Managed to copy the file to my home directory and change the permissions however still the errors persist:
root@tegra-ubuntu:/usr/local/driveworks-5.10/tools/capture# ./recorder /home/pomo/release_test.json
[07-08-2024 11:37:56] Platform: Detected Drive Orin P3710
[07-08-2024 11:37:56] TimeSource: monotonic epoch time offset is 1723015431745165
[07-08-2024 11:37:56] TimeSourceVibranteLinux: detect valid PTP interface mgbe2_0
[07-08-2024 11:37:56] TimeSource Nvpss : PTP ioctl returned error. Synchronized time will not be available from this timesource.
[07-08-2024 11:37:56] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to mgbe2_0
[07-08-2024 11:37:56] PTP Time is available from Eth Driver
[07-08-2024 11:37:56] Platform: currently selected GPU device integrated ID 0
[07-08-2024 11:37:56] Context::mountResourceCandidateDataPath resource FAILED to mount from './resources': VirtualFileSystem: Failed to mount './resources/resources.pak'
[07-08-2024 11:37:56] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.10/tools/capture/data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.10/tools/capture/data/resources.pak'
[07-08-2024 11:37:56] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.10/tools/capture/../../data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.10/tools/capture/../../data/resources.pak'
[07-08-2024 11:37:56] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.10/data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.10/data/resources.pak'
[07-08-2024 11:37:56] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/tools/capture/../../targets/aarch64-Linux/lib/libdw_base.so.5.10
[07-08-2024 11:37:56] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/targets/aarch64-Linux/lib/libdw_base.so.5.10
[07-08-2024 11:37:56] SDK: No resources(.pak) mounted, some modules will not function properly
[07-08-2024 11:37:56] egl::Display: found 1 EGL devices
[07-08-2024 11:37:56] egl::Display: use drm device: drm-nvdc
[07-08-2024 11:37:56] Initialize DriveWorks SDK v5.10.87
[07-08-2024 11:37:56] Release build with GNU 9.3.0 from buildbrain-branch-0-g9a5b4670e12 against Drive PDK v6.0.6.0
[07-08-2024 11:37:56] Rig overlay directory does not exist: /storage/driveworks/data/vehicle_cfg
[07-08-2024 11:37:56] rig::DatabaseOverlayer: Failed to open a file '/tmp/car_vin' - file likely does not exist - skipping overlay
[07-08-2024 11:37:56] RigConfiguration: loading dwGenericVehicle from a rig that does not contain the drive-by-wire second order dynamics. Ignoring the second-order dynamic values.
[07-08-2024 11:37:56] No valid data file found for camera:front:center:120fov in parameter string: camera-name=SF3325,interface=csi-a,link=0,output-format=raw+processed,fifo-size=1,warn-per-frame=0,skip-eeprom=1 (using configuration folder /home/pomo/)
[07-08-2024 11:37:56] No valid data file found for camera:front:center:60fov in parameter string: camera-name=SF3325,interface=csi-a,link=1,output-format=raw+processed,fifo-size=1,warn-per-frame=0,skip-eeprom=1 (using configuration folder /home/pomo/)
[07-08-2024 11:37:56] No valid data file found for can:vehicle in parameter string: device=can0 (using configuration folder /home/pomo/)
[07-08-2024 11:37:56] No valid data file found for gps:xsens in parameter string: device=/dev/ttyUSB0,baudrate=230400,stop-bits=1,slave=true,file-buffer-size=8192,index_table=off (using configuration folder /home/pomo/)
[07-08-2024 11:37:56] No valid data file found for imu:xsens in parameter string: device=/dev/ttyUSB0,baudrate=230400,stop-bits=1,slave=true,file-buffer-size=8192,index_table=off (using configuration folder /home/pomo/)
[07-08-2024 11:37:56] No valid data file found for radar:front:center in parameter string: device=CONTINENTAL_ARS430,ip=10.1.1.20,port=40000,multicast-ip=239.0.0.1,time-smoothing=false,slave=true,file-buffer-size=4194304 (using configuration folder /home/pomo/)
[07-08-2024 11:37:56] SensorFactory::createSensor() -> time.nvpps, nvpps-device=/dev/nvpps0
[07-08-2024 11:37:56] TimeSensor: failed to set NVPPS parameters. Error: Invalid argument
[07-08-2024 11:37:56] This platform does not support NVPPS GPIO mode. Fallback to timer mode
[07-08-2024 11:37:56] TimeSensor: initialized with no UTC time reference.
[07-08-2024 11:37:56] EndpointNVPPS: started on /dev/nvpps0
[07-08-2024 11:37:56] SensorFactory::createSensor() -> camera.gmsl, camera-name=SF3325,interface=csi-a,link=0,output-format=raw+processed,fifo-size=1,warn-per-frame=0,skip-eeprom=1
[07-08-2024 11:37:56] SensorFactory::createSensor() -> camera.gmsl.master,
[07-08-2024 11:37:56] CameraMaster::parseDevBlock Getting device info list.
[07-08-2024 11:37:56] devBlock: 0 Slave = 0 Interface = csi-a Camera_name = SF3325 Link = 0 GroupInit = 0 RecCfg = 1
[07-08-2024 11:37:56] Camera Match Name: SF3325 Description: Sekonix SF3325 module - 60-deg FOV, DVP AR0231-RCCB, MAX96705 linkIndex: 4294967295 serInfo.Name: MAX96705
[07-08-2024 11:37:56] Client, Setting up information for camera ID 0
[07-08-2024 11:37:56] Client, successfully found info for camera ID 0 bound to id 0
[07-08-2024 11:37:56] CameraClient: using NITO found at /usr/share/camera/SF3325.nito
[07-08-2024 11:37:56] SensorFactory::createSensor() -> camera.gmsl, camera-name=SF3325,interface=csi-a,link=1,output-format=raw+processed,fifo-size=1,warn-per-frame=0,skip-eeprom=1
[07-08-2024 11:37:56] devBlock: 0 Slave = 0 Interface = csi-a Camera_name = SF3325 Link = 1 GroupInit = 0 RecCfg = 1
[07-08-2024 11:37:56] Client, Setting up information for camera ID 1
[07-08-2024 11:37:56] Client, successfully found info for camera ID 1 bound to id 1
[07-08-2024 11:37:56] SensorFactory::createSensor() -> can.socket, device=can0
[07-08-2024 11:37:56] CANSocket: cannot connect to CAN, network is down
[07-08-2024 11:37:56] SensorManager::addSensor DW_HAL_CANNOT_OPEN_CHANNEL: CANSocket: socket error 100
[07-08-2024 11:37:56] SensorManager::addSensorsFromRig() failed to add sensor from rig: can.socket device=can0 (Error: DW_HAL_CANNOT_OPEN_CHANNEL)
[07-08-2024 11:37:58] CameraClient: Stopping client
terminate called after throwing an instance of 'dw::core::Exception'
what(): DW_HAL_CANNOT_OPEN_CHANNEL: SensorManager::SensorManager() Failed to add sensors from rig
Aborted
