NULL, NULL, &status)
    cl_context context = clCreateContext(0, 1, &device, NULL, NULL, &status);
    cout<<"clCreateContext :"<<status<<endl;
I don’t think this should be seg faulting and if so then why not return an error?
EDIT: This has been fixed by restarting the machine. Not sure what that indicates as it definitely seg faulted on clCreateContext.
EDIT2: Could this imply that OpenCL or CUDA isn’t cleaning itself up properly on the GPU side?
