Getting segfault. Could you check?
I appended samplecode of cl.hpp with another kernel and I get a segmentation fault. Is the kernel wrong? Did I forgot anything?
It would be very helpful, if some of you check this program for segfaults.
System: Arch Linux
NVidia Linux 64bit driver 260.19.36
[Update1]: and also 260.19.44.
[Update2]: Driver 270.18 and 270.26 (Beta!!) do not crash. However I get 5 invalid reads, so further crashes are possible. I hope these will vanish over time.
My code:
#define __CL_ENABLE_EXCEPTIONS
#if defined(__APPLE__) || defined(__MACOSX)
#include <OpenCL/cl.hpp>
#else
#include <CL/cl.hpp>
#endif
#include <cstdio>
#include <cstdlib>
#include <iostream>
const char * helloStr  = "__kernel void mipmap(__global __read_only image2d_t in0,"
							"__global __read_only image2d_t in1,"
							"__global __read_only image2d_t in2,"
							"__global __read_only image2d_t in3,"
							"__global __write_only image2d_t out){"
int
 main(void)
    cl_int err = CL_SUCCESS;
    try {
std::vector<cl::Platform> platforms;
      cl::Platform::get(&platforms);
      if (platforms.size() == 0) {
          std::cout << "Platform size 0\n";
          return -1;
cl_context_properties properties[] =
         { CL_CONTEXT_PLATFORM, (cl_context_properties)(platforms[0])(), 0};
      cl::Context context(CL_DEVICE_TYPE_DEFAULT, properties);
std::vector<cl::Device> devices = context.getInfo<CL_CONTEXT_DEVICES>();
cl::Program::Sources source(1,
          std::make_pair(helloStr,strlen(helloStr)));
      cl::Program program_ = cl::Program(context, source);
      program_.build(devices);
    catch (cl::Error err) {
       std::cerr
          << "ERROR: "
          << err.what()
          << err.err()
          << std::endl;
return EXIT_SUCCESS;
The corresponding valgrind message:
==4395== Memcheck, a memory error detector
==4395== Copyright (C) 2002-2010, and GNU GPL'd, by Julian Seward et al.
==4395== Using Valgrind-3.6.1 and LibVEX; rerun with -h for copyright info
==4395== Command: ./badcode
==4395==
==4395== Invalid read of size 4
==4395==    at 0x63FBB9E: ??? (in /usr/lib/libcuda.so.260.19.36)
==4395==    by 0x63FC264: ??? (in /usr/lib/libcuda.so.260.19.36)
==4395==    by 0x63FD79A: ??? (in /usr/lib/libcuda.so.260.19.36)
==4395==    by 0x640A53D: ??? (in /usr/lib/libcuda.so.260.19.36)
==4395==    by 0x64935B4: ??? (in /usr/lib/libcuda.so.260.19.36)
==4395==    by 0x401BE8: cl::Program::build(std::vector<cl::Device, std::allocator<cl::Device> > const&, char const*, void (*)(_cl_program*, void*), void*) const (in /home/alex/projects/opencl/badcode)
==4395==    by 0x401334: main (in /home/alex/projects/opencl/badcode)
==4395==  Address 0x28 is not stack'd, malloc'd or (recently) free'd
==4395==
==4395==
==4395== Process terminating with default action of signal 11 (SIGSEGV)
==4395==  Access not within mapped region at address 0x28
==4395==  If you believe this happened as a result of a stack
==4395==  overflow in your program's main thread (unlikely but
==4395==  possible), you can try to increase the size of the
==4395==  main thread stack using the --main-stacksize= flag.
==4395==  The main thread stack size used in this run was 8388608.
==4395==
==4395== HEAP SUMMARY:
==4395==     in use at exit: 872,953 bytes in 1,877 blocks
==4395==   total heap usage: 203,792 allocs, 201,915 frees, 42,249,831 bytes allocated
==4395==
==4395== LEAK SUMMARY:
==4395==    definitely lost: 5,723 bytes in 225 blocks
==4395==    indirectly lost: 9,552 bytes in 75 blocks
==4395==      possibly lost: 3,113 bytes in 60 blocks
==4395==    still reachable: 854,565 bytes in 1,517 blocks
==4395==         suppressed: 0 bytes in 0 blocks
==4395== Rerun with --leak-check=full to see details of leaked memory
==4395==
==4395== For counts of detected and suppressed errors, rerun with: -v
==4395== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 16 from 10)
Thank you!
Best regards,
Alex
