Isaac Sim Version
4.2.0
Isaac Lab Version (if applicable)
1.2
Operating System
Ubuntu 22.04
GPU Information
- Model: 4090
- Driver Version: 535.129.03
Topic Description
Detailed Description
When I use the RigidObject.set_external_force_and_torque() function in stages according to the simulation time, I can control the object well in the first stage, but when I enter the second stage from the first stage, the object receives the force and torque of the second stage first and can control the movement of the object well. But after a while can not control, the object seems to be subjected to the first stage of the force and torque, and will continue to superimpose this force and torque, making the acceleration of the object more and more. It feels like the cache of forces and moments in this function is not cleared
Screenshots or Videos
Phenomenon vedio:
Specific values (force and torque is input, object velocity is output):
Where 10-30 is the first stage, 30-90 is the second stage
As can be seen from step 50 onwards, the function does not control the object. This feels like a superposition of the first phase values
Additional Information
What I’ve Tried
At first, I thought it was a problem caused by too many decimal places in the input value. Later, after controlling it to 3 decimal places, the phenomenon slowed down, but it still occurred. Then continue to reduce the decimal place, the effect is minimal.
Thank you for posting this. This is being investigated by the Isaac Lab team, and tracked in this issue. Please use the Isaac Lab issues for these reports. Thanks.
Hello, I may know the cause of this, because when force and torque are used together, it will cause this bug. This bug does not occur when using force alone, or when using torque alone. Hope this phenomenon can help you solve this bug!
I don’t mean that force and torque can’t both be assigned and used in RigidObject.set_external_force_and_torque(). For example, it worked fine when I set up force and torque in phase 1 and accelerated the ball with RigidObject.set_external_force_and_torque on the x and y linear and z angular velocities. However, in the second stage, when you set up force and torque and slow down the balls with RigidObject.set_external_force_and_torque, it can develop this bug. This bug occurs when the angular velocity of the Z-axis is too large and it is slowed down. When the Z-axis angular velocity is small, there is no such bug.
Now there is a new bug, I found that when I accelerate in this first stage, the ball line speed reaches a certain value, even if I have an external force, the ball will not accelerate, and even slow down.
As you can see in the figure, this has been happening since 25
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
