Description
The output of LayerNormPlugin has large error compared to torch.nn.LayerNorm.
Environment
official docker container 22.12
Relevant Files
related files: https://cloud.tsinghua.edu.cn/f/40c33b2aeb2347678cea/?dl=1
Steps To Reproduce
import os
from polygraphy.backend.trt import TrtRunner
import torch
import numpy as np
class MyLayerNorm(torch.nn.LayerNorm):
def __init__(self, dim, eps=1e-5):
super().__init__(dim, eps)
def forward(self, x):
x = x.view(2, 256, 4, 16, 4, 16)
x = x.permute(0, 2, 4, 3, 5, 1).contiguous()
x = x.view(2, 16, 256, 256)
return super().forward(x)
input_0, model = torch.load('LN_bug.pt')
with torch.no_grad():
outputs_pt = model(input_0).numpy()
feed_dict = {'input_0': input_0.numpy()}
import tensorrt as trt
TRT_LOGGER = trt.Logger()
trt.init_libnvinfer_plugins(TRT_LOGGER, '')
def load_engine(engine_file_path):
assert os.path.exists(engine_file_path)
print("Reading engine from file {}".format(engine_file_path))
with open(engine_file_path, "rb") as f, trt.Runtime(TRT_LOGGER) as runtime:
return runtime.deserialize_cuda_engine(f.read())
os.system('trtexec --onnx=LN_bug.onnx --saveEngine=LN_bug.trt --fp16 --buildOnly')
engine = load_engine('LN_bug.trt')
with TrtRunner(engine) as runner:
outputs_trt = runner.infer(feed_dict)
print('max error', np.abs(outputs_pt-outputs_trt['output_0']).max())
It will output >11 absolute error.
