Camera initiation returns error: nvccp_set_cam_unit_pwr_on failed status 1001
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.10816
other
Host Machine Version
native Ubuntu 18.04
other
Dear Nvidia Support,
Last week, when running the sample_camera program from Driveworks, we were met with the following error.
nvidia@tegra-ubuntu:~/tmp$ /usr/local/driveworks/bin/sample_camera
[01-12-2022 18:01:15] Platform: Detected DDPX - Tegra A
[01-12-2022 18:01:15] TimeSource: monotonic epoch time offset is 1669889917193888
[01-12-2022 18:01:15] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[01-12-2022 18:01:15] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[01-12-2022 18:01:15] TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[01-12-2022 18:01:15] Platform: number of GPU devices detected 2
[01-12-2022 18:01:15] Platform: currently selected GPU device discrete ID 0
[01-12-2022 18:01:15] Context::mountResourceCandidateDataPath resource FAILED to mount from '/home/nvidia/tmp/data/': VirtualFileSystem: Failed to mount '/home/nvidia/tmp/data/[.pak]'
[01-12-2022 18:01:15] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-4.0/bin/../data
[01-12-2022 18:01:15] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-4.0/bin/../data/': VirtualFileSystem: Failed to mount '/usr/local/driveworks-4.0/bin/../data/[.pak]'
[01-12-2022 18:01:15] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-4.0/data
[01-12-2022 18:01:15] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-4.0/data/': VirtualFileSystem: Failed to mount '/usr/local/driveworks-4.0/data/[.pak]'
[01-12-2022 18:01:15] SDK: No resources(.pak) mounted, some modules will not function properly
[01-12-2022 18:01:15] SDK: Create NvMediaDevice
[01-12-2022 18:01:15] SDK: Create NvMedia2D
[01-12-2022 18:01:15] SDK: use EGL display as provided
[01-12-2022 18:01:15] Initialize DriveWorks SDK v4.0.0
[01-12-2022 18:01:15] Release build with GNU 7.3.1 from no-gitversion-build against Drive PDK v5.2.6.0
[01-12-2022 18:01:15] Rig::fromFile: Loading rig file: /usr/local/driveworks-4.0/data/samples/sensors/camera/camera/rig.json
[01-12-2022 18:01:15] rig::DatabaseOverlayer: Failed to open a file '/tmp/car_vin' - file likely does not exist - skipping overlay
[01-12-2022 18:01:15] No valid data file found for camera:sample0 in parameter string: camera-name=SF3324,interface=csi-a,link=0,output-format=processed (using configuration folder /usr/local/driveworks-4.0/data/samples/sensors/camera/camera/)
onInitialize: creating camera.gmsl with params: camera-name=SF3324,interface=csi-a,link=0,output-format=processed
[01-12-2022 18:01:15] SensorFactory::createSensor() -> camera.gmsl, camera-name=SF3324,interface=csi-a,link=0,output-format=processed
[01-12-2022 18:01:15] CameraBase: pool size set to 8
[01-12-2022 18:01:15] SensorFactory::createSensor() -> camera.gmsl.master,
[01-12-2022 18:01:16] CameraMaster::parseDevBlock Getting device info list.
[01-12-2022 18:01:16] devBlock: 1 Slave = 0 Interface = csi-a Camera_name = SF3324 Link = 0
[01-12-2022 18:01:16] Camera Match Name: SF3324 Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705 linkIndex: 4294967295 serInfo.Name: MAX96705
[01-12-2022 18:01:16] Client, Setting up information for camera ID 0
[01-12-2022 18:01:16] Client, successfully found info for camera ID 0 bound to id 0
[01-12-2022 18:01:16] CameraClient: no NITO found at /opt/nvidia/nvmedia/nit/SF3324.nito
[01-12-2022 18:01:16] CameraClient: using NITO found at /opt/nvidia/nvmedia/nit/sf3324.nito
[01-12-2022 18:01:16] Initialize DriveWorks VisualizationSDK v4.0.0
[01-12-2022 18:01:16] Initialize DriveWorksGL SDK v4.0.0
onInitialize: Total cameras 1
onInitialize: getting image props 0
onInitialize: initilizing stream: 0
[01-12-2022 18:01:16] StreamConsumerGL: successfully initialized
[01-12-2022 18:01:16] StreamProducerCUDA: successfully initialized
Main: Starting master.
[01-12-2022 18:01:16] CameraGSMLMaster: starting...
[01-12-2022 18:01:16] SIPLMaster::SIPLMaster: Setting up master camera
[01-12-2022 18:01:16] Platform:
[01-12-2022 18:01:16] Platform Config:
[01-12-2022 18:01:16] Description:
[01-12-2022 18:01:16] Number of device blocks: 1
[01-12-2022 18:01:16] Device Block : 0
[01-12-2022 18:01:16] 	csiPort: 0
[01-12-2022 18:01:16] 	i2cDevice: 0
[01-12-2022 18:01:16] 	Deserializer Name: MAX96712
[01-12-2022 18:01:16] 	Deserializer Description: Maxim 96712 Aggregator
[01-12-2022 18:01:16] 	Deserializer i2cAddress: 41
[01-12-2022 18:01:16] 	Simulator Mode: 0
[01-12-2022 18:01:16] 	Slave Mode: 0
[01-12-2022 18:01:16] 	Phy Mode: 0
[01-12-2022 18:01:16] 	Number of camera modules: 1
[01-12-2022 18:01:16] 	CameraModule index: 0
[01-12-2022 18:01:16] 		Name :SF3324
[01-12-2022 18:01:16] 		Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705
[01-12-2022 18:01:16] 		Serializer name: MAX96705
[01-12-2022 18:01:16] 		Serializer description: Maxim 96705 Serializer
[01-12-2022 18:01:16] 		Serializer i2cAdress: 64
[01-12-2022 18:01:16] 			Sensor ID: 0
[01-12-2022 18:01:16] 			Sensor name: AR0231
[01-12-2022 18:01:16] 			Sensor description: OnSemi AR0231 Sensor
[01-12-2022 18:01:16] 			Sensor i2cAddress: 16
[01-12-2022 18:01:16] 			Sensor isTPGEnabled: 0
[01-12-2022 18:01:16] 			Sensor isTriggerMode: 1
[01-12-2022 18:01:16] 				 cfa: 39
[01-12-2022 18:01:16] 				 embeddedTopLines: 24
[01-12-2022 18:01:16] 				 embeddedBottomLines: 4
[01-12-2022 18:01:16] 				 inputFormat: 8
[01-12-2022 18:01:16] 				 height: 1208
[01-12-2022 18:01:16] 				 width: 1920
[01-12-2022 18:01:16] 				 fps: 30.0000000
[01-12-2022 18:01:16] 				 Embedded Data: 0
[01-12-2022 18:01:16] CameraMaster available outputs: 1
[01-12-2022 18:01:16] CameraClient: setting pipeline config for camera ID 0
[01-12-2022 18:01:16] CameraMaster: master initiation
Module_id 30 Severity 2 : src/devblk/fusa/cameramodule/common/utils/pwr_utils.cpp 493
Module_id 30 Severity 2 : nvccp_set_cam_unit_pwr_on failed with status 1001
Module_id 30 Severity 2 : src/devblk/nonfusa/cameramodule/MAX96712cameramodule/CNvMMAX96712CameraModule.cpp 790
Module_id 30 Severity 2 : MAX96712: CNvMMAX96712CameraModule::DoSetPower failed with SIPL error 127
Module_id 30 Severity 2 : src/devblk/common/ddi/ModuleIF/CNvMCameraModule.cpp 70
Module_id 30 Severity 2 : CNvMCameraModule::SetPower failed with SIPL error 127
Module_id 30 Severity 2 : src/devblk/common/core/CNvMDeviceBlock.cpp 678
Module_id 30 Severity 2 : CameraModule SetPower failed with SIPL error 127
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 435: ThreadFunc: Device block init failed(7f)
Module_id 30 Severity 2 : src/core/CNvMDeviceBlockMgr.cpp 144
Module_id 30 Severity 2 : Device block action failed for block (action, block) 10
Module_id 30 Severity 2 : src/core/CNvMDeviceBlockMgr.cpp 180
Module_id 30 Severity 2 : Failed to initialize device blocks
sample_camera: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 436: Init: DeviceBlock manager init failed
[01-12-2022 18:01:16] CameraMaster: master init failed127
sample_camera: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 615: GetImageAttributes: Incorrect pipeline state for pipeline:0
[01-12-2022 18:01:16] CameraMaster: GetImageAttributes failed6
[01-12-2022 18:01:16] CameraClient: GetImageAttributes failed6
[01-12-2022 18:01:16] CameraClient: Failed to allocate images groups!6
[01-12-2022 18:01:16] Driveworks exception thrown: DW_FAILURE: CameraClient: Failed to allocate images pool!
terminate called after throwing an instance of 'std::runtime_error'
  what():  [2022-12-01 18:01:16] DW Error DW_FAILURE executing DW function:
 dwSensor_start(m_camera[i])
 at samples/sensors/camera/camera/main.cpp:367
Aborted (core dumped)
When we first met with this issue, the problem was resolved by simply waiting around an hour. Several days later, the same issue came up. It was resolved by extensively trying out different cameras, cables, and ports. Now, the issue still persists even after waiting and trying out different cameras, cables, and ports.
Looking through the forums, we found NvSIPLCamera Init failed faced the same issue. We followed the recommended actions in the thread, namely:
  • aurixreset
  • Reflashing Driveworks on both Tegras
  • Running the sample_camera program on both Tegras
and still face the same error.
We also checked Hardware Errata #4 and can confirm that a small, round, QC sticker exists. A photo can be provided if needed.
How should we best continue?
@aulia.widyaputra1
When reproducing the issue, please try if SIPL Camera (nvsipl_camera) or SIPL Sample (nvsipl_sample) work or not.
This is the result of running SIPL Sample (nvsipl_sample).
nvidia@tegra-ubuntu:~/drive-t186ref-linux/samples/nvmedia/nvsipl/test/sample$ ./nvsipl_sample -p SF3324_CPHY_x4
nvsipl_sample: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 436: Init: DeviceBlock manager init failed
nvsipl_sample: ERROR: INvSIPLCamera::Init() failed, status: 127
nvsipl_sample: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvMSensorPipeline.cpp: 705: Deinit: Deinit() call in wrong state
nvsipl_sample: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:0
nvsipl_sample: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 49: ~CNvMCamera: CNvMCamera object fails to deinit
nvsipl_sample: ERROR: Unexpected output type
The same type of error occurs.
I’ll check with the team internally. At the same time, please cross-check on another devkit and see if you can narrow down the causes.
Another devkit as in another AGX Xavier? We only have one.
We’ll try reflashing the device with Driveworks 4.0 with the AGX Xavier SDK. Currently, it’s flashed with the Driveworks 4.0 Pegasus XT SDK. We purchased the model with additional two discrete GPUs. We’ll also try reflashing with Drive Software 10.0.
Some additional information, we also tried running the sample_lidar application. The sample application worked. It returned a livestream of the lidar readings.
Are there any further developments on this issue?
We tried running sample_camera on different versions. None of them worked. The following is the log for running sample_camera on Drive Software 10.0.
nvidia@tegra-ubuntu:/usr/local/driveworks/bin$ ./sample_camera_gmsl
[21-09-2019 01:13:03] Platform: Detected DDPX - Tegra A
[21-09-2019 01:13:03] TimeSource: monotonic epoch time offset is 1569027511792651
[21-09-2019 01:13:03] PTP Time is available from NVPPS Driver
[21-09-2019 01:13:03] Platform: number of GPU devices detected 2
[21-09-2019 01:13:03] Platform: currently selected GPU device discrete ID 0
[21-09-2019 01:13:03] SDK: Resources mounted from .././data/
[21-09-2019 01:13:03] SDK: Create NvMediaDevice
[21-09-2019 01:13:03] SDK: use EGL display as provided
[21-09-2019 01:13:03] TimeSource: monotonic epoch time offset is 1569027511792652
[21-09-2019 01:13:03] Initialize DriveWorks SDK v2.2.3136
[21-09-2019 01:13:03] Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gca7b4b26e65 against Drive PDK v5.1.6.1
[21-09-2019 01:13:03] Initialize DriveWorks VisualizationSDK v2.2.3136
[21-09-2019 01:13:03] Initialize DriveWorksGL SDK v2.2.3136
[21-09-2019 01:13:03] SensorFactory::createSensor() -> camera.gmsl, output-format=yuv,fifo-size=3,isp-mode=yuv420-uint8,camera-type=ar0231-rccb-bae-sf3324,camera-group=a,slave=0
[21-09-2019 01:13:03] CameraGMSL: Couldn't set CameraGMSL setup thread sched params!
[21-09-2019 01:13:03] CameraGMSL: Create NvMediaIPPManager
[21-09-2019 01:13:03] CameraGMSL: required FPS = 30, resolution = 1920x1208
nvmedia isc: GetCameraPowerControlLevel: 936: Camera power control library: NVCCP
nvccp_verify_receive_pkt: request is Failed
nvmedia isc: NvccpCamPowerControl: 564: NVCCP command failed with ret NVCCP_REQ_FAILED
iscRootDevOpen: Failed to power on camera(s)
NvMediaISCRootDeviceCreate: Unable to open root device
nvmedia: ERROR: Init: Failed to create NvMedia ISC root device
[21-09-2019 01:13:03] Driveworks exception thrown: DW_SAL_CANNOT_CREATE_SENSOR: CameraGMSL: cannot connect to camera
  what():  [2019-09-21 01:13:03] DW Error DW_SAL_CANNOT_CREATE_SENSOR executing DW function:
 dwSAL_createSensor(&m_camera, params, m_sal)
 at /dvs/git/dirty/gitlab-master_av/dw/sdk/samples/sensors/camera/camera_gmsl/main.cpp:174
A brief glance at the log seems to indicate that a similar error occurs. That being NvMedia is unable to power on the cameras.
We also tried running sample_camera_usb. This worked.
still checking with the team. Has this system been installed in a vehicle? Have any camera-related hardware peripherals been plugged or unplugged without powering off the system first?
Yes. We commonly test our software on a vehicle.
No. We make sure to fully power off the system before plugging or unplugging camera-related hardware. We both poweroff using aurix terminal and switch off the power supply before plugging and unplugging the cameras.
Dear @aulia.widyaputra1,
Could you share below
  • Ping aurix(10.42.0.146) from tegra and check if any packet drop occur
  • Share Aurix version.
nvidia@tegra-ubuntu:~$ ping 10.42.0.146
PING 10.42.0.146 (10.42.0.146) 56(84) bytes of data.
64 bytes from 10.42.0.146: icmp_seq=1 ttl=64 time=0.434 ms
64 bytes from 10.42.0.146: icmp_seq=2 ttl=64 time=0.422 ms
64 bytes from 10.42.0.146: icmp_seq=3 ttl=64 time=0.419 ms
64 bytes from 10.42.0.146: icmp_seq=4 ttl=64 time=0.417 ms
64 bytes from 10.42.0.146: icmp_seq=5 ttl=64 time=0.416 ms
64 bytes from 10.42.0.146: icmp_seq=6 ttl=64 time=0.418 ms
64 bytes from 10.42.0.146: icmp_seq=7 ttl=64 time=0.502 ms
64 bytes from 10.42.0.146: icmp_seq=8 ttl=64 time=0.420 ms
64 bytes from 10.42.0.146: icmp_seq=9 ttl=64 time=0.417 ms
64 bytes from 10.42.0.146: icmp_seq=10 ttl=64 time=0.417 ms
64 bytes from 10.42.0.146: icmp_seq=11 ttl=64 time=0.414 ms
64 bytes from 10.42.0.146: icmp_seq=12 ttl=64 time=0.437 ms
64 bytes from 10.42.0.146: icmp_seq=13 ttl=64 time=0.415 ms
64 bytes from 10.42.0.146: icmp_seq=14 ttl=64 time=0.416 ms
64 bytes from 10.42.0.146: icmp_seq=15 ttl=64 time=0.420 ms
64 bytes from 10.42.0.146: icmp_seq=16 ttl=64 time=0.760 ms
64 bytes from 10.42.0.146: icmp_seq=17 ttl=64 time=0.424 ms
64 bytes from 10.42.0.146: icmp_seq=18 ttl=64 time=0.248 ms
64 bytes from 10.42.0.146: icmp_seq=19 ttl=64 time=0.417 ms
64 bytes from 10.42.0.146: icmp_seq=20 ttl=64 time=0.429 ms
^C
--- 10.42.0.146 ping statistics ---
20 packets transmitted, 20 received, 0% packet loss, time 19318ms
rtt min/avg/max/mdev = 0.248/0.433/0.760/0.086 ms
No packets are dropped.
nvidia@tegra-ubuntu:~$ nv_aurix_update -get_fw_version
Flashed AURIX fw version 4.04.01.00
SW Version: DRIVE-V5.2.6-E3550-AFW-Aurix-With3LSS-StepA-4.04.01
AURIX Chip revision: 00
Running version on the aurix terminal also returns the same version.
The aurix is reachable from Tegra.
You reflashed both Tegras with DRIVE OS 5.2.6 and no camera is working or each Tegra has different release? I hope the camera is not is use by any other process.
Please check using nvsipl_camera sample with different ports/cameras and see if the issue is specific to a port/camera
It’s not. If the camera is used by another process, the error message usually says that the device or resource is busy.
Currently the AGX is connected to cameras at PortA-0, PortC-0, PortD-0, PortD-2. Here are the logs when we try to run nvsipl_camera
nvidia@tegra-ubuntu:~/drive-t186ref-linux/samples/nvmedia/nvsipl/test/camera$ ./nvsipl_camera -c SF3324_DPHY_x2
DEVBLK_WORKER_2: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 435: ThreadFunc: Device block init failed(7f)
DEVBLK_WORKER_1: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 435: ThreadFunc: Device block init failed(7f)
Module_id 30 Severity 2 : Device block action failed for block (action, block) 11
Module_id 30 Severity 2 : Device block action failed for block (action, block) 12
DEVBLK_WORKER_3: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 435: ThreadFunc: Device block init failed(7f)
Module_id 30 Severity 2 : Device block action failed for block (action, block) 13
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 436: Init: DeviceBlock manager init failed
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 127
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvMSensorPipeline.cpp: 705: Deinit: Deinit() call in wrong state
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:0
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:1
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:2
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:3
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:4
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:5
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:6
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:7
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:8
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:9
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:10
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:11
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:12
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:13
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:14
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:15
Module_id 30 Severity 2 : src/devblk/fusa/cameramodule/common/utils/pwr_utils.cpp 464
Module_id 30 Severity 2 : nvccp_set_aggreg_pwr_off failed with status 2
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX96712DeserializerDriver/CNvMMax96712.cpp 566
Module_id 30 Severity 2 : MAX96712: CNvMMax96712::DoSetPower failed with SIPL error 127
Module_id 30 Severity 2 : src/devblk/common/ddi/DeserializerIF/CNvMDeserializer.cpp 42
Module_id 30 Severity 2 : CNvMDeserializer::SetPower failed with SIPL error 127
Module_id 30 Severity 2 : src/devblk/common/core/CNvMDeviceBlock.cpp 845
Module_id 30 Severity 2 : Deserializer SetPower failed with SIPL error 127
DEVBLK_WORKER_1: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 456: ThreadFunc: Device block deinit failed(7f)
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 456: ThreadFunc: Device block deinit failed(7f)
Module_id 30 Severity 2 : Device block action failed for block (action, block) 40
Module_id 30 Severity 2 : Device block action failed for block (action, block) 41
DEVBLK_WORKER_2: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 456: ThreadFunc: Device block deinit failed(7f)
Module_id 30 Severity 2 : Device block action failed for block (action, block) 42
DEVBLK_WORKER_3: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 456: ThreadFunc: Device block deinit failed(7f)
Module_id 30 Severity 2 : Device block action failed for block (action, block) 43
Module_id 30 Severity 2 : src/core/CNvMDeviceBlockMgr.cpp 244
Module_id 30 Severity 2 : Failed to deinit device blocks
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 1016: Deinit: DeviceBlock manager fails to deinit
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 49: ~CNvMCamera: CNvMCamera object fails to deinit
nvidia@tegra-ubuntu:~/drive-t186ref-linux/samples/nvmedia/nvsipl/test/camera$ ./nvsipl_camera -c SF3324_DPHY_x4
Here’s the result of adding the mask option to select on ly cameras on PortC-0 and PortD-0.
nvidia@tegra-ubuntu:~/drive-t186ref-linux/samples/nvmedia/nvsipl/test/camera$ ./nvsipl_camera -c SF3324_DPHY_x2 --link-enable-masks '0x0000 0x0000 0x0001 0x0001'
nvidia@tegra-ubuntu:~/drive-t186ref-linux/samples/nvmedia/nvsipl/test/camera$ ./nvsipl_camera -c SF3324_DPHY_x4 --link-enable-masks '0x0000 0x0000 0x0001 0x0001'
As stated in the previous posts, we’ve also tried different cameras, ports, and cables when running the sample_camera application. The same error occurs. The AGX seems to be able to detect and query the camera. But it somehow isn’t able to power it on.
May I know when did you purchase this board?
I am assuming the camera/cables has no issue. Could you check reflashing Aurix FW to avoid if issue related to Aurix FW. This helps to narrow down if it is related HW issue.
Also, please confirm if aurix version and DRIVE OS version are compatible. Thanks.
We received the board on the 9th November 2021. Payment was done on the 11th November 2021.
Should we follow the instructions in this link Flashing AURIX?
Before or after reflashing the Aurix? Could you provide the link to check the compatibility of Aurix and DriveOS?
We’re currently looking at the Release Properties section of DRIVE OS Release Notes and based on running version on Aurix, the versions seem compatible. The following is a repeat from the above post regarding Aurix version.
Yes.
OK. We’re currently running some tests using the other sensors. We’ll get back to you in around a week or two.
Flashing the Aurix worked. The camera is able to run now.
