nvidia@tegra-ubuntu:/usr/local/driveworks/tools/capture$ sudo ./recorder-tui /home/nvidia/go/192.168.1.30.json
./recorder-tui:1296: SyntaxWarning: “is” with a literal. Did you mean “==”?
if hostname is “local”:
./recorder-tui:1310: SyntaxWarning: “is not” with a literal. Did you mean “!=”?
if hostname is not “local”:
running recorder-tui with arguments: Namespace(aes_key=None, aes_key_encrypted=None, backend=False, bbr=False, description=‘’, disable_encryption=True, enable_encryption=False,
lane_id=None, log_dir_path=‘/tmp’, login_id=None, no_mount_check=False, no_sudo=False, non_interaction=False, remote_dw_path=‘’, rig=‘/home/nvidia/go/192.168.1.30.json’, route=N
one, rsa_key=‘/home/nvidia/.ssh/recorder-aiinfra.pem’, rsa_key_md5=None, skip_init_input=False, tag=‘NONE’)
./recorder-tui:250: DeprecationWarning: tostring() is deprecated. Use tobytes() instead.
if ip_addr.replace(“.”, “”, 3).isnumeric() and (not utils.checkLocalIP(ip_addr)):
[15-03-2024 13:05:03] TimeSource Nvpss : PTP ioctl returned error. Synchronized time will not be available from this timesource.
[15-03-2024 13:05:03] SDK: No resources(.pak) mounted from ‘/usr/local/driveworks-5.10/data’. Please adjust path or some modules won’t function properly.
Copying rigs and setup code for local…
Platform setup for local…
[ 5500.893288] nvpps nvpps0: unable to switch mode. Only timer mode is supported
192.168.1.30.json: Backend abruptly exited in waitForRecorderToStart
Cleanup started …
Waiting (timeout=30s) for child process 1/1 to exit cleanly…
Cleaning up sensor initializers …
Performing platform recorder cleanup, if found …
Errors detected during recording
First 100 lines of std error log:
/usr/local/driveworks-5.10/tools/capture/recorder-tui:1296: SyntaxWarning: “is” with a literal. Did you mean “==”?
/usr/local/driveworks-5.10/tools/capture/recorder-tui:1310: SyntaxWarning: “is not” with a literal. Did you mean “!=”?
/usr/local/driveworks-5.10/tools/capture/recorder-tui:250: DeprecationWarning: tostring() is deprecated. Use tobytes() instead.
[15-03-2024 13:05:03] Platform: Detected Drive Orin P3710
[15-03-2024 13:05:03] TimeSource: monotonic epoch time offset is 1710516803147972
[15-03-2024 13:05:03] TimeSourceVibranteLinux: detect valid PTP interface mgbe2_0
[15-03-2024 13:05:03] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to mgbe2_0
[15-03-2024 13:05:03] PTP Time is available from Eth Driver
[15-03-2024 13:05:04] Platform: currently selected GPU device integrated ID 0
[15-03-2024 13:05:04] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘./resources’: VirtualFileSystem: Failed to mount ‘./resources/resources.pak’
[15-03-2024 13:05:04] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/tmp/recorder-4607/data’: VirtualFileSystem: Failed to mount ‘/tmp/recorder-4607/dat
a/resources.pak’
[15-03-2024 13:05:04] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.10/tools/capture/…/…/data’: VirtualFileSystem: Failed to m
ount ‘/usr/local/driveworks-5.10/tools/capture/…/…/data/resources.pak’
[15-03-2024 13:05:04] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.10/data’: VirtualFileSystem: Failed to mount ‘/usr/local/dri
veworks-5.10/data/resources.pak’
[15-03-2024 13:05:04] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/tools/captur
e/…/…/targets/aarch64-Linux/lib/libdw_base.so.5.10
[15-03-2024 13:05:04] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/targets/aarc
[15-03-2024 13:05:04] SDK: No resources(.pak) mounted, some modules will not function properly
[15-03-2024 13:05:04] egl::Display: found 1 EGL devices
[15-03-2024 13:05:04] egl::Display: use drm device: drm-nvdc
[15-03-2024 13:05:04] TimeSource: monotonic epoch time offset is 1710516803147973
[15-03-2024 13:05:04] TimeSourceVibranteLinux: detect valid PTP interface mgbe2_0
[15-03-2024 13:05:04] TimeSource Nvpss : PTP ioctl returned error. Synchronized time will not be available from this timesource.
[15-03-2024 13:05:04] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to mgbe2_0
[15-03-2024 13:05:04] PTP Time is available from Eth Driver
[15-03-2024 13:05:04] Initialize DriveWorks SDK v5.10.87
[15-03-2024 13:05:04] Release build with GNU 9.3.0 from buildbrain-branch-0-g9a5b4670e12 against Drive PDK v6.0.6.0
[15-03-2024 13:05:04] Rig overlay directory does not exist: /storage/driveworks/data/vehicle_cfg
[15-03-2024 13:05:04] rig::DatabaseOverlayer: Failed to open a file ‘/tmp/car_vin’ - file likely does not exist - skipping overlay
[15-03-2024 13:05:04] No valid data file found for RSWL_IMX490 in parameter string: camera-name=IMX490_RGGB,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,frame-mod
=3,format=h265,isp-mode=yuv420-uint8,nito-file=/usr/share/camera/IMX490_RGGB_FoV120.nito (using configuration folder /tmp/recorder-4607/)
[15-03-2024 13:05:04] No valid data file found for FSWL_IMX490 in parameter string: camera-name=IMX490_RGGB,interface=csi-ab,CPHY-mode=1,link=1,output-format=processed,frame-mod
[15-03-2024 13:05:04] No valid data file found for FSWR_IMX490 in parameter string: camera-name=IMX490_RGGB,interface=csi-ab,CPHY-mode=1,link=2,output-format=processed,frame-mod
[15-03-2024 13:05:04] No valid data file found for RSWR_IMX490 in parameter string: camera-name=IMX490_RGGB,interface=csi-ab,CPHY-mode=1,link=3,output-format=processed,frame-mod
[15-03-2024 13:05:04] No valid data file found for AVM_Left_IMX623 in parameter string: camera-name=IMX623_RGGB,interface=csi-ef,CPHY-mode=1,link=0,output-format=processed,frame
-mod=3,format=h265,isp-mode=yuv420-uint8,nito-file=/usr/share/camera/IMX623_RGGB.nito (using configuration folder /tmp/recorder-4607/)
[15-03-2024 13:05:04] No valid data file found for AVM_Right_IMX623 in parameter string: camera-name=IMX623_RGGB,interface=csi-ef,CPHY-mode=1,link=1,output-format=processed,fram
e-mod=3,format=h265,isp-mode=yuv420-uint8,nito-file=/usr/share/camera/IMX623_RGGB.nito (using configuration folder /tmp/recorder-4607/)
[15-03-2024 13:05:04] SensorFactory::createSensor() → time.nvpps, nvpps-device=/dev/nvpps0
[15-03-2024 13:05:04] TimeSensor: failed to set NVPPS parameters. Error: Invalid argument
[15-03-2024 13:05:04] This platform does not support NVPPS GPIO mode. Fallback to timer mode
[15-03-2024 13:05:04] TimeSensor: initialized with no UTC time reference.
[15-03-2024 13:05:04] EndpointNVPPS: started on /dev/nvpps0
[15-03-2024 13:05:04] SensorFactory::createSensor() → camera.gmsl, camera-name=IMX490_RGGB,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,frame-mod=3,format=h265,i
[15-03-2024 13:05:04] SensorFactory::createSensor() → camera.gmsl.master,
[15-03-2024 13:05:04] CameraMaster::parseDevBlock Getting device info list.
[15-03-2024 13:05:04] CameraClient, setting isp-mode to yuv420-uint8
[15-03-2024 13:05:04] CameraClient, isp-mode set to yuv420-uint8
[15-03-2024 13:05:04] devBlock: 0 Slave = 0 Interface = csi-ab Camera_name = IMX490_RGGB Link = 0 GroupInit = 0 RecCfg = 1
[15-03-2024 13:05:04] Camera Match Name: IMX490_RGGB Description: Sony IMX490 RGGB module - 120-deg FOV, MIPI-IMX490, MAX9295 linkIndex: 4294967295 serInfo.Name: MAX9295
[15-03-2024 13:05:04] Client, Setting up information for camera ID 0
[15-03-2024 13:05:04] Client, successfully found info for camera ID 0 bound to id 0
[15-03-2024 13:05:04] CameraClient: using NITO found at /usr/share/camera/IMX490_RGGB_FoV120.nito
[15-03-2024 13:05:04] SensorFactory::createSensor() → camera.gmsl, camera-name=IMX490_RGGB,interface=csi-ab,CPHY-mode=1,link=1,output-format=processed,frame-mod=3,format=h265,i
[15-03-2024 13:05:04] devBlock: 0 Slave = 0 Interface = csi-ab Camera_name = IMX490_RGGB Link = 1 GroupInit = 0 RecCfg = 1
[15-03-2024 13:05:04] Client, Setting up information for camera ID 1
[15-03-2024 13:05:04] Client, successfully found info for camera ID 1 bound to id 1
[15-03-2024 13:05:04] SensorFactory::createSensor() → camera.gmsl, camera-name=IMX490_RGGB,interface=csi-ab,CPHY-mode=1,link=2,output-format=processed,frame-mod=3,format=h265,i
[15-03-2024 13:05:04] devBlock: 0 Slave = 0 Interface = csi-ab Camera_name = IMX490_RGGB Link = 2 GroupInit = 0 RecCfg = 1
[15-03-2024 13:05:04] Client, Setting up information for camera ID 2
[15-03-2024 13:05:04] Client, successfully found info for camera ID 2 bound to id 2
[15-03-2024 13:05:04] SensorFactory::createSensor() → camera.gmsl, camera-name=IMX490_RGGB,interface=csi-ab,CPHY-mode=1,link=3,output-format=processed,frame-mod=3,format=h265,i
[15-03-2024 13:05:04] devBlock: 0 Slave = 0 Interface = csi-ab Camera_name = IMX490_RGGB Link = 3 GroupInit = 0 RecCfg = 1
[15-03-2024 13:05:04] Client, Setting up information for camera ID 3
[15-03-2024 13:05:04] Client, successfully found info for camera ID 3 bound to id 3
[15-03-2024 13:05:04] SensorFactory::createSensor() → camera.gmsl, camera-name=IMX623_RGGB,interface=csi-ef,CPHY-mode=1,link=0,output-format=processed,frame-mod=3,format=h265,i
[15-03-2024 13:05:04] devBlock: 1 Slave = 0 Interface = csi-ef Camera_name = IMX623_RGGB Link = 0 GroupInit = 0 RecCfg = 1
[15-03-2024 13:05:04] Camera Match Name: IMX623_RGGB Description: Sony IMX623 RGGB module - 120-deg FOV, MIPI-IMX623, MAX96717F linkIndex: 4294967295 serInfo.Name: MAX96717F
[15-03-2024 13:05:04] Client, Setting up information for camera ID 4
[15-03-2024 13:05:04] Client, successfully found info for camera ID 4 bound to id 4
[15-03-2024 13:05:04] CameraClient: using NITO found at /usr/share/camera/IMX623_RGGB.nito
[15-03-2024 13:05:04] SensorFactory::createSensor() → camera.gmsl, camera-name=IMX623_RGGB,interface=csi-ef,CPHY-mode=1,link=1,output-format=processed,frame-mod=3,format=h265,i
[15-03-2024 13:05:04] devBlock: 1 Slave = 0 Interface = csi-ef Camera_name = IMX623_RGGB Link = 1 GroupInit = 0 RecCfg = 1
[15-03-2024 13:05:04] Client, Setting up information for camera ID 5
[15-03-2024 13:05:04] Client, successfully found info for camera ID 5 bound to id 5
[15-03-2024 13:05:04] SIPLMaster::SIPLMaster: Setting up master camera
[15-03-2024 13:05:04] CameraMaster available outputs: 1
First 100 lines of std out log:
running recorder-tui with arguments: Namespace(aes_key=None, aes_key_encrypted=None, backend=True, bbr=False, description=‘’, disable_encryption=True, enable_encryption=False, l
ane_id=None, log_dir_path=‘/tmp’, login_id=None, no_mount_check=False, no_sudo=False, non_interaction=False, remote_dw_path=‘’, rig=‘/tmp/recorder-4607/192.168.1.30.json’, route
=None, rsa_key=‘/home/nvidia/.ssh/recorder-aiinfra.pem’, rsa_key_md5=None, skip_init_input=False, tag=‘NONE’)
Rig: 192.168.1.30.json recorder-tui: started
MAX96712: Revision 5 detected
MAX96712 Link 0: PHY optimization was enabled
MAX96712 Link 1: PHY optimization was enabled
MAX96712 Link 2: PHY optimization was enabled
MAX96712 Link 3: PHY optimization was enabled
Rig: 192.168.1.30.json CurrentMount: /media/sda1_ssd
Rig: 192.168.1.30.json Rollover: 1
Rig: 192.168.1.30.json EndOfMountsInfo
Rig: 192.168.1.30.json Error: recorder exited abnormally: cannot send cmd
When reporting bugs, please attach full log and files /tmp/recorder-tui-4607/.log and /tmp/recorder-4607/.log
WARNING: Forcibly exited. Some data might have been lost!
WARNING: Use q to exit gracefully, next time.
here is the log
