I used the samples in driveworks-0.1.2, which was preinstalled on PX2, to test an ov10635 camera, but failed.
The camera was connected to A0 input, and I tried the following sample:
Could you please check AURIX_IP_ADDRESS ip on Aurix shell?
If AURIX_IP_ADDRESS=10.42.0.73, please modify tacp.cfg file.
AURIX_IP_ADDRESS=10.42.0.73 => AURIX_IP_ADDRESS=10.42.0.33
Then export DRIVEPX2_AURIX_IP_ADDRESS=10.42.0.33 on DPX2.
However we’ve post DrivePX2 PDK Beta 1.0 on NVONLINE.
If possible, could you please use new one instead of old one? Thanks.
I changed the aurix ip address to 10.42.0.33, this error still exists. I upgrade the DrivePX2 PDK Beta 1.0, still the same error. Is there any other point I should check with? Thank you!
Hello I followed all these your answers and instraction to on the gmsl camera but yet i am not able to run any single camera on px2. in following you can see my terminal output corresponding input additionally I dont have any file as tacp.cfg . PLEASE HELP THANK YOU
$ sudo /etc/systemd/scripts/nv_aurix_check_fw.sh
[sudo] password for nvidia:
starting Aurix FW checking…
Checking arguments…
Rootfs EB FW version is 2.02.04.0
Flashed EB FW version is 2.02.04.00
Aurix is booted with Latest EB FW
Rootfs UPDATE FW version is 0.16.00.0
Flashed UPDATE FW version is 0.16.00.00
Aurix is booted with Latest UPDATE FW
receive_from: Timeout Error.
Please check Ethernet ip configuration or
check Aurix firmware version
iscRootDevOpen: Failed to power on camera(s)
NvMediaISCRootDeviceCreate: Unable to open root device
nvmedia: ERROR: Init: Failed to create NvMedia ISC root device
nvmedia: ERROR: IPPInit: Failed to initialize ISC devices
[NvMediaIPPManagerDestroy:189] Bad parameter
nvmedia: ERROR: main: Error in IPPInit
in minicom terminal
shell>>status
IP add: TegraA 10.42.0.28
IP add: Tegrab 10.42.0.29
IP add: aurix 10.42.0.73
