I’m currently on RTX 3070 on one of the gpu it is causing way too many issues, the gpu decoder reaches 100% when deepstream and when the app stops running the decoder still doesn’t free up. This has been causing way too many issues. Any help would be appreciated, thanks.
Related topics
| Decoding 4k streams causing issues on decoder? | 18 | 1690 | October 9, 2021 | |
| Decoder destructor exception causes GPU memory leak in deepstream v1.5 | 1 | 479 | May 21, 2019 | |
| GPU decoder unit has been locked on 100% usage | 3 | 2941 | April 25, 2021 | |
| Hardware decoder deallocation? | 6 | 972 | March 1, 2022 | |
| C++ gstreamer rtsp decoder nvh264 | 8 | 705 | December 13, 2023 | |
| NVDEC resource realse fail | 5 | 88 | March 10, 2025 | |
| I have a problem with video decoding in Deepstream 8.0 / RTX 5060 TI | 3 | 64 | March 2, 2026 | |
| Deepstream GPU Memory Leak in nvv4l2decoder | 8 | 1137 | August 23, 2022 | |
| Decode multi-stream with GTX 1080 using DeepStream SDK | 3 | 1064 | October 12, 2021 | |
| Deepstream 6.0 nvv4l2decoder suddenly uses 100% CPU and crashes the application | 16 | 1005 | July 25, 2023 |
