Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I am using the driveworks sample_camera application for quanta camera. I have updated the rig.json accordingly.
I was successfully able to run nvsipl_camera and record in raw,yuv formats.
But when I run driveworks, i face this problem
nvidia@tegra-ubuntu:/usr/local/driveworks/samples/bin$ ./sample_camera --offscreen=2
sample_camera !
dw_samples::SamplesDataPath::get() : /usr/local/driveworks-5.10/data
ProgramArguments: Missing argument ‘dwTracePath’ requested
WindowEGL: find EGL devices
WindowEGL: found 1 EGL devices
WindowEGL: init EGL with GLES3 context
WindowEGL: bind OpenGLES3 API
WindowEGL: offscreen mode → use EGL PBuffer surface 1280x800
WindowEGL: create EGL context
WindowEGL: assign EGL context to current thread
[04-10-2023 12:26:35] Platform: Detected Drive Orin P3710
[04-10-2023 12:26:35] TimeSource: monotonic epoch time offset is 1696407401634844
[04-10-2023 12:26:35] TimeSourceVibranteLinux: detect valid PTP interface mgbe2_0
[04-10-2023 12:26:35] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to mgbe2_0
[04-10-2023 12:26:35] PTP Time is available from Eth Driver
[04-10-2023 12:26:35] Adding variable DW_Base:DW_Version
[04-10-2023 12:26:35] Added variable DW_Base:DW_Version
[04-10-2023 12:26:35] Platform: number of GPU devices detected 1
[04-10-2023 12:26:35] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_05_10_03, Arch: ga10b
[04-10-2023 12:26:35] Platform: currently selected GPU device integrated ID 0
[04-10-2023 12:26:35] CUDLAEngine:getDLACount: CUDLA version is = 1003000
[04-10-2023 12:26:35] CUDLAEngine:getDLACount: Number of DLA devices = 2
[04-10-2023 12:26:35] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘./resources’: VirtualFileSystem: Failed to mount ‘./resources/resources.pak’
[04-10-2023 12:26:35] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.10/samples/bin/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.10/samples/bin/data/resources.pak’
[04-10-2023 12:26:35] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks/data
[04-10-2023 12:26:35] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks/data/resources.pak’
[04-10-2023 12:26:35] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.10/data
[04-10-2023 12:26:35] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.10/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.10/data/resources.pak’
[04-10-2023 12:26:35] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks/lib/libdw_base.so.5.10
[04-10-2023 12:26:35] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/targets/aarch64-Linux/lib/libdw_base.so.5.10
[04-10-2023 12:26:35] SDK: No resources(.pak) mounted, some modules will not function properly
[04-10-2023 12:26:35] SDK: use EGL display as provided
[04-10-2023 12:26:35] Initialize DriveWorks SDK v5.10.87
[04-10-2023 12:26:35] Release build with GNU 9.3.0 from buildbrain-branch-0-g9a5b4670e12 against Drive PDK v6.0.6.0
[04-10-2023 12:26:35] SensorFactory::createSensor() → time.nvpps, nvpps-device=/dev/nvpps0
[04-10-2023 12:26:35] Can not create time sensor: DW_HAL_CANNOT_OPEN_CHANNEL: EndpointNVPPS: cannot open NVPPS device with name: /dev/nvpps0
Error: Permission denied
[04-10-2023 12:26:35] fromFile: Loading rig file: /usr/local/driveworks-5.10/data/samples/sensors/camera/camera/rig.json
[04-10-2023 12:26:35] rig::DatabaseOverlayer: Failed to open a file ‘/tmp/car_vin’ - file likely does not exist - skipping overlay
[04-10-2023 12:26:35] No valid data file found for camera:sample3 in parameter string: camera-name=HZKJ_IMX728_ES2_V2_120FOV,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216 (using configuration folder /usr/local/driveworks-5.10/data/samples/sensors/camera/camera/)
onInitialize: creating camera.gmsl with params: camera-name=HZKJ_IMX728_ES2_V2_120FOV,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216
[04-10-2023 12:26:35] SensorFactory::createSensor() → camera.gmsl, camera-name=HZKJ_IMX728_ES2_V2_120FOV,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216
[04-10-2023 12:26:35] CameraBase: pool size set to 8
[04-10-2023 12:26:35] SensorFactory::createSensor() → camera.gmsl.master,
[04-10-2023 12:26:35] CameraMaster::parseDevBlock Getting device info list.
[04-10-2023 12:26:35] devBlock: 0 Slave = 0 Interface = csi-ab Camera_name = HZKJ_IMX728_ES2_V2_120FOV Link = 0 GroupInit = 0 RecCfg = 1
[04-10-2023 12:26:35] Camera Match Name: HZKJ_IMX728_ES2_V2_120FOV Description: QUANTA IMX728 ES2 V2 RGGB module - 120-deg FOV, MIPI-IMX728, MAX96717 linkIndex: 4294967295 serInfo.Name: MAX96717F
[04-10-2023 12:26:35] Client, Setting up information for camera ID 0
[04-10-2023 12:26:35] Client, successfully found info for camera ID 0 bound to id 0
[04-10-2023 12:26:35] ImageStreamer(NvMedia → CUDA)
[04-10-2023 12:26:35] CameraClient: using NITO found at /usr/share/camera/HZKJ_IMX728_ES2_V2_120FOV.nito
[04-10-2023 12:26:35] SIPLMaster::SIPLMaster: Setting up master camera
[04-10-2023 12:26:35] Platform Config:
[04-10-2023 12:26:35] Description:
[04-10-2023 12:26:35] Number of device blocks: 1
[04-10-2023 12:26:35] Device Block : 0
[04-10-2023 12:26:35] csiPort: 2
[04-10-2023 12:26:35] i2cDevice: 0
[04-10-2023 12:26:35] Deserializer Name: MAX96712
[04-10-2023 12:26:35] Deserializer Description: Maxim 96712 Aggregator
[04-10-2023 12:26:35] Deserializer i2cAddress: 41
[04-10-2023 12:26:35] Simulator Mode: 0
[04-10-2023 12:26:35] Passive Mode: 0
[04-10-2023 12:26:35] Phy Mode: 1
[04-10-2023 12:26:35] Number of camera modules: 1
[04-10-2023 12:26:35] CameraModule index: 0
[04-10-2023 12:26:35] Name :HZKJ_IMX728_ES2_V2_120FOV
[04-10-2023 12:26:35] Description: QUANTA IMX728 ES2 V2 RGGB module - 120-deg FOV, MIPI-IMX728, MAX96717
[04-10-2023 12:26:35] Serializer name: MAX96717F
[04-10-2023 12:26:35] Serializer description: Maxim 96717F Serializer
[04-10-2023 12:26:35] Serializer i2cAdress: 64
[04-10-2023 12:26:35] EEPROM name: N24C64
[04-10-2023 12:26:35] EEPROM i2cAddress: 84
[04-10-2023 12:26:35] EEPROM description: N24C64 64-Kbit serial I2C EEPROM
[04-10-2023 12:26:35] Sensor ID: 0
[04-10-2023 12:26:35] Sensor name: IMX728
[04-10-2023 12:26:35] Sensor description: Sony IMX728 Sensor
[04-10-2023 12:26:35] Sensor i2cAddress: 28
[04-10-2023 12:26:35] Sensor isTPGEnabled: 0
[04-10-2023 12:26:35] Sensor isTriggerMode: 1
[04-10-2023 12:26:35] cfa: 33
[04-10-2023 12:26:35] embeddedTopLines: 1
[04-10-2023 12:26:35] embeddedBottomLines: 20
[04-10-2023 12:26:35] inputFormat: 8
[04-10-2023 12:26:35] height: 2160
[04-10-2023 12:26:35] width: 3840
[04-10-2023 12:26:35] fps: 30.000000
[04-10-2023 12:26:35] Embedded Data: 0
[04-10-2023 12:26:35] CameraMaster available outputs: 1
[04-10-2023 12:26:35] CameraClient: setting pipeline config for camera ID 0
[04-10-2023 12:26:35] CameraMaster: master initiation
MAX96712: Revision 5 detected
MAX96712 Link 0: PHY optimization was enabled
[04-10-2023 12:26:36] CameraMaster: master init failed with status = 10
[04-10-2023 12:26:36] Driveworks exception thrown: DW_UNEXPECTED_EVENT: CameraMaster::bootstrap failed with sipl status 10
terminate called after throwing an instance of ‘std::runtime_error’
what(): [2023-10-04 12:26:36] DW Error DW_UNEXPECTED_EVENT executing DW function:
dwSAL_start(m_sal)
at /usr/local/driveworks/samples/src/sensors/camera/camera/main.cpp:363
Aborted (core dumped)
