[BUG] target-docker-container running driveworks sample_camera failed
Required Info:
  • Software Version
    DRIVE OS 6.0.6
  • Target OS
    Linux
  • SDK Manager Version
    1.9.2.10884
  • Host Machine Version
    native Ubuntu Linux 20.04 Host installed with DRIVE OS DOCKER Containers
Describe the bug
following with this topic Running Docker Containers Directly on NVIDIA DRIVE AGX Orin | NVIDIA Technical Blog.
and this topic [BUG] target-docker-container running driveworks sample_hello_world failed
in target-docker-container, /usr/local/driveworks/bin/sample_camera failed with many errors.
To Reproduce
# start and into the container
./docker/run/orin_start.sh
./docker/run/orin_into.sh
the csv in /etc/nvidia-container-runtime/host-files-for-container.d/ is from here
https://github.com/ZhenshengLee/nv_driveworks_demo/blob/main/docker/run/
the keypoint of orin_start.sh is
docker run --runtime nvidia --gpus all -it -d --privileged --name gw_orin_20.04_nvidia -e DOCKER_USER=nvidia -e USER=nvidia -e DOCKER_USER_ID=1000 -e DOCKER_GRP=nvidia -e DOCKER_GRP_ID=1000 -e DOCKER_IMG=arm64v8/ros:foxy -e USE_GPU=1 -e NVIDIA_VISIBLE_DEVICES=all -e NVIDIA_DRIVER_CAPABILITIES=compute,graphics,video,utility,display -e NVIDIA_REQUIRE_JETPACK=csv-mounts=all -e DISPLAY=:1 -v /home/nvidia/zhensheng/orin_ws/nv_driveworks_demo/target:/target -v /dev:/dev -v /home/nvidia/zhensheng/cuda-sample:/home/nvidia/zhensheng/cuda-sample -v /home/nvidia/.cache:/home/nvidia/.cache -v /dev/bus/usb:/dev/bus/usb -v /media:/media -v /tmp/.X11-unix:/tmp/.X11-unix:rw -v /etc/localtime:/etc/localtime:ro -v /usr/src:/usr/src -v /lib/mgaules:/lib/mgaules --ulimit nofile=32768:32768 --ulimit msgqueue=2097152:2097152 -v /etc/nvsciipc.cfg:/etc/nvsciipc.cfg --net host --ipc host --cap-add SYS_ADMIN --cap-add SYS_PTRACE -w /target --add-host in_orin_docker:127.0.0.1 --add-host tegra-ubuntu:127.0.0.1 --hostname in_orin_docker --shm-size 2G -v /dev/null:/dev/raw1394 arm64v8/ros:foxy /bin/bash
the rig.json is edited and the camera with eligible module is connected.
Expected behavior
# in target-orin-host
ProgramArguments: Missing argument 'dwTracePath' requested
[21-05-2023 19:11:18] Platform: Detected Drive Orin P3710
[21-05-2023 19:11:18] TimeSource: monotonic epoch time offset is 1684599544108287
[21-05-2023 19:11:18] TimeSourceVibranteLinux: detect valid PTP interface mgbe2_0
[21-05-2023 19:11:18] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to mgbe2_0
[21-05-2023 19:11:18] PTP Time is available from Eth Driver
[21-05-2023 19:11:18] Adding variable DW_Base:DW_Version
[21-05-2023 19:11:18] Added variable DW_Base:DW_Version
[21-05-2023 19:11:18] Platform: number of GPU devices detected 1
[21-05-2023 19:11:18] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_05_10_03, Arch: ga10b
[21-05-2023 19:11:18] Platform: currently selected GPU device integrated ID 0
[21-05-2023 19:11:18] CUDLAEngine:getDLACount: CUDLA version is = 1003000
[21-05-2023 19:11:18] CUDLAEngine:getDLACount: Number of DLA devices = 2
[21-05-2023 19:11:18] Context::mountResourceCandidateDataPath resource FAILED to mount from './resources': VirtualFileSystem: Failed to mount './resources/resources.pak'
[21-05-2023 19:11:18] Context::mountResourceCandidateDataPath resource FAILED to mount from '/home/nvidia/zhensheng/orin_ws/nv_driveworks_demo/target/data': VirtualFileSystem: Failed to mount '/home/nvidia/zhensheng/orin_ws/nv_driveworks_demo/target/data/resources.pak'
[21-05-2023 19:11:18] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.10/bin/../data
[21-05-2023 19:11:18] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.10/bin/../data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.10/bin/../data/resources.pak'
[21-05-2023 19:11:18] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.10/data
[21-05-2023 19:11:18] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.10/data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.10/data/resources.pak'
[21-05-2023 19:11:18] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/bin/../lib/libdw_base.so.5.10
[21-05-2023 19:11:18] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/targets/aarch64-Linux/lib/libdw_base.so.5.10
[21-05-2023 19:11:18] SDK: No resources(.pak) mounted, some modules will not function properly
[21-05-2023 19:11:18] SDK: use EGL display as provided
[21-05-2023 19:11:18] Initialize DriveWorks SDK v5.10.87
[21-05-2023 19:11:18] Release build with GNU 9.3.0 from buildbrain-branch-0-g9a5b4670e12 against Drive PDK v6.0.6.0
[21-05-2023 19:11:18] SensorFactory::createSensor() -> time.nvpps, nvpps-device=/dev/nvpps0
[21-05-2023 19:11:18] Can not create time sensor: DW_HAL_CANNOT_OPEN_CHANNEL: EndpointNVPPS: cannot open NVPPS device with name: /dev/nvpps0
 Error: Permission denied
[21-05-2023 19:11:18] fromFile: Loading rig file: /usr/local/driveworks-5.10/data/samples/sensors/camera/camera/rig.json
[21-05-2023 19:11:18] rig::DatabaseOverlayer: Failed to open a file '/tmp/car_vin' - file likely does not exist - skipping overlay
[21-05-2023 19:11:18] No valid data file found for camera:sample0 in parameter string: camera-name=V1SIM623S4RU5195NB3,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216,skip-eeprom=1 (using configuration folder /usr/local/driveworks-5.10/data/samples/sensors/camera/camera/)
onInitialize: creating camera.gmsl with params: camera-name=V1SIM623S4RU5195NB3,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216,skip-eeprom=1
[21-05-2023 19:11:18] SensorFactory::createSensor() -> camera.gmsl, camera-name=V1SIM623S4RU5195NB3,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216,skip-eeprom=1
[21-05-2023 19:11:18] CameraBase: pool size set to 8
[21-05-2023 19:11:18] SensorFactory::createSensor() -> camera.gmsl.master,
[21-05-2023 19:11:18] CameraMaster::parseDevBlock Getting device info list.
[21-05-2023 19:11:18] devBlock: 0 Slave = 0 Interface = csi-ab Camera_name = V1SIM623S4RU5195NB3 Link = 0 GroupInit = 0 RecCfg = 1
[21-05-2023 19:11:18] Camera Match Name: V1SIM623S4RU5195NB3 Description: Sony IMX623 RGGB module - 120-deg FOV, MIPI-IMX623, MAX96717F linkIndex: 4294967295 serInfo.Name: MAX96717F
[21-05-2023 19:11:18] Client, Setting up information for camera ID 0
[21-05-2023 19:11:18] Client, successfully found info for camera ID 0 bound to id 0
[21-05-2023 19:11:18]  ImageStreamer(NvMedia -> CUDA)
[21-05-2023 19:11:18] CameraClient: using NITO found at /usr/share/camera/V1SIM623S4RU5195NB3.nito
[21-05-2023 19:11:18] SIPLMaster::SIPLMaster: Setting up master camera
[21-05-2023 19:11:18] Platform Config:
[21-05-2023 19:11:18] Description:
[21-05-2023 19:11:18] Number of device blocks: 1
[21-05-2023 19:11:18] Device Block : 0
[21-05-2023 19:11:18] 	csiPort: 2
[21-05-2023 19:11:18] 	i2cDevice: 0
[21-05-2023 19:11:18] 	Deserializer Name: MAX96712_Fusa_nv
[21-05-2023 19:11:18] 	Deserializer Description: Maxim 96712 Aggregator Fusa_nv
[21-05-2023 19:11:18] 	Deserializer i2cAddress: 41
[21-05-2023 19:11:18] 	Simulator Mode: 0
[21-05-2023 19:11:18] 	Passive Mode: 0
[21-05-2023 19:11:18] 	Phy Mode: 1
[21-05-2023 19:11:18] 	Number of camera modules: 1
[21-05-2023 19:11:18] 	CameraModule index: 0
[21-05-2023 19:11:18] 		Name :V1SIM623S4RU5195NB3
[21-05-2023 19:11:18] 		Description: Sony IMX623 RGGB module - 120-deg FOV, MIPI-IMX623, MAX96717F
[21-05-2023 19:11:18] 		Serializer name: MAX96717F
[21-05-2023 19:11:18] 		Serializer description: Maxim 96717F Serializer
[21-05-2023 19:11:18] 		Serializer i2cAdress: 64
[21-05-2023 19:11:18] 			EEPROM name: M24C04
[21-05-2023 19:11:18] 			EEPROM i2cAddress: 84
[21-05-2023 19:11:18] 			EEPROM description: M24C04 EEPROM
[21-05-2023 19:11:18] 			Sensor ID: 0
[21-05-2023 19:11:18] 			Sensor name: IMX623
[21-05-2023 19:11:18] 			Sensor description: Sony IMX623 Sensor
[21-05-2023 19:11:18] 			Sensor i2cAddress: 26
[21-05-2023 19:11:18] 			Sensor isTPGEnabled: 0
[21-05-2023 19:11:18] 			Sensor isTriggerMode: 1
[21-05-2023 19:11:18] 				 cfa: 33
[21-05-2023 19:11:18] 				 embeddedTopLines: 1
[21-05-2023 19:11:18] 				 embeddedBottomLines: 22
[21-05-2023 19:11:18] 				 inputFormat: 20
[21-05-2023 19:11:18] 				 height: 1536
[21-05-2023 19:11:18] 				 width: 1920
[21-05-2023 19:11:18] 				 fps: 30.000000
[21-05-2023 19:11:18] 				 Embedded Data: 0
[21-05-2023 19:11:18] CameraMaster available outputs: 1
[21-05-2023 19:11:18] CameraClient: setting pipeline config for camera ID 0
[21-05-2023 19:11:18] CameraMaster: master initiation
MAX96712: Revision 5 detected
MAX96712 Link 0: PHY optimization was enabled
MAX96717F : Revision 4 detected!
Sensor IMX623 Rev 8 RGGB detected!
[21-05-2023 19:11:19] CameraMaster: Bootstrap NvSIPL and ClientPipelines complete
[21-05-2023 19:11:19] SAL: bootstrap complete
[21-05-2023 19:11:19] Initialize DriveWorks VisualizationSDK v5.10.87
[21-05-2023 19:11:19] Initialize DriveWorksGL SDK v5.10.87
onInitialize: Total cameras 1
onInitialize: getting image props 0
onInitialize: initilizing stream: 0
Main: Starting master.
[21-05-2023 19:11:19] CameraMaster: starting...
[21-05-2023 19:11:19] CameraClient: allocating image pool for ICP
[21-05-2023 19:11:19] CameraClient: raw bit type is missing or unexpected in virtual channel info, meta info might be incomplete
[21-05-2023 19:11:19] Allocating NvSci group
[21-05-2023 19:11:19] CameraClient: allocate image pool for 0
[21-05-2023 19:11:19] Allocating NvSci ISP0 images
[21-05-2023 19:11:19] CameraClient: format not specified. Using h264 in Codec Header.
[21-05-2023 19:11:19] SIPLClient: Acquisition started
[21-05-2023 19:11:20] CameraClient: raw bit type is missing or unexpected in virtual channel info, meta info might be incomplete
[21-05-2023 19:11:20] SIPLDeviceBlockNotificationHandler: Queue timeout
Timing results:
Thread main:
-onProcess                CPU:     6us, std=   4       | GPU:     4us, std=   1       | samples=34
-onRender                 CPU: 33061us, std=9126       | GPU: 33084us, std=9119       | samples=34
[21-05-2023 19:11:21] CameraClient: Notification received from pipeline index:0 of type: NOTIF_WARN_ICP_CAPTURE_TIMEOUT
[21-05-2023 19:11:21] Sensor Health Signal for camera[0] camera.gmsl, camera-name=V1SIM623S4RU5195NB3,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216,skip-eeprom=1
	timestamp: 1684696280493220	sourceID: 1040
	Sensor notifications:
[21-05-2023 19:11:21] Sensor statistics for: camera[0] camera.gmsl, camera-name=V1SIM623S4RU5195NB3,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216,skip-eeprom=1
[21-05-2023 19:11:21] Statistics for DW_SENSOR_STATE_DELTA_HOST_AND_HOST_TIME
Events: 69
Errors: 1
Drops: 0
minDelta: 33332.0000 us
maxDelta: 33334.0000 us
meanDelta: 33332.7266us
Standard deviation: 0.6166
[21-05-2023 19:11:21] Statistics for DW_SENSOR_STATE_DELTA_SENSOR_AND_SENSOR_TIME
Events: 69
Errors: 1
Drops: 0
minDelta: 0.0000 us
maxDelta: 0.0000 us
meanDelta: 0.0000us
Standard deviation: 0.0000
[21-05-2023 19:11:21] Statistics for DW_SENSOR_STATE_DELTA_HOST_AND_SENSOR_TIME
Events: 69
Errors: 1
Drops: 0
minDelta: -2.8138e+14 us
maxDelta: -2.8138e+14 us
meanDelta: -2.8138e+14us
[21-05-2023 19:11:21] Statistics for DW_SENSOR_STATE_DELTA_CURRENT_AND_HOST_TIME
Events: 69
Errors: 1
Drops: 0
minDelta: 0.0000 us
maxDelta: 0.0000 us
meanDelta: 0.0000us
[21-05-2023 19:11:21]  Buffers(Processed) should be          released before calling DeInit() on sipl camera
[21-05-2023 19:11:21] Deinit master camera
[21-05-2023 19:11:21] SIPLDeviceBlockNotificationHandler: Queue timeout
[21-05-2023 19:11:21] SIPLClient: ImageQueue timeout
[21-05-2023 19:11:21] SIPLClient: ImageQueue shutdown
[21-05-2023 19:11:21] SIPLNotifier: Event notification queue shutdown
[21-05-2023 19:11:22] SIPLDeviceBlockNotificationHandler: Queue timeout
[21-05-2023 19:11:23] SIPLDeviceBlockNotificationHandler: Queue timeout
[21-05-2023 19:11:24] CameraClient: Stopping client
[21-05-2023 19:11:24] Releasing camera master
[21-05-2023 19:11:24] SIPLDeviceBlockNotificationHandler: Queue timeout
[21-05-2023 19:11:24] Driveworks VisualizationSDK released
[21-05-2023 19:11:24] Releasing Driveworks SDK Context
[21-05-2023 19:11:24] DriveworksGL SDK released
Actual behavior
without installing systemd in the container
# in target-docker-container
sh: 1: loginctl: not found
WindowGLFW: Failed create window
terminate called after throwing an instance of 'std::exception'
  what():  std::exception
Aborted (core dumped)
after install systemd in the container
nvidia@in_orin_docker:/target$ /usr/local/driveworks/bin/sample_camera
System has not been booted with systemd as init system (PID 1). Can't operate.
Failed to create bus connection: Host is down
with docker run /lib/systemd/systemd tring to solve the System has not been booted issue. There still shows the error.
Additional context
  1. There is no sudo used. because it’s been solved by [BUG] target-docker-container running cuda-samples require unintended extra permission
with reading WindowGLFW: Failed create window - #6 by shayNV , I made some more tests
run sample with headless mode
# in target-orin-docker
nvidia@in_orin_docker:/usr/local/driveworks/bin$ ./sample_camera --offscreen=1
WindowEGL: find EGL devices
WindowEGL: found 1 EGL devices
WindowEGL: init EGL with GLES3 context
WindowEGL: bind OpenGLES3 API
WindowEGL: offscreen mode -> use EGL PBuffer surface 1280x800
WindowEGL: create EGL context
WindowEGL: assign EGL context to current thread
[23-05-2023 07:27:53] Platform: Detected Drive Orin P3710
[23-05-2023 07:27:53] TimeSource: monotonic epoch time offset is 1684716041160715
[23-05-2023 07:27:53] TimeSourceVibranteLinux: detect valid PTP interface mgbe2_0
[23-05-2023 07:27:53] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to mgbe2_0
[23-05-2023 07:27:53] PTP Time is available from Eth Driver
[23-05-2023 07:27:53] Adding variable DW_Base:DW_Version
[23-05-2023 07:27:53] Added variable DW_Base:DW_Version
[23-05-2023 07:27:53] Platform: number of GPU devices detected 1
[23-05-2023 07:27:53] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_05_10_03, Arch: ga10b
[23-05-2023 07:27:53] Platform: currently selected GPU device integrated ID 0
[23-05-2023 07:27:53] CUDLAEngine:getDLACount: CUDLA version is = 1003000
[23-05-2023 07:27:53] CUDLAEngine:getDLACount: Number of DLA devices = 2
[23-05-2023 07:27:53] Context::mountResourceCandidateDataPath resource FAILED to mount from './resources': VirtualFileSystem: Failed to mount './resources/resources.pak'
[23-05-2023 07:27:53] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.10/bin/data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.10/bin/data/resources.pak'
[23-05-2023 07:27:53] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.10/bin/../data
[23-05-2023 07:27:53] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.10/bin/../data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.10/bin/../data/resources.pak'
[23-05-2023 07:27:53] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.10/data
[23-05-2023 07:27:53] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.10/data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.10/data/resources.pak'
[23-05-2023 07:27:53] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/bin/../lib/libdw_base.so.5.10
[23-05-2023 07:27:53] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/targets/aarch64-Linux/lib/libdw_base.so.5.10
[23-05-2023 07:27:53] SDK: No resources(.pak) mounted, some modules will not function properly
[23-05-2023 07:27:53] SDK: use EGL display as provided
[23-05-2023 07:27:53] TimeSource: monotonic epoch time offset is 1684716041160714
[23-05-2023 07:27:53] Initialize DriveWorks SDK v5.10.87
[23-05-2023 07:27:53] Release build with GNU 9.3.0 from buildbrain-branch-0-g9a5b4670e12 against Drive PDK v6.0.6.0
[23-05-2023 07:27:53] SensorFactory::createSensor() -> time.nvpps, nvpps-device=/dev/nvpps0
[23-05-2023 07:27:53] Can not create time sensor: DW_HAL_CANNOT_OPEN_CHANNEL: EndpointNVPPS: cannot open NVPPS device with name: /dev/nvpps0
[23-05-2023 07:27:53] fromFile: Loading rig file: /usr/local/driveworks-5.10/data/samples/sensors/camera/camera/rig.json
[23-05-2023 07:27:53] rig::DatabaseOverlayer: Failed to open a file '/tmp/car_vin' - file likely does not exist - skipping overlay
[23-05-2023 07:27:53] No valid data file found for camera:sample0 in parameter string: camera-name=V1SIM623S4RU5195NB3,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216,skip-eeprom=1 (using configuration folder /usr/local/driveworks-5.10/data/samples/sensors/camera/camera/)
[23-05-2023 07:27:53] SensorFactory::createSensor() -> camera.gmsl, camera-name=V1SIM623S4RU5195NB3,interface=csi-ab,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216,skip-eeprom=1
[23-05-2023 07:27:53] CameraBase: pool size set to 8
[23-05-2023 07:27:53] SensorFactory::createSensor() -> camera.gmsl.master,
libnvsipl_query.so: CNvMQuery.cpp : 108: GetDriverLibraries: Could not find module driver library directory, searched paths:
libnvsipl_query.so: CNvMQuery.cpp : 110: GetDriverLibraries:   - /usr/local/driveworks-5.10/bin/../../../../lib
libnvsipl_query.so: CNvMQuery.cpp : 110: GetDriverLibraries:   - /usr/lib/nvsipl_drv
libnvsipl_query.so: CNvMQuery.cpp : 110: GetDriverLibraries:   - /usr/local/cuda/lib64/nvsipl_drv
libnvsipl_query.so: CNvMQuery.cpp : 110: GetDriverLibraries:   - /opt/ros/foxy/opt/yaml_cpp_vendor/lib/nvsipl_drv
libnvsipl_query.so: CNvMQuery.cpp : 110: GetDriverLibraries:   - /opt/ros/foxy/lib/aarch64-linux-gnu/nvsipl_drv
libnvsipl_query.so: CNvMQuery.cpp : 110: GetDriverLibraries:   - /opt/ros/foxy/lib/nvsipl_drv
[23-05-2023 07:27:53] Driveworks exception thrown: DW_INTERNAL_ERROR: INvSIPLQuery::ParseDefault() failed! SIPL errror code = 10
terminate called after throwing an instance of 'std::runtime_error'
  what():  [2023-05-23 07:27:53] DW Error DW_INTERNAL_ERROR executing DW function:
 dwSAL_createSensor(&m_camera[m_totalCameras], paramsClient[i], m_sal)
 at samples/sensors/camera/camera/main.cpp:343
change DISPLAY
export DISPLAY=:0
GLFW error: 65544, X11: Failed to open display :0
WindowGLFW: Failed to initialize GLFW
ping @SivaRamaKrishnaNV
Dear @lizhensheng,
We have not evaluated DW samples on docker container. Could you use the target directly for unblocking your development?
Understood, the docker container in orin is just the fresh new feature.
But due to the advantage of using docker container, there is a strong need to run all dw samples in the docker container environment.
there are many reasons to use container. some of them is in following from Concepts — NVIDIA Cloud Native Technologies documentation
Containerizing GPU applications provides several benefits, among them:
  • Ease of deployment
  • Isolation of individual devices
  • Run across heterogeneous driver/toolkit environments
  • Requires only the NVIDIA driver to be installed on the host
  • Facilitate collaboration: reproducible builds, reproducible performance, reproducible results.
running the target directly is fine, but docker is the true need.
Hi, @SivaRamaKrishnaNV
With the effort of editing *.csv inject libs into docker container, the creatSensor issue was resolved.
/usr/local/driveworks/bin/sample_camera --offscreen=1 --rig=/usr/local/driveworks/data/samples/sensors/camera/camera/rig.json can be ran in the target docker container.
but the renderer issue still exists when offscreen=0 with correct display export DISPLAY=:1
/usr/local/driveworks/bin/sample_camera --offscreen=0 --rig=/usr/local/driveworks/data/samples/sensors/camera/camera/rig.json
output is
GLFW error: 65542, EGL: Failed to get EGL display: Success
some times with this error which comes from cgf-app, but is believed to belong to dwCamera module.
<15>1 2023-05-29T06:05:25.217379Z - pilotPipe_process 2486 - - [1685340257827758us][VERBOSE][tid:0][ImageStreamerNvMediaCUDAImpl.hpp:73][NO_TAG]  ImageStreamer(NvMedia -> CUDA)
<15>1 2023-05-29T06:05:25.223597Z - pilotPipe_process 2486 - - [1685340257833978us][VERBOSE][tid:0][ImageClasses.hpp:1099][ImageClasses] : handled exception. e.what= Error: importing external memory failed. Error cudaErrorUnknown: unknown error
 Allocation of NvSci Backing Store failed; skipping setup, dw format= 3001 pxlFmt= 6000, pxlType=64, planeCount=2 width=1920, height=1536, vidMem=0
<11>1 2023-05-29T06:05:25.228231Z - pilotPipe_process 2486 - - [1685340257838615us][ERROR][tid:0][Exception.hpp:328][NO_TAG] Driveworks exception thrown: Cannot allocate cuda pitch memory, bytes 2949120. Error cudaErrorUnknown: unknown error
<11>1 2023-05-29T06:05:25.228289Z - pilotPipe_process 2486 - - [1685340257838679us][ERROR][tid:0][Exception.hpp:328][NO_TAG]
<11>1 2023-05-29T06:05:25.228502Z - pilotPipe_process 2486 - - [1685340257838892us][ERROR][tid:0][Runtime.cpp:247][Runtime] Failed to create node instance dwcgfRawCameraDeployPipe.cameraFrontLeftPipe.cameraCapture.cameraNode of type dw::framework::gwCameraNode. Details: DW_CUDA_ERROR: /gw_demo/modules/xplatform/xcgf/image_pipe/src/nodes/camera/camera/CameraNodeImpl.cpp:36 - DriveWorks Error
the error comes from the following code
Friendly ping @SivaRamaKrishnaNV
Could you help with the render issue?
Dear @lizhensheng,
I hope this issue is not a blocker for you.
As informed earlier, we plan to include DW samples testing in docker container for future release. Unfortunately, I don’t have an update from core team on this issue.
according to Display Issue :: X11 and GLFW in Driveworks Docker Environment Host PC - NGC GPU Cloud / Docker and NVIDIA Docker - NVIDIA Developer Forums
but xhost + before entering container not work in this case.
@SivaRamaKrishnaNV
Can you confirm this issue officially?
Hi @lizhensheng,
Do you mean which release the requested instructions available?
I mean, this bug should be reproduced by the nvidia forum.
Also, if you can provide the release that will solve the issue, I am happy to know the plan!
Friendly ping for any updates.
this issue is marked as “known limitation” in driveos release notes from 6.0.9 to 6.0.10, see Log in | NVIDIA Developer
