The sample_drivenetNcameras runs properly on Xavier A(the application window shows up the detected object), but when I try to run it on Xavier B, nothing shows up in the application window(blackout) and “Cannot read frame: DW_NOT_READY” message keeps bumping up on the Terminal. Then I push Escape key to quit the application and “(NvCapture) Error Timeout” message shows on the terminal as below.
I wonder if I miss some configuration to run the sample with the camera on Xavier B? Thank you.
nvidia@tegra-ubuntu:/usr/local/driveworks-2.0/bin$ ./sample_drivenetNcameras --input-type=camera
[04-07-2017 07:40:13] Platform: Detected DDPX - Tegra B
[04-07-2017 07:40:13] Initialize DriveWorks SDK v2.0.2081
[04-07-2017 07:40:13] Release build with GNU 4.9.4 from heads/buildbrain-branch-0-g36b127f against Drive PDK v5.1.0.2
[04-07-2017 07:40:13] TimeSource: monotonic epoch time offset is 1499153892206067
[04-07-2017 07:40:13] PTP Time is available from NVPPS Driver
[04-07-2017 07:40:13] Platform: number of GPU devices detected 1
[04-07-2017 07:40:13] Platform: currently selected GPU device integrated ID 0
[04-07-2017 07:40:13] SDK: Resources mounted from .././data/
[04-07-2017 07:40:13] SDK: Create NvMediaDevice
[04-07-2017 07:40:13] SDK: use EGL display as provided
[04-07-2017 07:40:13] SensorFactory::createSensor() -> camera.gmsl, camera-group=a,camera-type=ar0231-rccb-bae-sf3324,serialize=false,output-format=raw,camera-count=4,camera-mask=0001,slave=0,fifo-size=5
[04-07-2017 07:40:13] CameraGMSL: Create NvMediaIPPManager
[04-07-2017 07:40:13] CameraGMSL: required FPS = 30, resolution = 1920x1208
nvmedia isc: IscPwrCtrlInit: 939: Camera power control library: NVCCP
Max96712 Rev 2 detected!
MAX96712: Enable periodic AEQ on Link 0
MAX96705: Pre-emphasis set to 0xaa
Sensor AR0231 RCCB Rev7 detected!
[04-07-2017 07:40:14] CameraGMSL: default IPP event callback function set
Camera image with 1920x1208 at 30 FPS
[04-07-2017 07:40:14] Setting up SoftISP
[04-07-2017 07:40:14] DriveNet: Running in FP32 mode.
[04-07-2017 07:40:15] FileHeader: file header created with development build (patch = -1), assumingcompatibility
[04-07-2017 07:40:15] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[04-07-2017 07:40:15] Glob Size is 28376488 bytes.
[04-07-2017 07:40:15] Added linear block of size 22118400
[04-07-2017 07:40:15] Added linear block of size 7372800
[04-07-2017 07:40:15] Added linear block of size 1036800
[04-07-2017 07:40:15] Added linear block of size 218624
[04-07-2017 07:40:20] Deserialize required 4907073 microseconds.
[04-07-2017 07:40:20] DataConditioner: Scale transformation has been configured with 0.003922.
[04-07-2017 07:40:20] DataConditioner: Split transformation has been enabled.
[04-07-2017 07:40:20] DataConditioner: Value subtract transformation has been configured with {0.00000, 0.00000, 0.00000}.
[04-07-2017 07:40:20] Initialize DriveWorks VisualizationSDK v2.0.2081
[04-07-2017 07:40:20] Initialize DriveWorksGL SDK v2.0.2081
[04-07-2017 07:40:21] StreamConsumerGL: successfully initialized
[04-07-2017 07:40:21] StreamProducerCUDA: successfully initialized
Timing results:
Thread main:
-onProcess CPU: 2021305us, std= 806 | GPU: 2021075us, std= 464 | samples=21
-onRender CPU: 895us, std=1808 | GPU: 904us, std=1824 | samples=21
(NvCapture) Error Timeout: capture waiting for status timeout (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture_hw_linux.c, function NvCaptureLinuxGetCaptureStatus(), line 362)
(NvCapture) Error Timeout: (propagating from /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture.c, function NvCaptureDequeue(), line 1050)
^[(NvCapture) Error Timeout: capture waiting for status timeout (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture_hw_linux.c, function NvCaptureLinuxGetCaptureStatus(), line 362)
[04-07-2017 07:41:05] Driveworks VisualizationSDK released
[04-07-2017 07:41:05] SDK: Release NvMediaDevice
[04-07-2017 07:41:05] DriveworksGL SDK released
[04-07-2017 07:41:05] Driveworks SDK released
[04-07-2017 07:41:05] SDK: Release NvMedia2D
