I am connected to the attached camera with reference to the setup video of Xavier to play the sample, but I can not play it due to the following error.
nvidia @ tegra-ubuntu: / usr / local / driveworks / bin $ ./sample_drivenetNcameras --input-type = camera
[04-07-2017 08:02:50] Platform: Detected DDPX-Tegra A
[04-07-2017 08:02:50] Initialize DriveWorks SDK v2.0.2081
[04-07-2017 08:02:50] Release build with GNU 4.9.4 from heads / buildbrain-branch-0-g36b127f against Drive PDK v5.1.0.2
[04-07-2017 08:02:50] TimeSource: monotonic epoch time offset is 1499153885580204
[04-07-2017 08:02:50] PTP Time is available from NVPPS Driver
[04-07-2017 08:02:50] Platform: number of GPU devices detected 1
[04-07-2017 08:02:50] Platform: currently selected GPU device integrated ID 0
[04-07-2017 08:02:50] SDK: Resources mounted from …/./data/
[04-07-2017 08:02:50] SDK: Create NvMediaDevice
[04-07-2017 08:02:50] SDK: use EGL display as provided
[04-07-2017 08:02:50] SensorFactory :: createSensor ()-> camera.gmsl, camera-group = a, camera-type = ar0231-rccb-bae-sf3324, serialize = false, output-format = raw, camera-count = 4, camera-mask = 0001, slave = 0, fifo-size = 5
[04-07-2017 08:02:50] CameraGMSL: Create NvMediaIPPManager
[04-07-2017 08:02:50] CameraGMSL: required FPS = 30, resolution = 1920x1208
nvmedia isc: IscPwrCtrlInit: 939: Camera power control library: NVCCP
Max96712 Rev 2 detected!
MAX96712: Enable periodic AEQ on Link 0
MAX96705: Pre-emphasis set to 0xaa
Sensor AR0231 RCCB Rev7 detected!
(NvCapture) Error IoctlFailed: capture setup ioctl failed: 5 (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture_hw_linux.c, function NvCaptureLinuxChannelOpen (), line 157)
(NvCapture) Error IoctlFailed: (propagating from /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture.c, function NvCaptureChannelHwBackendOpen (), line 1169)
(NvCapture) Error IoctlFailed: (propagating from /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture.c, function NvCaptureChannelSetAttribute (), line 1241)
SetSourceSequence: failed to set channel source attribute
ICPCreate: captureCreate failed
CreateGroup: failed for create ICP instance 0
[IppIcpExComponentCreateNew: 634] Failed to create ICP
[NvMediaIPPComponentCreateNew: 806] Failed to create NVMEDIA_IPP_COMPONENT_ICP_EX component
[04-07-2017 08:02:57] Driveworks exception thrown: DW_NVMEDIA_ERROR: CameraGMSL: Can not setup pipeline: 7
terminate called after throwing an instance of ‘std :: runtime_error’
what (): [2017-07-04 08:02:57] DW Error DW_NVMEDIA_ERROR executing DW function:
dwSAL_createSensor (& salSensor, salParams, sal)
at /dvs/git/dirty/gitlab-master_av/dw/sdk/samples/drivenet/drivenet_ncameras/main.cpp: 690
Aborted (core dumped)
Please tell me how to resolve.
