Bug Report: Wayland-only: dmaAllocMapping_GM107 VA mapping failures (does not reproduce on X11)
Driver versions affected: 580.105.08 and earlier versions (issue reproducible across multiple driver/kernel combinations)
Kernel: 6.17.9-2-cachyos (also observed on earlier kernels)
GPU: GeForce RTX 3080 Founders Edition (GA102, 10 GiB)
Driver type: nvidia-open kernel modules
Desktop session: KDE Plasma Wayland
Application affected: Jellyfin “Delfin” Electron client (NVDEC-accelerated video playback), Various GPU-intensive workloads (e.g., gaming)
ReBAR: Tested enabled and disabled — issue occurs in both cases
Bug report log: nvidia-bug-report.log.gz (506.8 KB)
Summary
The NVIDIA driver eventually begins emitting repeated kernel messages of the form:
NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
This occurs reliably after ~30–45 minutes of NVDEC hardware-accelerated video playback, and also intermittently during other GPU-intensive workloads such as gaming.
Impact differs by workload:
  • During video playback: the video output turns blank, and the application must be restarted, but the desktop remains responsive.
  • During heavier GPU workloads (e.g., games): the same error sometimes leads to noticeable stalls, and in some cases a full system freeze (impossible to switch to another TTY).
The issue has been reproduced across multiple NVIDIA driver versions and multiple kernel versions, with and without ReBAR enabled.
No Xid codes are generated — only the repeated VA-space allocation failure message.
Reproduction Steps (most reliable via NVDEC)
  1. Start KDE Plasma Wayland session.
  2. Launch HW accelerated video playback (for example with Delfin, a Jellyfin client).
  3. Ensure NVDEC hardware acceleration is enabled.
  4. Play any long video.
  5. After ~30–45 minutes:
    • Video freezes and goes blank.
    • Application must be restarted.
    • Kernel logs begin spamming:
Observed using:
sudo journalctl -k -f -g NVRM
Observed Behaviour
  • Playback failure and blank video output during NVDEC decoding.
  • Kernel repeatedly logs VA-space allocation errors.
  • No Xid codes or GPU resets logged.
  • Same log message appears during gaming or other heavy GPU tasks, where it may cause stalls or full system freezes.
  • Problem persists:
    • With ReBAR enabled (large BAR1 aperture).
    • With ReBAR disabled (classic 256 MiB BAR1).
    • Across several driver and kernel versions.
  • VRAM usage remains stable; issue appears unrelated to memory pressure.
Update: Issue also occurs with software decoding + does NOT reproduce under X11
I have additional information after further testing:
1. The dmaAllocMapping_GM107: can't alloc VA space for mapping error also occurs with hardware decoding completely disabled.
  • I disabled hardware video acceleration in the application.
  • I verified via nvidia-smi dmon -s u that NVDEC usage remained at 0% throughout playback.
  • After a longer period (larget timescale than previous tests, though I’m now inclined to think this is random), the same error eventually appeared in the kernel log.
This suggests the issue is not tied to NVDEC.
2. The issue does not reproduce under a Plasma (X11) session.
I switched from Plasma Wayland to Plasma X11 and tested:
  • multiple hours of continuous video playback
  • gaming workloads
  • other GPU-intensive tasks
The error never appeared, and no playback stalls or freezes occurred.
This strongly suggests that the issue is triggered specifically under Wayland.
3. Summary of updated findings
  • Error occurs even with software decoding only - unrelated to NVDEC.
  • Error occurs under Plasma Wayland during normal usage (video playback or gaming).
  • Error does NOT occur on X11, even after extended stress testing.
  • System remains stable on X11; no VA mapping failures observed.
Let me know if there is any additional logging I can enable to help isolate the problem
I see this as well with a similar setup (Arch 6.12.61-1-lts, Driver 580.105.08, GPU 5070 Ti, nvidia-open), and have also noticed it happening even without NVDEC issues.
Another trigger I’ve found is certain webpages in Chrome 143, even with hardware decoding forcibly disabled, such as this one (the most recent one that crashed my system): https://www.nokia.com/broadband-access/in-home-connectivity/home-wi-fi/wi-fi-beacon-g6-2/
I have reported this multiple times. Nvidia seem determined to ignore it.
Hi All,
Apologize for the delayed response, I have filed a bug 5762513 internally for tracking purpose.
Team will try to duplicate issue in lab and will get back if required any additional information.
I have the same issue while playing Hytale on wayland.
NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from pReuseMappingDb->pMapCb(pReuseMappingDb->pGlobalCtx, pAllocCtx, range, cachingFlags, &token, _reusemappingdbAddMappingCallback) @ mapping_reuse.c:273
It gets absolutely spammed, that even the journal can’t keep up.
$ journalctl -b -g NVRM | wc -l
3950544
$ journalctl -b -u systemd-journald
/dev/kmsg buffer overrun, some messages lost. (Dropped 24 similar message(s))
Missed 483 kernel messages
Missed 13 kernel messages
Missed 425 kernel messages
Missed 1124 kernel messages
Additional reproduction data - RTX 3090 Ti on Fedora 43 + COSMIC Wayland
I can confirm this issue occurs on driver 580.126.09 (latest production release as of Jan 2026), indicating the kvmalloc() memory allocation fix in this release does not address this specific bug.
System Configuration:
  • GPU: NVIDIA GeForce RTX 3090 Ti (GA102, 24GB)
  • Driver: 580.126.09 (proprietary, DKMS install)
  • Kernel: 6.18.5-200.fc43.x86_64
  • OS: Fedora 43
  • Desktop: COSMIC (System76 Wayland compositor)
  • Browser: Chromium
Reproduction:
  • Simply loading a webpage with media content (Nokia product page with embedded content)
  • Crash occurs within seconds, not requiring extended playback
Observed errors (journalctl):
[drm:__nv_drm_gem_nvkms_map [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to map NvKmsKapiMemory 0x000000009ebe4fc4
traps: Media[19678] trap invalid opcode ip:560a118419d6 sp:7f2c67f0c430 error:0 in chromium-browser
Impact:
  • Chrome’s GPU/Media process crashes with illegal instruction trap
  • Extended occurrence leads to full system freeze requiring hard reboot
  • Issue is intermittent but reproducible within normal browsing session
Notes:
  • Issue did NOT occur on driver 580.119.02 with akmod-nvidia (RPM Fusion) initially, but manifested after extended uptime
  • Upgraded to 580.126.09 hoping kvmalloc() fix would help - issue persists
  • ReBAR status: enabled in BIOS
Bug report attached: nvidia-bug-report-20260123-222838.log.gz
Files to attach:
  1. nvidia-bug-report-20260123-222838.log.gz (1.8 MB)
Can you confirm my report is related or different issue and if so kindly file a separate ticket?
welp I’m now getting it as well. it came out from absolutely nowhere.
been locked on 580.82.09 drivers for months, and now running gamescope -–backend sdl – command triggers this in dmesg:
[ 7587.307062] NVRM: dmaAllocMapping_GM107: Virtual address 0x6E30000 is not compatible with page size 0x200000 or page offset 0x0.
[ 7587.307273] gamescope-xwm[161783]: segfault at 80 ip 000055cffbced49e sp 00007efe42c78070 error 4 in gamescope[7449e,55cffbcaf000+382000] likely on CPU 12 (core 6, socket 0)
[ 7587.307280] Code: 00 48 29 c1 48 89 c8 48 89 55 e0 48 89 45 e8 48 8b 45 e0 48 8b 55 e8 48 89 10 90 90 c9 c3 55 48 89 e5 48 89 7d f8 48 8b 45 f8 <48> 8b 00 5d c3 90 55 48 89 e5 48 89 7d f8 48 8b 45 f8 48 8b 00 48
I also have this issue, though I just found this thread, I tried to report it in 580 and 590 feedback but was ignored.
I’m able to reproduce it using the nvidium mod, maintained fork, setting the memory limit to 8192 or above causes it, under that does not. I have a 3090 with 24GB of vram.
Here’s the two associated threads of other people with the same issue:
I was able to confirm that this issue occurs with both open and closed drivers, and was introduced in 580.126.09, the prior version 580.119.02 or 570/575 do not have this issue, and the latest 590.48.01 still has it.
[  +0.000003] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[  +0.000003] NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from pReuseMappingDb->pMapCb(pReuseMappingDb->pGlobalCtx, pAllocCtx, range, cachingFlags, &token, _reusemappingdbAddMappingCallback) @ mapping_reuse.c:274
[  +0.002012] NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from reusemappingdbMap(&pBar1VaInfo->reuseDb, pMappingType, mapRange, pMemArea, cachingFlags) @ kern_bus_gm107.c:3187
[  +0.003045] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[  +0.000031] NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from pReuseMappingDb->pMapCb(pReuseMappingDb->pGlobalCtx, pAllocCtx, range, cachingFlags, &token, _reusemappingdbAddMappingCallback) @ mapping_reuse.c:274
[  +0.000281] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
I can also reproduce it by running any local LLM which uses more than 8GB of vram, errors in dmesg and very slow startup, keeps trying to allocate until it succeeds which can take several minutes depending on how much vram.
I used to have this problem only sometimes when using NVDec on 580/590 drivers and only in certain applications (for example freetube would lock up and spam the following in the logs):
Apr 06 12:09:55 balrog kernel: NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
Apr 06 12:09:55 balrog kernel: NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from pReuseMappingDb->pMapCb(pReuseMappingDb->pGlobalCtx, pAllocCtx, range, cachingFlags, &token, _reusemappingdbAddMappingCallback) @ mapping_reuse.c:273
Apr 06 12:09:55 balrog kernel: NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from reusemappingdbMap(&pBar1VaInfo->reuseDb, pMappingType, mapRange, pMemArea, cachingFlags) @ kern_bus_gm107.c:3186
However, since upgrading to 595 drivers the system is completely unusable. It happens with everything! Even opening a terminal fails (kitty opens but with a blank screen and hangs). All of this right after boot. Reverting back to 590 drivers makes (almost) everything functional again.
In my case the system is:
Arch Linux (6.19.9-arch1-1) / Hyprland (0.54.3-2) / GeForce RTX 3090
On 590.48.01-17 (rarely affected)
On 595.58.03-03 (everything crashing)
If it’s relevant, beyond normal set of apps running I do have whisper and sunshine loaded on boot (sunshine may initialize nvdec not sure, while whisper may do something similar with cuda?).
> nvidia-smi
Mon Apr  6 15:48:35 2026
| NVIDIA-SMI 590.48.01              Driver Version: 590.48.01      CUDA Version: 13.1     |
|   0  NVIDIA GeForce RTX 3090        Off |   00000000:01:00.0  On |                  N/A |
| 53%   40C    P0            110W /  350W |    2809MiB /  24576MiB |      5%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI              PID   Type   Process name                        GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A            1834    C+G   whisper-server                          226MiB |
|    0   N/A  N/A            2086      G   Hyprland                                424MiB |
|    0   N/A  N/A            2162      G   /usr/bin/64gram-desktop                   4MiB |
|    0   N/A  N/A            2163    C+G   /usr/bin/python                          87MiB |
|    0   N/A  N/A            2168      G   /usr/lib/firefox/firefox                221MiB |
|    0   N/A  N/A            2169      G   /usr/lib/firefox/firefox                260MiB |
|    0   N/A  N/A            2179      G   kitty                                    92MiB |
|    0   N/A  N/A            2217      G   Xwayland                                  6MiB |
|    0   N/A  N/A            2432    C+G   /usr/bin/swaync                         150MiB |
|    0   N/A  N/A            3208      G   /usr/lib/electron40/electron             63MiB |
|    0   N/A  N/A            3699      G   ...signal-desktop/signal-desktop         44MiB |
|    0   N/A  N/A            4685      G   ...share/Steam/ubuntu12_32/steam          8MiB |
|    0   N/A  N/A            5519      G   /opt/Heroic/heroic                       65MiB |
|    0   N/A  N/A            6209      G   ./steamwebhelper                         48MiB |
|    0   N/A  N/A            6249      G   ...am/ubuntu12_64/steamwebhelper         74MiB |
|    0   N/A  N/A            6311    C+G   /usr/bin/sunshine                       262MiB |
|    0   N/A  N/A            6421      G   /usr/lib/electron38/electron             59MiB |
|    0   N/A  N/A          597626      G   kitty                                   124MiB |
I can reliably reproduce this issue with a specific trigger.
System:
  • GPU: GeForce RTX 3060 12GB
  • Driver: 595.58.03 (latest production branch)
  • Kernel: 6.19.12-1-cachyos
  • OS: CachyOS based on Arch Linux
  • Desktop: KDE Plasma 6.6.4 Wayland
  • Browser: Chromium-based (tested both Helium Browser and Google Chrome - same result)
Reproduction:
Navigating to https://m3.material.io/get-started reliably triggers the crash every time. The page loads briefly, then the tab freezes and the renderer process crashes with SIGILL. No extended usage or waiting required, it happens within seconds of the page loading.
Another page on the same site - https://m3.material.io/styles/shape/overview-principles - goes further and freezes the entire system, requiring a hard reboot. Unlike the get-started page which only crashes the renderer process, this one escalates to a full system hang immediately.
Relevant dmesg output:
kernel: NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from pReuseMappingDb->pMapCb(pReuseMappingDb->pGlobalCtx, pAllocCtx, range, cachingFlags, &token, _reusemappingdbAddMappingCallback) @ mapping_reuse.c:274
kernel: resource: resource sanity check: requesting [mem 0x00000000bf4f0000-0x00000000c02fffff], which spans more than 0000:01:00.0 [mem 0xb0000000-0xbfffffff 64bit pref]
kernel: caller __nv_drm_gem_nvkms_map+0x94/0x110 [nvidia_drm] mapping multiple BARs
kernel: hrtimer: interrupt took 18635980 ns
kwin_wayland[1420]: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Coredump from renderer process:
Signal: 4 (ILL)
Stack trace of thread:
#0  0x0000562c191f5458 n/a (n/a + 0x0)
What I’ve tested:
  • --disable-gpu → no crash (confirms GPU path is the trigger)
  • Firefox with GPU acceleration → works fine on the same page
Additional findings:
All <video> elements on affected pages use preload="auto" autoplay muted loop, causing Chromium to decode all videos simultaneously on page load. The main page https://m3.material.io has 1 video and works fine. The https://m3.material.io/get-started page has 10 simultaneous autoplay videos and crashes the renderer. The https://m3.material.io/styles/shape/overview-principles page has 7 simultaneous autoplay videos and freezes the entire system. Firefox handles all three pages without issues.
Happy to provide any additional logs or run diagnostic commands if it helps narrow this down. The fact that this is 100% reproducible on a specific URL should hopefully make it easier to debug on your end.
nvidia-bug-report.log.gz (362.3 KB)
Soooooo is this going to be fixed any time soon? Kinda still running 580.119.02 after all this time, need this to be fixed or I can never update again… on a supported 3090 GPU…
I am also getting this for a seemingly random reason, but in my case it causes an unrecoverable freeze in GNOME. I am unable to forcibly restart GNOME from an SSH connection and am forced to power cycle my computer, though admittedly I haven’t tried very hard since it isn’t too big of a deal to just reboot.
System:
  • GPU: GeForce RTX 4070 Ti 12GB
  • Driver: 610.43.02
  • Kernel: 7.0.12-arch1-1
  • OS: Arch Linux
  • Desktop: GNOME 50.2, Wayland
  • Browser: Brave (Version 1.91.172, Chromium: 149.0.7827.115)
I am able to reproduce the same behavior as @meet.indrawn-3h using the first website that was linked to (https://m3.material.io/get-started). The second web page (https://m3.material.io/styles/shape/overview-principles) doesn’t freeze or alert in dmesg when opened.
This is the error that shows up dmesg after clicking on the bad link.
[ 1456.378504] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378512] NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from pReuseMappingDb->pMapCb(pReuseMappingDb->pGlobalCtx, pAllocCtx, range, cachingFlags, &token, _reusemappingdbAddMappingCallback) @ mapping_reuse.c:273
[ 1456.378521] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378525] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378550] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378553] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378557] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378620] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378625] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378648] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378652] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378656] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378660] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378663] NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
[ 1456.378667] NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from pReuseMappingDb->pMapCb(pReuseMappingDb->pGlobalCtx, pAllocCtx, range, cachingFlags, &token, _reusemappingdbAddMappingCallback) @ mapping_reuse.c:273
[ 1456.378724] NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from reusemappingdbMap(&pBar1VaInfo->reuseDb, pMappingType, mapRange, pMemArea, cachingFlags) @ kern_bus_gm107.c:3150
[ 1456.378735] [drm:__nv_drm_gem_nvkms_map [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000a00] Failed to map NvKmsKapiMemory 0x00000000826400ba
[ 1456.402972] traps: Media[19929] trap invalid opcode ip:55c8b4392e48 sp:7f569d9fb020 error:0 in brave[b407e48,55c8ac1fc000+dfda000]
Weirdly enough, triggering the dmesg error by opening the webpage that freezes in Brave doesn’t cause GNOME to freeze, but looking at all my previous runtime logs using journalctl -b -$BOOT_INDEX -k, this error message is consistent with all the other freezes from GNOME; Brave shows up in dmesg with the same trap alert whenever a freeze occurs, so I don’t know why it’s any different.
Globally disabling Autoplay in Brave (Settings > Privacy and Security > Site and Shield Settings > Additional Permissions > Autoplay) allows the webpage that was freezing before to load just fine with no issue or alert in dmesg. I would assume the same would work in any other Chromium-based browser too.
I will continue with this setting for a few days and if I still experience freezes, I will report back.
I can reproduce what appears to be the same issue on Arch Linux with an RTX 5070 Ti, nvidia-open 610.43.02, KDE Plasma Wayland, and Google Chrome 149.
System:
Distribution: Arch Linux
GPU: NVIDIA GB203 / GeForce RTX 5070 Ti, PCI ID 10de:2c05
Driver: nvidia-open 610.43.02-3
Userspace: nvidia-utils 610.43.02-2, lib32-nvidia-utils 610.43.02-1
Desktop: KDE Plasma 6.7.0 / KWin 6.7.0-3
Session: Wayland
Browser: Google Chrome 149.0.7827.155-1
Chrome renderer command line included: --ozone-platform=wayland
Observed behavior:
Chrome media/renderer processes repeatedly crash with SIGILL in the same browsing/video playback scenario. One occurrence caused the machine to become unresponsive and required a reboot. After rebooting and restoring Chrome, the same tab/scenario reproduced the renderer crashes.
The kernel logs match the issue described in this thread:
NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from pReuseMappingDb->pMapCb(...) @ mapping_reuse.c:273
NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051) returned from reusemappingdbMap(...) @ kern_bus_gm107.c:3150
[drm:__nv_drm_gem_nvkms_map [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00002b00] Failed to map NvKmsKapiMemory
traps: Media[...] trap invalid opcode ... in chrome
NVRM: Xid (PCI:0000:2b:00): 38, pid=1418, name=chrome
coredumpctl list chrome shows repeated Chrome SIGILL crashes:
Sun 2026-06-21 17:58:43 CST 106472 1000 1000 SIGILL truncated /opt/google/chrome/chrome
Sun 2026-06-21 17:58:44 CST  72062 1000 1000 SIGILL truncated /opt/google/chrome/chrome
Sun 2026-06-21 18:02:15 CST   2714 1000 1000 SIGILL present   /opt/google/chrome/chrome
Sun 2026-06-21 18:02:45 CST   2847 1000 1000 SIGILL truncated /opt/google/chrome/chrome
This does not appear to be system RAM exhaustion. After reboot, the system had about 25 GiB available memory.
I will attach nvidia-bug-report.log.gz generated from this machine. Please let me know if additional logs or tests would help.
nvidia-bug-report.log.gz.gz (504.1 KB)
03-key-log-excerpts.txt (4.5 KB)
Dear All,
This is to update that we were able to reproduce issue in our lab and also checked that issue doesn’t persists once we enable resizable bar option in BIOS.
Can some one please help to enable resizable bar with our latest drivers and share the feedback.
Enabling resizable BAR seems to have fixed the issue.
Originally I had only tried enabling the DKMS option as such:
$ cat /etc/modprobe.d/nvidia.conf
options nvidia NVreg_EnableResizableBar=1
which only increased the reported size from 256MiB to 512 MiB.
The solution to that was to actually turn on resizable BAR by enabling it in the motherboard BIOS. Those being “Above 4G Decoding” and “Resizable BAR support” options or equivalent.
For anyone that may be confused, I’d recommend looking up how to enable resizable BAR for your motherboard specifically (or at least the brand since the menu should be similar across models).
Are there any plans to fix the issue? I’m using a supermicro board that doesn’t like REBAR.
I enabled Above 4G Decoding and Clever Access Memory in my motherboard’s UEFI (ASRock B460M PRO4), and I’m no longer getting crashes in Chrome on the URLs I attached in my first message. It looks like this fixed the issue.
I have an additional Fedora 44 reproduction that appears to belong to NVIDIA internal bug 5762513. It adds proprietary-driver, Pascal/GP106, and cross-compositor evidence.
Between a short span of 2 days I retained eight Brave foreground-renderer SIGILL failures across five browser incidents. The Brave crashpad metadata for all eight identifies a foreground renderer with YouTube loaded. This matches what I was doing at the time: YouTube tabs were open, being selected, or active. I am treating that as workload correlation, not proof that YouTube is the root cause.
Environment:
  • Fedora Linux 44 x86_64
  • affected kernel: 7.1.8-200.fc44.x86_64
  • KDE Plasma 6.7.4 Wayland, KWin 6.7.4
  • Brave 1.93.137 and 1.93.138, native Wayland (--ozone-platform=wayland)
  • proprietary NVIDIA kernel module and userspace driver 580.173.02
  • GeForce GTX 1060 6GB, GP106, PCI ID 10de:1c03
  • PCI Region 1 is 256 MiB prefetchable; lspci -vv does not show a Resizable BAR capability
All eight renderer traps were immediately preceded by an nvidia_drm failure to map an NvKmsKapiMemory object. Six crashes in Brave 1.93.138 had the same file offset, 0xc102488; mapping that offset into the installed ELF lands on ud2 (0f 0b). This therefore looks like an intentional Chromium fatal path after the GPU resource failure, rather than an unsupported CPU instruction.
Two incidents on 2026-08-22 contained system-wide Xid storms before the renderer trap:
  1. 125 Xid 32 records in about 25 ms, affecting kwin_wayland (57), xwaylandvideobr (11), plasma-keyboard (11), plasmashell (10), brave (10), udev-worker (10), Xwayland (8), and ChatGPT (8). This was followed within milliseconds by Failed to ioremap_wc NvKmsKapiMemory, Failed to map NvKmsKapiMemory, and the Brave Media renderer SIGILL. About 30 seconds later there were two Xid 56 records; KWin attributed a graphics reset to its current GL context, Plasma lost its GL context/device, and the Brave and Codex GPU processes exited. The boot journal then ended without an orderly shutdown sequence.
  2. 110 Xid 32 records in about 21 ms, affecting kwin_wayland (66), ChatGPT (8), xwaylandvideobr (7), plasmashell (7), Xwayland (7), plasma-keyboard (5), brave (5), and udev-worker (5). Brave then reported GL_GUILTY_CONTEXT_RESET_KHR, nvidia_drm failed to map KMS memory, the Brave Media renderer hit the same SIGILL, Brave restarted its GPU process, and KWin reported a graphics reset. The journal ended approximately 2.3 seconds later without an orderly shutdown.
The other six renderer failures had the same Failed to map NvKmsKapiMemory → fixed-build-offset SIGILL sequence but no retained Xid records.
There was no suspend/resume transition before either Xid storm. The affected journals also contain no event-time host OOM, AMD GPU reset, PCIe AER/MCE, or GPU has fallen off the bus. I do not have local dmaAllocMapping_GM107, NV_ERR_NO_MEMORY, mapping_reuse, or resource sanity check lines, so I cannot independently prove the exact internal VA-allocation failure on this proprietary build.
I previously observed the same multi-client Xid 32 family with Chrome/YouTube under COSMIC. These new events reproduce it under KDE/KWin.
Does this proprietary-driver GP106 case belong to bug 5762513? Since this GTX 1060 exposes no ReBAR capability, is there a driver fix/backport or another specific diagnostic you would like collected immediately after the next recurrence?
Sanitized text attachmentsincident-summary-public.txt
environment-public.txt (606 Bytes)
kde-xid-event-2-public.txt (711 Bytes)
kde-xid-event-1-public.txt (945 Bytes)
incident-summary-public.txt (2.6 KB)
Written by gpt 5.6 sol . Verified by me ( aka human)
