[575.153.02] btree mapping crash during Dune: Awakening
I experienced this graphics crash while playing Dune: Awakening yesterday, 2025-06-21. Unfortunately the collection of asserts don’t indicate clearly (at least to my eye) what is happening. I first thought this was a graphics OOM, since I have experienced that before I implemented idle buffer reduction (GLVidHeapReuseRatio = 0) on my compositor. But checking the VRAM usage at the time of the crash, it was at about 10GB out of 16GB on my 5080. I haven’t seen Dune go above that since then, either.
From my searches, this seems to be new - I can’t find any reports referencing _gvaspaceMappingInsert.
Attached is nvidia-bug-report.log.gz. I’ve also put the relevant log output in-line for searchability and in case nvidia-bug-report didn’t grab the revelant logs from journalctl. OS is NixOS 25.05.
nvidia-bug-report.log.gz (618.9 KB)
It hasn’t happened again, at least so far. If it does I will report back.
Jun 21 18:15:41 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3C0000-0xDEFA3CFFFF!
Jun 21 18:15:41 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:4815
Jun 21 18:15:41 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:2278
Jun 21 18:15:41 snail kernel: NVRM: nvCheckFailedNoLog: Check failed: 0 == (pMapNode->gpuMask & gpuMask) @ gpu_vaspace.c:4731
Jun 21 18:15:41 snail kernel: NVRM: nvCheckOkFailedNoLog: Check failed: Invalid argument to call [NV_ERR_INVALID_ARGUMENT] (0x0000001F) returned from _gvaspaceMappingInsert(pGVAS, pGpu, pVASBlock, vaLo, vaHi, flags) @ gpu_vaspace.c:2233
Jun 21 18:15:41 snail kernel: NVRM: nvCheckFailedNoLog: Check failed: NV_OK == status @ virt_mem_allocator_gm107.c:2222
Jun 21 18:15:41 snail kernel: NVRM: dmaAllocMapping_GM107: can't update VA space for mapping @vaddr=0xdefa3d0000
Jun 21 18:15:41 snail kernel: NVRM: dmaAllocMapping_GM107: can't update VA space for mapping @vaddr=0xdefa360000
Jun 21 18:15:41 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: pMapNode->node.keyStart <= vaLo && pMapNode->node.keyEnd >= vaHi @ gpu_vaspace.c:4823
Jun 21 18:15:42 snail kernel: NVRM: nvCheckFailedNoLog: Check failed: 0 == (pMapNode->gpuMask & gpuMask) @ gpu_vaspace.c:4731
Jun 21 18:15:42 snail kernel: NVRM: nvCheckOkFailedNoLog: Check failed: Invalid argument to call [NV_ERR_INVALID_ARGUMENT] (0x0000001F) returned from _gvaspaceMappingInsert(pGVAS, pGpu, pVASBlock, vaLo, vaHi, flags) @ gpu_vaspace.c:2233
Jun 21 18:15:42 snail kernel: NVRM: nvCheckFailedNoLog: Check failed: NV_OK == status @ virt_mem_allocator_gm107.c:2222
Jun 21 18:15:42 snail kernel: NVRM: dmaAllocMapping_GM107: can't update VA space for mapping @vaddr=0xdefa3d0000
Jun 21 18:15:42 snail kernel: NVRM: dmaAllocMapping_GM107: can't update VA space for mapping @vaddr=0xdefa360000
Jun 21 18:15:42 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEF9C10000-0xDEF9C1FFFF!
Jun 21 18:15:42 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEF9BB0000-0xDEF9BCFFFF!
Jun 21 18:15:42 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3C0000-0xDEFA3CFFFF!
Jun 21 18:15:42 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEF9BD0000-0xDEF9BEFFFF!
Jun 21 18:15:42 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEF9BF0000-0xDEF9C0FFFF!
Jun 21 18:15:42 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA350000-0xDEFA35FFFF!
Jun 21 18:15:42 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEF9C20000-0xDEF9C2FFFF!
Jun 21 18:15:42 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:4815
Jun 21 18:15:42 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:2278
Jun 21 18:15:43 snail kernel: NVRM: nvCheckFailedNoLog: Check failed: 0 == (pMapNode->gpuMask & gpuMask) @ gpu_vaspace.c:4731
Jun 21 18:15:43 snail kernel: NVRM: nvCheckOkFailedNoLog: Check failed: Invalid argument to call [NV_ERR_INVALID_ARGUMENT] (0x0000001F) returned from _gvaspaceMappingInsert(pGVAS, pGpu, pVASBlock, vaLo, vaHi, flags) @ gpu_vaspace.c:2233
Jun 21 18:15:43 snail kernel: NVRM: nvCheckFailedNoLog: Check failed: NV_OK == status @ virt_mem_allocator_gm107.c:2222
Jun 21 18:15:43 snail kernel: NVRM: dmaAllocMapping_GM107: can't update VA space for mapping @vaddr=0xdefa3d0000
Jun 21 18:15:43 snail kernel: NVRM: dmaAllocMapping_GM107: can't update VA space for mapping @vaddr=0xdefa360000
Jun 21 18:15:43 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEF9C10000-0xDEF9C1FFFF!
Jun 21 18:15:43 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEF9BB0000-0xDEF9BCFFFF!
Jun 21 18:15:43 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3C0000-0xDEFA3CFFFF!
Jun 21 18:15:43 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEF9BD0000-0xDEF9BEFFFF!
Jun 21 18:15:43 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEF9BF0000-0xDEF9C0FFFF!
Jun 21 18:15:43 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA350000-0xDEFA35FFFF!
Jun 21 18:15:43 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEF9C20000-0xDEF9C2FFFF!
Jun 21 18:15:43 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:4815
Jun 21 18:15:43 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:2278
Jun 21 18:15:46 snail kernel: [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
Jun 21 18:15:47 snail xwayland-satellite[3588]:  2025-06-21T22:15:47.441Z INFO  xwayland_process                      > Error getting buffer
Jun 21 18:15:47 snail kernel: NVRM: nvCheckFailedNoLog: Check failed: 0 == (pMapNode->gpuMask & gpuMask) @ gpu_vaspace.c:4731
Jun 21 18:15:47 snail kernel: NVRM: nvCheckOkFailedNoLog: Check failed: Invalid argument to call [NV_ERR_INVALID_ARGUMENT] (0x0000001F) returned from _gvaspaceMappingInsert(pGVAS, pGpu, pVASBlock, vaLo, vaHi, flags) @ gpu_vaspace.c:2233
Jun 21 18:15:47 snail kernel: NVRM: nvCheckFailedNoLog: Check failed: NV_OK == status @ virt_mem_allocator_gm107.c:2222
Jun 21 18:15:47 snail kernel: NVRM: dmaAllocMapping_GM107: can't update VA space for mapping @vaddr=0xdefa360000
Jun 21 18:15:47 snail kernel: [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
Jun 21 18:15:47 snail xwayland-satellite[3588]:  2025-06-21T22:15:47.708Z INFO  xwayland_process                      > Error getting buffer
Jun 21 18:15:58 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3B0000-0xDEFA3BFFFF!
Jun 21 18:15:58 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3C0000-0xDEFA3CFFFF!
Jun 21 18:15:58 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3D0000-0xDEFA3EFFFF!
Jun 21 18:15:58 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:4815
Jun 21 18:15:58 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:2278
Jun 21 18:15:59 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3B0000-0xDEFA3BFFFF!
Jun 21 18:15:59 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3C0000-0xDEFA3CFFFF!
Jun 21 18:15:59 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3D0000-0xDEFA3EFFFF!
Jun 21 18:15:59 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:4815
Jun 21 18:15:59 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:2278
Jun 21 18:16:00 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3B0000-0xDEFA3BFFFF!
Jun 21 18:16:00 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3C0000-0xDEFA3CFFFF!
Jun 21 18:16:00 snail kernel: NVRM: intermapRegisterDmaMapping: Failed to insert new mapping node for range 0xDEFA3D0000-0xDEFA3EFFFF!
Jun 21 18:16:00 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:4815
Jun 21 18:16:00 snail kernel: NVRM: nvAssertFailedNoLog: Assertion failed: NV_OK == status @ gpu_vaspace.c:2278
Jun 21 18:16:00 snail kernel: [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
Jun 21 18:16:01 snail xwayland-satellite[3588]:  2025-06-21T22:16:01.442Z INFO  xwayland_process                      > Error getting buffer
