Dear deepd,
Could you please try to run the sample app with sudo permission like below?
nvidia@tegra-ubuntu:/usr/local/driveworks/bin$ sudo ./sample_camera_gmsl --camera-type=ar0231-rccb-bae-sf3324 --camera-port=a
One more thing, could you let us know what Aurix FW version is?
You can get the following information by running saple.
Please see Platform: OS_DRIVE_V5L - CURRENT: Sensor [3] part
nvidia@tegra-ubuntu:/usr/local/driveworks/bin$ sudo ./sample_sensors_info
[22-2-2019 10:25:59] Initialize DriveWorks SDK v1.2.400
[22-2-2019 10:25:59] Release build with GNU 4.9.4 from v1.2.0-rc11-0-ga7f5475 against Vibrante PDK v5.0.10.3
[22-2-2019 10:25:59] Platform: Detected Drive PX2 - Tegra A
[22-2-2019 10:25:59] TimeSource: monotonic epoch time offset is 1548831126524568
[22-2-2019 10:25:59] TimeSource: PTP ioctl returned error. Synchronized time will not be available.
[22-2-2019 10:25:59] TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[22-2-2019 10:26:0] Platform: number of GPU devices detected 2
[22-2-2019 10:26:0] Platform: currently selected GPU device discrete ID 0
[22-2-2019 10:26:0] SDK: Resources mounted from /usr/local/driveworks-1.2/data/resources
[22-2-2019 10:26:0] SDK: Create NvMediaDevice
[22-2-2019 10:26:0] SDK: Create NvMediaIPPManager
[22-2-2019 10:26:0] egl::Display: found 2 EGL devices
[22-2-2019 10:26:0] egl::Display: use drm device: drm-nvdc
Platform: OS_LINUX:
Sensor [0] : can.socket ? device=can0[,fifo-size=1024]
Sensor [1] : can.virtual ? file=/path/to/file.can[,create_seek,default_timeout_us,time-offset=0]
Sensor [2] : camera.virtual ? video/file=filepath.{h264,raw,lraw}[,timestamp=file.txt][,create_seek][,time-offset=0]
Sensor [3] : camera.nvidia-ip ? host=<ip_addr>, port=<TCP port number>
Sensor [4] : camera.usb ? device=0
Sensor [5] : camera.pointgrey ? device=0[,fps=30]
Sensor [6] : gps.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=nmea0183][,fifo-size=1024]]
Sensor [7] : gps.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=true,time-offset=0]
Sensor [8] : gps.xsens ? device=0[,frequency=100,time-smoothing=true,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [9] : gps.novatel ? [fifo-size=1024]
Sensor [10] : gps.dataspeed ? can-proto=can.socket,can-params=device=canX[,fifo-size=1024]
Sensor [11] : imu.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=xsens_nmea][,fifo-size=1024]]
Sensor [12] : imu.xsens ? device=0[,frequency=100,time-smoothing=true,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [13] : imu.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=true][,fifo-size=1024][,time-offset=0]
Sensor [14] : imu.novatel ? [fifo-size=1024]
Sensor [15] : imu.dataspeed ? can-proto=can.socket,can-params=device=canX[,fifo-size=1024]
Sensor [16] : lidar.virtual ? file=filepath.bin[,create_seek,default_timeout_us,decoder=filepath.so,time-smoothing=false,decoding=true,time-offset=0]
Sensor [17] : lidar.socket ? ip=X.X.X.X,port=XXXX,device={QUAN_M81A, IBEO_LUX, VELO_VLP16, VELO_VLP16HR, VELO_HDL32E, VELO_VLP32C, VELO_HDL64E, CUSTOM},scan-frequency=XX.X[,protocol=xxx,multicast-ip=X.X.X.X,decoder=filepath.so,time-smoothing=false]
Sensor [18] : radar.virtual ? file=filepath.bin,time-smoothing=true[,decoder=filepath.so,create_seek,default_timeout_us,decoding=true,time-offset=0]
Sensor [19] : radar.socket ? ip=X.X.X.X,port=XXXX,device={DELPHI_ESR2_5, CONTINENTAL_ARS430, CUSTOM},multicast-ip=X.X.X.X],time-smoothing=true,isInverted=false,slave=false[,decoder=filepath.so,protocol=xxx]
Sensor [20] : radar.can ? can-driver=can.xxx,can-bus=xxx,can-base-id=0x460,device={CONTINENTAL_ARS430_CAN}[,aurix-can-ip=X.X.X.X.X],[aurix-can-aport=XXXX][,aurix-can-bport=XXXX][,virtual-file=filepath.bin][,time-smoothing=false]
<b>Platform: OS_DRIVE_V5L - CURRENT:</b>
Sensor [1] : can.aurix ? ip=10.0.0.1,bus={a,b,c,d}[,aport=50000,bport=60395][,fifo-size=1024]
Sensor [2] : can.virtual ? file=/path/to/file.can[,create_seek,default_timeout_us,time-offset=0]
<b> Sensor [3] : camera.gmsl ? csi-port={a,c,e,g},camera-count={1,2,3,4},(Parker) camera-type={ov10635, ov10640-bggr-ae-svc210, ov10640-bggr-ae-svc212, ar0231-grbg-ae-sd3321, ar0231-rccb-ae-ss3322,ar0231-rccb-bae-ss3322, ar0231-rccb-ae-ss3323, ar0231-rccb-bae-ss3323, ar0231-rccb-ae-sf3324,ar0231-rccb-bae-sf3324, ar0231-rccb-ae-sf3325, ar0231-rccb-bae-sf3325},(Xavier) camera-type={ar0231-rccb-bae-sf3324, ar0231-rccb-bae-sf3325, ar0144-cccc-none-gazet1},output-format={yuv+raw+data}[,slave={0,1}][,fifo-size={3..20}][,custom-board=0][,camera-mask={0001|0010|0011|..|1111}][,warn-per-frame={0,1}]</b>
Sensor [4] : camera.virtual ? video/file=filepath.{h264,raw,lraw}[,timestamp=file.txt][,create_seek][,time-offset=0]
Sensor [5] : camera.usb ? device=0
Sensor [6] : camera.pointgrey ? device=0[,fps=30]
Sensor [7] : camera.nvidia-ip ? host=[ip_addr], port=[TCP port number]
Sensor [8] : gps.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=nmea0183]][,fifo-size=1024]
Sensor [9] : gps.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,time-offset=0]
Sensor [10] : gps.xsens ? device=0[,frequency=100,time-smoothing=false,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [11] : gps.novatel ? [fifo-size=1024]
Sensor [12] : gps.dataspeed ? can-proto=can.socket,can-params=device=canX[,fifo-size=1024]
Sensor [13] : imu.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=xsens_nmea]][,fifo-size=1024]
Sensor [14] : imu.xsens ? device=0[,frequency=100,time-smoothing=false,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [15] : imu.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,time-offset=0]
Sensor [16] : imu.novatel ? [fifo-size=1024]
Sensor [17] : imu.dataspeed ? can-proto=can.socket,can-params=device=canX[,fifo-size=1024]
Sensor [18] : lidar.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,decoding=true,time-offset=0]
Sensor [19] : lidar.socket ? ip=X.X.X.X,port=XXXX,device={QUAN_M81A, IBEO_LUX, VELO_VLP16, VELO_VLP16HR, VELO_HDL32E, VELO_VLP32C, VELO_HDL64E, CUSTOM},scan-frequency=XX.X[,protocol=xxx,multicast-ip=X.X.X.X,decoder=filepath.so,time-smoothing=false]
Sensor [20] : radar.virtual ? file=filepath.bin,time-smoothing=true[,decoder=filepath.so,create_seek,default_timeout_us,decoding=true,time-offset=0]
Sensor [21] : radar.socket ? ip=X.X.X.X,port=XXXX,device={DELPHI_ESR2_5, CONTINENTAL_ARS430, CUSTOM},multicast-ip=X.X.X.X,time-smoothing=true,isInverted=false,slave=false[,decoder=filepath.so,protocol=xxx]
Sensor [22] : radar.can ? can-driver=can.xxx,can-bus=xxx,can-base-id=0x460,device={CONTINENTAL_ARS430_CAN}[,aurix-can-ip=X.X.X.X.X],[aurix-can-aport=XXXX][,aurix-can-bport=XXXX][,virtual-file=filepath.bin]
Platform: OS_QNX:
Sensor [1] : can.virtual ? file=/path/to/file.can[,create_seek][,time-offset=0]
Sensor [2] : camera.gmsl ? csi-port={a,c,e,g},camera-count={1,2,3,4},camera-type={ar0231-rccb-bae-sf3324, ar0231-rccb-bae-sf3325},output-format={yuv+raw+data}[,slave={0,1}][,fifo-size={3..20}][,custom-board=0][,camera-mask={0001|0010|0011|..|1111}][,warn-per-frame={0,1}]
Sensor [3] : camera.virtual ? video/file=filepath.{h264,raw}[,timestamp=file.txt][,create_seek][,time-offset=0]
Sensor [4] : gps.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=nmea0183]][,fifo-size=1024]
Sensor [5] : gps.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,time-offset=0]
Sensor [6] : gps.xsens ? device=0[,frequency=100,time-smoothing=false,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [7] : gps.dataspeed ? can-proto=can.socket/aurix,can-params=device=canX[,fifo-size=1024]
Sensor [8] : imu.uart ? device=/dev/ttyXXX[,baud={1200,2400,4800,9600,19200,38400,57600,115200}[,format=xsens_nmea]][,fifo-size=1024]
Sensor [9] : imu.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,time-offset=0]
Sensor [10] : imu.xsens ? device=0[,frequency=100,time-smoothing=false,fifo-size=1024,baudrate=115200,stop-bits=2]
Sensor [11] : imu.dataspeed ? can-proto=can.socket/aurix,can-params=device=canX[,fifo-size=1024]
Sensor [12] : lidar.virtual ? file=filepath.bin[,create_seek,default_timeout_us,time-smoothing=false,time-offset=0]
Sensor [13] : lidar.socket ? ip=X.X.X.X,port=XXXX,device={QUAN_M81A, IBEO_LUX, VELO_VLP16, VELO_VLP16HR, VELO_HDL32E, VELO_VLP32C, VELO_HDL64E, CUSTOM},scan-frequency=XX.X[,protocol=xxx,multicast-ip=X.X.X.X,decoder=filepath.so,time-smoothing=false]
Sensor [14] : radar.virtual ? file=filepath.bin,time-smoothing=true[,decoder=filepath.so,create_seek,default_timeout_us,decoding=false,time-offset=0]
Sensor [15] : radar.socket ? ip=X.X.X.X,port=XXXX,device={DELPHI_ESR2_5, CONTINENTAL_ARS430, CUSTOM},multicast-ip=X.X.X.X],time-smoothing=true,isInverted=false[,decoder=filepath.so,protocol=xxx]
Sensor [16] : radar.can ? can-driver=can.xxx,can-bus=xxx,can-base-id=0x460,device={CONTINENTAL_ARS430_CAN}[,aurix-can-ip=X.X.X.X.X],[aurix-can-aport=XXXX][,aurix-can-bport=XXXX][,virtual-file=filepath.bin]
[22-2-2019 10:26:0] SDK: Release NvMediaDevice
[22-2-2019 10:26:0] Driveworks SDK released
[22-2-2019 10:26:0] SDK: Release NvMedia2D
