I noticed, that yellow background color for kernel code in editor (nsight) is missing, if there is following statement in code:
#include <cuda_runtime_api.h>
This bug happen to be in nsight 7.5 and nsight 8.0
Everything is OK in nsight 7.0
I am always using Ubuntu and run installer.
Is there any solutions for this problem?
Best regards, Andrej
veraj
August 11, 2016, 6:56am
2
I have reproduced the issue and filed a bug to our dev.
Thanks for reporting.
Hi
is there any news about solving this bug? Thank you and best regards, Andrej
Hi
I found workaround for this problem. The problem is in indexer in Nsight. The solution (not pretty nice, but it works) is:
In file /usr/local/cuda/include/host_defines.h in line 185 add:
#if ( !defined(MY_INDEXER) )
in line 198 add:
#endif /* !defined(MY_INDEXER) */
You will get all together:
#define host
location (host)
#define device
location (device)
#define global
location (global)
#define shared
location (shared)
#define constant
location (constant)
#define managed
location (managed)
Now you have to set symbol MY_INDEXER in Nsight:
Project/Properties/C/C++General/Preprocessor Include Paths, Macros etc./Entries/CUDA C/CDT User Settings Entries
klick button: Add
pull down: Preprocessor Macro
Value: 1
klick button: OK
Klick button: Apply
klick button: OK
Project/C/C++ Index/Rebuild
