I have noticed some strange behaviour when checking calculated IMU data.
At high physics frequency (>= 200) and orientation close to 0, there is significant jitter in the acceleration values.
Below is the code I am using to alter rigid body motion.
# A callback run on each physics frame
rigidbody.set_linear_velocity([0,step/fps,0])
rigidbody.set_angular_velocity([0,0,10])
Where scanner
has the rigidbody.
This might be a case of the XY problem - for context, I am trying to move an object around a simulated scene, predefined path, and output sensor data (lidar, camera, imu) to ROS synchronized with simulation time. Would really appreciate some help!
