Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
I tried to run the sample_denseopticalflow sample based on the entron camera (ar0820-rccb-bae-F008A120BM0A), but I am getting the below error, this is while when I tried it with Sekonix camera, it is working perfectly. Can you please help me with that? Thank you in advance.
sudo ./sample_denseopticalflow --input-type=camera --camera-type=ar0820-rccb-bae-F008A120BM0A
a-type=ar0820-rccb-bae-F008A120BM0A --estimationMode=UHP
[14-02-2022 15:41:11] Platform: Detected DDPX - Tegra A
[14-02-2022 15:41:11] TimeSource: monotonic epoch time offset is 1644451300181959
[14-02-2022 15:41:11] TimeSource Nvpss : PTP ioctl returned error. Synchronized time will not be available from this timesource.
[14-02-2022 15:41:11] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[14-02-2022 15:41:11] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[14-02-2022 15:41:11] TimeSource: Could not detect valid PTP time source at ‘eth0’. Fallback to CLOCK_MONOTONIC.
[14-02-2022 15:41:11] Platform: number of GPU devices detected 1
[14-02-2022 15:41:11] Platform: currently selected GPU device integrated ID 0
[14-02-2022 15:41:11] Platform: found 2 PVA engines
[14-02-2022 15:41:11] Context::getDataPathFromSelfLocation DATA_ROOT found at: /usr/local/driveworks-3.5/data
[14-02-2022 15:41:11] SDK: No resources(.pak) mounted, some modules will not function properly
[14-02-2022 15:41:11] SDK: Create NvMediaDevice
[14-02-2022 15:41:11] SDK: Create NvMedia2D
[14-02-2022 15:41:11] SDK: use EGL display as provided
[14-02-2022 15:41:11] Initialize DriveWorks SDK v3.5.75
[14-02-2022 15:41:11] Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gc61a9a35bd0 against Drive PDK v5.2.0.0
[14-02-2022 15:41:11] Initialize DriveWorks VisualizationSDK v3.5.75
[14-02-2022 15:41:11] Initialize DriveWorksGL SDK v3.5.75
[14-02-2022 15:41:11] SensorFactory::createSensor() → camera.gmsl, output-format=yuv,fifo-size=3,camera-type=ar0820-rccb-bae-F008A120BM0A,camera-group=a,slave=0
[14-02-2022 15:41:11] CameraGMSLSelector: missing siblingIndex to be able to map to new camera.gmsl parameter called link, assuming link 0
[14-02-2022 15:41:11] CameraGMSLSelector: note the name doesn’t correspond to the old supported cameras, DW will pass the name as is to the SIPL library. Please consider replacing camera-type with camera-name
[14-02-2022 15:41:11] CameraGMSLSelector: creating CameraClient from remapped old gmsl parameters to output-format=yuv,fifo-size=3,camera-type=ar0820-rccb-bae-F008A120BM0A,camera-group=a,slave=0,camera-name=ar0820-rccb-bae-F008A120BM0A,interface=csi-ab,link=0
[14-02-2022 15:41:11] CameraBase: pool size set to 8
[14-02-2022 15:41:11] SensorFactory::createSensor() → camera.gmsl.master,
[14-02-2022 15:41:11] CameraMaster::parseDevBlock Getting device info list.
[14-02-2022 15:41:11] devBlock: 1 Slave = 0 Interface = csi-ab Camera_name = ar0820-rccb-bae-F008A120BM0A Link = 0
[14-02-2022 15:41:11] Driveworks exception thrown: DW_INTERNAL_ERROR: CameraClient:allocateSIPLResources, no cameras created
terminate called after throwing an instance of ‘std::runtime_error’
what(): [2022-02-14 15:41:11] DW Error DW_INTERNAL_ERROR executing DW function:
dwSAL_createSensor(&m_camera, sensorParams, m_sal)
at /dvs/git/dirty/gitlab-master_av/dw/sdk/samples/imageprocessing/motion/denseopticalflow/main.cpp:166 → Cannot create virtual camera sensor, maybe wrong video file?
Aborted
nvidia@tegra-ubuntu:/usr/local/driveworks/bin$ sudo ./sample_denseopticalflow --input-type=camera --camera-type=ar0820-rccb-bae-F008A120BM0A --estimationMode=HQ
[14-02-2022 15:41:18] Platform: Detected DDPX - Tegra A
[14-02-2022 15:41:18] TimeSource: monotonic epoch time offset is 1644451300181959
[14-02-2022 15:41:18] TimeSource Nvpss : PTP ioctl returned error. Synchronized time will not be available from this timesource.
[14-02-2022 15:41:18] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[14-02-2022 15:41:18] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[14-02-2022 15:41:18] TimeSource: Could not detect valid PTP time source at ‘eth0’. Fallback to CLOCK_MONOTONIC.
[14-02-2022 15:41:18] Platform: number of GPU devices detected 1
[14-02-2022 15:41:18] Platform: currently selected GPU device integrated ID 0
[14-02-2022 15:41:18] Platform: found 2 PVA engines
[14-02-2022 15:41:18] Context::getDataPathFromSelfLocation DATA_ROOT found at: /usr/local/driveworks-3.5/data
[14-02-2022 15:41:18] SDK: No resources(.pak) mounted, some modules will not function properly
[14-02-2022 15:41:18] SDK: Create NvMediaDevice
[14-02-2022 15:41:18] SDK: Create NvMedia2D
[14-02-2022 15:41:18] SDK: use EGL display as provided
[14-02-2022 15:41:18] Initialize DriveWorks SDK v3.5.75
[14-02-2022 15:41:18] Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gc61a9a35bd0 against Drive PDK v5.2.0.0
[14-02-2022 15:41:18] Initialize DriveWorks VisualizationSDK v3.5.75
[14-02-2022 15:41:18] Initialize DriveWorksGL SDK v3.5.75
[14-02-2022 15:41:18] SensorFactory::createSensor() → camera.gmsl, output-format=yuv,fifo-size=3,camera-type=ar0820-rccb-bae-F008A120BM0A,camera-group=a,slave=0
[14-02-2022 15:41:18] CameraGMSLSelector: missing siblingIndex to be able to map to new camera.gmsl parameter called link, assuming link 0
[14-02-2022 15:41:18] CameraGMSLSelector: note the name doesn’t correspond to the old supported cameras, DW will pass the name as is to the SIPL library. Please consider replacing camera-type with camera-name
[14-02-2022 15:41:18] CameraGMSLSelector: creating CameraClient from remapped old gmsl parameters to output-format=yuv,fifo-size=3,camera-type=ar0820-rccb-bae-F008A120BM0A,camera-group=a,slave=0,camera-name=ar0820-rccb-bae-F008A120BM0A,interface=csi-ab,link=0
[14-02-2022 15:41:18] CameraBase: pool size set to 8
[14-02-2022 15:41:18] SensorFactory::createSensor() → camera.gmsl.master,
[14-02-2022 15:41:18] CameraMaster::parseDevBlock Getting device info list.
[14-02-2022 15:41:18] devBlock: 1 Slave = 0 Interface = csi-ab Camera_name = ar0820-rccb-bae-F008A120BM0A Link = 0
[14-02-2022 15:41:18] Driveworks exception thrown: DW_INTERNAL_ERROR: CameraClient:allocateSIPLResources, no cameras created
what(): [2022-02-14 15:41:18] DW Error DW_INTERNAL_ERROR executing DW function:
Aborted
[14-02-2022 15:43:51] Platform: Detected DDPX - Tegra A
[14-02-2022 15:43:51] TimeSource: monotonic epoch time offset is 1644451300181959
[14-02-2022 15:43:51] TimeSource Nvpss : PTP ioctl returned error. Synchronized time will not be available from this timesource.
[14-02-2022 15:43:51] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[14-02-2022 15:43:51] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[14-02-2022 15:43:51] TimeSource: Could not detect valid PTP time source at ‘eth0’. Fallback to CLOCK_MONOTONIC.
[14-02-2022 15:43:51] Platform: number of GPU devices detected 1
[14-02-2022 15:43:51] Platform: currently selected GPU device integrated ID 0
[14-02-2022 15:43:51] Platform: found 2 PVA engines
[14-02-2022 15:43:51] Context::getDataPathFromSelfLocation DATA_ROOT found at: /usr/local/driveworks-3.5/data
[14-02-2022 15:43:51] SDK: No resources(.pak) mounted, some modules will not function properly
[14-02-2022 15:43:51] SDK: Create NvMediaDevice
[14-02-2022 15:43:51] SDK: Create NvMedia2D
[14-02-2022 15:43:51] SDK: use EGL display as provided
[14-02-2022 15:43:51] Initialize DriveWorks SDK v3.5.75
[14-02-2022 15:43:51] Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gc61a9a35bd0 against Drive PDK v5.2.0.0
[14-02-2022 15:43:51] Initialize DriveWorks VisualizationSDK v3.5.75
[14-02-2022 15:43:51] Initialize DriveWorksGL SDK v3.5.75
[14-02-2022 15:43:51] SensorFactory::createSensor() → camera.gmsl, output-format=yuv,fifo-size=3,camera-type=ar0820-rccb-bae-F008A120BM0A,camera-group=a,slave=0
[14-02-2022 15:43:51] CameraGMSLSelector: missing siblingIndex to be able to map to new camera.gmsl parameter called link, assuming link 0
[14-02-2022 15:43:51] CameraGMSLSelector: note the name doesn’t correspond to the old supported cameras, DW will pass the name as is to the SIPL library. Please consider replacing camera-type with camera-name
[14-02-2022 15:43:51] CameraGMSLSelector: creating CameraClient from remapped old gmsl parameters to output-format=yuv,fifo-size=3,camera-type=ar0820-rccb-bae-F008A120BM0A,camera-group=a,slave=0,camera-name=ar0820-rccb-bae-F008A120BM0A,interface=csi-ab,link=0
[14-02-2022 15:43:51] CameraBase: pool size set to 8
[14-02-2022 15:43:51] SensorFactory::createSensor() → camera.gmsl.master,
[14-02-2022 15:43:51] CameraMaster::parseDevBlock Getting device info list.
[14-02-2022 15:43:51] devBlock: 1 Slave = 0 Interface = csi-ab Camera_name = ar0820-rccb-bae-F008A120BM0A Link = 0
[14-02-2022 15:43:51] Driveworks exception thrown: DW_INTERNAL_ERROR: CameraClient:allocateSIPLResources, no cameras created
what(): [2022-02-14 15:43:51] DW Error DW_INTERNAL_ERROR executing DW function:
