the same as what sample_cgf_dwchannel --cons=1 --prod=1 --downstreams=1 --dataType=custom do.
Actual behavior
nvidia@tegra-ubuntu:~/zhensheng/orin_ws/nv_driveworks_demo/target/aarch64/install/bin/common_cgf_channel$ ./dwchannel_test --cons=1 --prod=1 --downstreams=1 --dataType=custom
Creating channel with dataType: custom
[11-07-2023 13:34:31] Platform: Detected Drive Orin P3710
[11-07-2023 13:34:31] TimeSource: monotonic epoch time offset is 1688958463806737
[11-07-2023 13:34:31] TimeSourceVibranteLinux: detect valid PTP interface mgbe2_0
[11-07-2023 13:34:31] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to mgbe2_0
[11-07-2023 13:34:31] PTP Time is available from Eth Driver
[11-07-2023 13:34:31] Adding variable DW_Base:DW_Version
[11-07-2023 13:34:31] Added variable DW_Base:DW_Version
[11-07-2023 13:34:31] Platform: number of GPU devices detected 1
[11-07-2023 13:34:31] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_05_10_03, Arch: ga10b
[11-07-2023 13:34:31] Platform: currently selected GPU device integrated ID 0
[11-07-2023 13:34:31] CUDLAEngine:getDLACount: CUDLA version is = 1003000
[11-07-2023 13:34:31] CUDLAEngine:getDLACount: Number of DLA devices = 2
[11-07-2023 13:34:31] Context::mountResourceCandidateDataPath resource FAILED to mount from './resources': VirtualFileSystem: Failed to mount './resources/resources.pak'
[11-07-2023 13:34:31] Context::mountResourceCandidateDataPath resource FAILED to mount from '/home/nvidia/zhensheng/orin_ws/nv_driveworks_demo/target/aarch64/install/bin/common_cgf_channel/data': VirtualFileSystem: Failed to mount '/home/nvidia/zhensheng/orin_ws/nv_driveworks_demo/target/aarch64/install/bin/common_cgf_channel/data/resources.pak'
[11-07-2023 13:34:31] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks/data
[11-07-2023 13:34:31] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks/data': VirtualFileSystem: Failed to mount '/usr/local/driveworks/data/resources.pak'
[11-07-2023 13:34:31] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.10/data
[11-07-2023 13:34:31] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.10/data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.10/data/resources.pak'
[11-07-2023 13:34:31] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks/lib/libdw_base.so.5.10
[11-07-2023 13:34:31] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/targets/aarch64-Linux/lib/libdw_base.so.5.10
[11-07-2023 13:34:31] SDK: No resources(.pak) mounted, some modules will not function properly
[11-07-2023 13:34:31] egl::Display: found 1 EGL devices
[11-07-2023 13:34:31] egl::Display: use drm device: drm-nvdc
[11-07-2023 13:34:31] Initialize DriveWorks SDK v5.10.87
[11-07-2023 13:34:31] Release build with GNU 9.3.0 from buildbrain-branch-0-g9a5b4670e12 against Drive PDK v6.0.6.0
Creating channel with parameters: role=consumer,type=SOCKET,ip=127.0.0.1,id=40002,timeout=1000,fifo-size=4
[11-07-2023 13:34:31] ChannelSocket Consumer created to connect with Server127.0.0.1:40002
[11-07-2023 13:34:31] Add consumer[0]: role=consumer,type=SOCKET,ip=127.0.0.1,id=40002,timeout=1000,fifo-size=4, current consumer list size: 0
Creating channel with parameters: role=producer,type=SOCKET,ip=127.0.0.1,id=40002,num-clients=1,producer-fifo=1,fifo-size=4,timeout=1000
[11-07-2023 13:34:31] ChannelSocket Producer @ port:40002, BlockingConnectionCount=1
[11-07-2023 13:34:31] Driveworks exception thrown: DW_NOT_AVAILABLE: ChannelFactory makePacket: requested signature not registered id: 1024 channel type: 3
terminate called after throwing an instance of 'std::runtime_error'
what(): DW Error DW_NOT_AVAILABLE executing DW function:
m_outputPort->bindChannel(m_outputChannel.get())
at /gw_demo/modules/common/cgf_channel/tools/dwchannel_test.cpp:381
Aborted (core dumped)
Additional context
I think there is no obvious difference between dwchannel_test.cpp and driverorks-5.10/samples/src/dwchannel/main.cpp, but the behavior is really strange. Hope that the forum helps. Thanks.
Dear @lizhensheng,
there is no obvious difference between dwchannel_test.cpp and driverorks-5.10/samples/src/dwchannel/main.cpp , but the behavior is really strange
the original sample works with custom data type.
But I don’t see any difference between the codes from both side. Could you help to check with the code?
nvidia@tegra-ubuntu:~/zhensheng/orin_ws/nv_driveworks_demo/target/aarch64/install/bin/common_cgf_channel$ ./sample_cgf_dwchannel --cons=1 --prod=1 --downstreams=1 --dataType=custom
[12-07-2023 02:00:40] Platform: Detected Drive Orin P3710
[12-07-2023 02:00:40] TimeSource: monotonic epoch time offset is 1688958463806737
[12-07-2023 02:00:40] TimeSourceVibranteLinux: detect valid PTP interface mgbe2_0
[12-07-2023 02:00:40] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to mgbe2_0
[12-07-2023 02:00:40] PTP Time is available from Eth Driver
[12-07-2023 02:00:40] Adding variable DW_Base:DW_Version
[12-07-2023 02:00:40] Added variable DW_Base:DW_Version
[12-07-2023 02:00:40] Platform: number of GPU devices detected 1
[12-07-2023 02:00:40] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_05_10_03, Arch: ga10b
[12-07-2023 02:00:40] Platform: currently selected GPU device integrated ID 0
[12-07-2023 02:00:40] CUDLAEngine:getDLACount: CUDLA version is = 1003000
[12-07-2023 02:00:40] CUDLAEngine:getDLACount: Number of DLA devices = 2
[12-07-2023 02:00:40] Context::mountResourceCandidateDataPath resource FAILED to mount from './resources': VirtualFileSystem: Failed to mount './resources/resources.pak'
[12-07-2023 02:00:40] Context::mountResourceCandidateDataPath resource FAILED to mount from '/home/nvidia/zhensheng/orin_ws/nv_driveworks_demo/target/aarch64/install/bin/common_cgf_channel/data': VirtualFileSystem: Failed to mount '/home/nvidia/zhensheng/orin_ws/nv_driveworks_demo/target/aarch64/install/bin/common_cgf_channel/data/resources.pak'
[12-07-2023 02:00:40] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks/data
[12-07-2023 02:00:40] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks/data': VirtualFileSystem: Failed to mount '/usr/local/driveworks/data/resources.pak'
[12-07-2023 02:00:40] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.10/data
[12-07-2023 02:00:40] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.10/data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.10/data/resources.pak'
[12-07-2023 02:00:40] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks/lib/libdw_base.so.5.10
[12-07-2023 02:00:40] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/targets/aarch64-Linux/lib/libdw_base.so.5.10
[12-07-2023 02:00:40] SDK: No resources(.pak) mounted, some modules will not function properly
[12-07-2023 02:00:40] egl::Display: found 1 EGL devices
[12-07-2023 02:00:40] egl::Display: use drm device: drm-nvdc
[12-07-2023 02:00:40] Initialize DriveWorks SDK v5.10.87
[12-07-2023 02:00:40] Release build with GNU 9.3.0 from buildbrain-branch-0-g9a5b4670e12 against Drive PDK v6.0.6.0
[12-07-2023 02:00:40] ChannelSocket Consumer created to connect with Server127.0.0.1:40002
[12-07-2023 02:00:40] Add consumer[0]: role=consumer,type=SOCKET,ip=127.0.0.1,id=40002,timeout=1000,fifo-size=4, current consumer list size: 0
[12-07-2023 02:00:40] ChannelSocket Producer @ port:40002, BlockingConnectionCount=1
[12-07-2023 02:00:40] Initializing server socket for port 40002
[12-07-2023 02:00:40] SocketServer: listening on 40002
[12-07-2023 02:00:40] Server socket initialized for port 40002 server = 187651436113376
[12-07-2023 02:00:40] Add producer[0]: role=producer,type=SOCKET,ip=127.0.0.1,id=40002,num-clients=1,producer-fifo=1,fifo-size=4,timeout=1000, current producer list size: 0
[12-07-2023 02:00:40] ChannelConnector: thread 281473132509440 starting producer and consumer connect threads
[12-07-2023 02:00:40] ChannelConnector: started producer and consumer threads. producer tid=281472968431872, consumer tid=281472976824576
[12-07-2023 02:00:40] SocketClient: connected 127.0.0.1:40002
[12-07-2023 02:00:40] SocketServer(@port:40002): accepted 127.0.0.1:45561
[12-07-2023 02:00:40] Connection for port 40002 accepted; status=DW_SUCCESS(0)
[12-07-2023 02:00:40] Connection for port 40002 sent metadata
[12-07-2023 02:00:40] ChannelConnector: thread 281473132509440 stopping producer and consumer connect threads
[12-07-2023 02:00:40] Sending 96 bytes on port 40002
[12-07-2023 02:00:41] Sending 96 bytes on port 40002
Producer Send BandWidth: 0MB/s
Consumer Idx[0] Latency: 119us
Consumer Idx[0] Recv BandWidth: 0MB/s
[12-07-2023 02:00:41] Releasing Driveworks SDK Context
