clBuildProgram error messages?
I’ve got OpenCL happily building a program. When the program is incorrect I get CL_BUILD_PROGRAM_FAILURE back, which is good.
But is there a way to get a more detailed error message back from the (internal) compiler?
e.g. GLSL had glGetShaderInfoLog() and CUDA had a real compiler. I had thought it might come back in the context notification callback (which is really horrible to manage when you need to throw an exception on ret != CL_SUCCESS) but I don’t see any messages.
yes, you can read out the debug messages with clGetProgramBuildInfo. Please read the opencl documentation section 5.4.5.
here’s a “little” hint:
inline void build(CDevice &device, const char* options = "")
							// build
							cl_int ret_val = clBuildProgram(program, 1, &device.device_id, options, NULL, NULL);
							// avoid abortion due to CL_BILD_PROGRAM_FAILURE
							if (ret_val != CL_SUCCESS && ret_val != CL_BUILD_PROGRAM_FAILURE)
									CL_CHECK_ERROR(ret_val);
							cl_build_status build_status;
							CL_CHECK_ERROR(clGetProgramBuildInfo(program, device.device_id, CL_PROGRAM_BUILD_STATUS, sizeof(cl_build_status), &build_status, NULL));
							if (build_status == CL_SUCCESS)
									return;
							char *build_log;
							size_t ret_val_size;
							CL_CHECK_ERROR(clGetProgramBuildInfo(program, device.device_id, CL_PROGRAM_BUILD_LOG, 0, NULL, &ret_val_size));
							build_log = new char[ret_val_size+1];
							CL_CHECK_ERROR(clGetProgramBuildInfo(program, device.device_id, CL_PROGRAM_BUILD_LOG, ret_val_size, build_log, NULL));
							// to be carefully, terminate with
inline void build(CDevice &device, const char* options = “”)
						// build
								return;
						char *build_log;
						// to be carefully, terminate with \0
					  // there's no information in the reference whether the string is 0 terminated or not
					  build_log[ret_val_size] = '\0';
						std::cout << "BUILD LOG: '" << filepath << "'" << std::endl;
						std::cout << build_log << std::endl;
						delete[] build_log;
						// build
								return;
						char *build_log;
						delete[] build_log;
							delete[] build_log;
Evidently I missed that in the manual. :">
Hi there,
I have a similar problem.
Trying to run a simple OpenCL app on an iMac with an nVidia card, I get the message
“cvmsErrorCompilerFailure: LLVM compiler has failed to compile a function.”
with the error code CL_BUILD_PROGRAM_FAILURE.
But this only happens when the GPU is selected as a device,
when the CPU is selected, the kernel compiles and the program runs fine.
Is there a difference between the language restrictions for CPU and GPU compilation of the kernel?
The kernel contains a median image filter utilizing a little bubblesort function.
Greetings from Germany and merry xmas!
Konstantin Dols
