Hi!
I compiled and try to execute camera demo, but have this error:
root@tegra-ubuntu ~ $ /usr/local/driveworks-2.0/samples/build/src/sensors/camera/camera_gmsl/sample_camera_gmsl
[27-09-2019 20:41:30] Platform: Detected DDPX - Tegra B
[27-09-2019 20:41:30] Initialize DriveWorks SDK v2.0.2081
[27-09-2019 20:41:30] Release build with GNU 4.9.4 from heads/buildbrain-branch-0-g36b127f against Drive PDK v5.1.0.2
[27-09-2019 20:41:30] TimeSource: monotonic epoch time offset is 1569613552357002
[27-09-2019 20:41:30] PTP Time is available from NVPPS Driver
[27-09-2019 20:41:30] Platform: number of GPU devices detected 1
[27-09-2019 20:41:30] Platform: currently selected GPU device integrated ID 0
[27-09-2019 20:41:30] SDK: Resource failed to mount from ‘…/data/’: VirtualFileSystem: Failed to mount ‘…/data/[.pak]’
[27-09-2019 20:41:30] SDK: Resources mounted from /usr/local/driveworks-2.0/data/
[27-09-2019 20:41:30] SDK: Create NvMediaDevice
[27-09-2019 20:41:30] egl::Display: found 1 EGL devices
[27-09-2019 20:41:30] egl::Display: use drm device: drm-nvdc
[27-09-2019 20:41:30] SensorFactory::createSensor() → camera.gmsl, output-format=yuv,fifo-size=3,isp-mode=yuv420-uint8,camera-type=ar0231-rccb-bae-sf3324,camera-group=a,slave=0
[27-09-2019 20:41:30] CameraGMSL: Create NvMediaIPPManager
[27-09-2019 20:41:30] CameraGMSL: required FPS = 30, resolution = 1920x1208
Max96712 Rev 2 detected!
Sensor AR0231 RCCB Rev7 detected!
CaptureOpenCalibration: Failed to apply nvcsi prod settings err -1
CaptureInit: failed to do mipi calibration
ICPCreate: captureCreate failed
nvmICPCreate: failed for create ICP instance 0
[IppIcpExComponentCreateNew:625] Failed to create ICP
[NvMediaIPPComponentCreateNew:807] Failed to create NVMEDIA_IPP_COMPONENT_ICP_EX component
[27-09-2019 20:41:31] Driveworks exception thrown: DW_NVMEDIA_ERROR: CameraGMSL: Cannot setup pipeline : 7
terminate called after throwing an instance of ‘std::runtime_error’
what(): [2019-09-27 20:41:31] DW Error DW_NVMEDIA_ERROR executing DW function:
dwSAL_createSensor(&m_camera, params, m_sal)
at /usr/local/driveworks-2.0/samples/src/sensors/camera/camera_gmsl/main.cpp:176
Aborted (core dumped)
Here is firmware version:
root@tegra-ubuntu ~ $ sudo /bin/bash /etc/systemd/scripts/nv_aurix_check_fw.sh
starting Aurix FW checking…
Checking arguments…
Rootfs FW version is 3.01.05.0
Response_From_Aurix
Flashed FW version is 3.01.05.00
SW Version: DRIVE-V5.0.13-E3550-EB-Aurix-ForHyperion-3.01.05
Aurix is booted with Latest FW
Rootfs UPDATE FW version is 1.24.00.0
Flashed UPDATE FW version is 1.24.00.00
Aurix is booted with Latest UPDATE FW
Please help!
Michael
